NP-350V5C-S0AIT blackscreen
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    Already tryed bios flash but no lucky.
    I have power led on , fan spinning but no video no beep noting.
    LA8861P rev 2.0.
    after about 2 minutes it boot
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: NP-350V5C-S0AIT blackscreen
    First flash bios with clean me so that it boots instantly. Do you get display on external monitor?? If the problem is no display on internal monitor only, then you need to measure the LVDS pins for voltage.
    • lordgeny
      • Apr 2016
      • 223
      • Italia
      thats my dump , can you remove me ?
        • 21692
        bios requests go here: https://www.badcaps.net/forum/forumdisplay.php?f=40
        • lordgeny
          • Apr 2016
          • 223
          • Italia
          any idea??? the black screen lag time it not same every time,
          But when boot if i reboot , it boot fast
          • ekozeko333
            [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
            by ekozeko333
            I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
            🔥 The Problem Started After Suspected ESD/PD Fault
            I experienced a power issue or ESD event through a USB-C charger
            After that, the NX20P5090 power switch was visibly burned and was replaced
            Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
            🧠 What I’ve Done So Far
            Flashed...
            06-21-2025, 02:48 AM
          • corrize
            Nikon D800 camera - flash don’t work and capacitor don’t charge
            by corrize
            Hello, I'm stuck in troubleshooting…
            The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
            In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
            When I press the flash button, it's detected by the system, flash icon appear on LDC display....
            10-01-2022, 10:02 AM
          • spmetroil
            Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
            by spmetroil
            I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
            The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
            I have a CH341A programmer and I already attempted the following steps:
            1. Identified the correct chip (W25Q128, 3.3V SPI flash).
            2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
            3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
            08-19-2025, 09:23 AM
          • abajor
            Canon VIXIA HF S10 A read data from inernal flash memory.
            by abajor
            Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
            Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
            The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
            I think my best shot is to figure out a way to read the internal flash memory outside...
            07-20-2024, 12:04 AM
          • Ihandyrepair
            4 red flash led 65X950G boot Sony and android logo but then black
            by Ihandyrepair
            HI guys
            I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
            here is the issue
            I have Sony and android logo. but then 4 led red flash lights front of the tv
            I have 3.3v ref. 12v reg then T con 12v when I press the power on button
            but then I get black screen and 4 red flash light at the front LED
            but I get 3 led flash on the LED driver board.
            I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
            so I tried...
            07-11-2024, 01:45 AM
