LG 55LM6200 part of image is darker
  • alfatv
    • Sep 2020
    • 353
    Please take a look at picture, seems to be panel related.
    Sometimes can see footprints from other scenes in that darker area.
    Already tried to clean and swap cables between T-con and panel, no effect.
    What voltage can be responsible for that? Any hints?
  • Diah
    • Feb 2013
    • 6562
    Re: LG 55LM6200 part of image is darker
    call service menu E-Z Adjust and from there ADC or test pattern to see if any change.
    service manual
    • alfatv
      • Sep 2020
      • 353
      Same thing with test pattern
        Is the tab bonding board on the bottom edge of the screen? I would inspect that section of the tab bonding board.
        • Diah
          • Feb 2013
          • 6562
          • alfatv
            • Sep 2020
            • 353
            Oops, here we go, I should have done it before asking.
              Well you found the problem, it is probably due to people spray glass cleaner on the screen and it drips down to the tab bonding board.
              • alfatv
                • Sep 2020
                • 353
                This is beyond my capabilities.
                If anyone is brave enough, I am giving this screen away for free, pickup only.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Yeah would have trace them via ports back to somewhere too, would be a hard repair not worth risking the COFIC being damaged either
                  • RDC55
                    • Dec 2017
                    • 180
                    That's the big side as far as pitch is concerned:-) Seems you could possibly repair an open if that is the issue and since they are redundant you can just look at the others to see how it should hook up if there is any doubt. Using one strand of finely stranded wire (about .12mm) should be easy enough to work with.
                    • angelos
                      • Dec 2012
                      • 573
                      • South Africa
                      You need a microscope! I once cut the wrong CKV lines on a tv and had to resolder those minute tracks with thin wires. What a nightmare. Good luck on the eye strain.
                      • alfatv
                        • Sep 2020
                        • 353
                        Please somebody who has this screen, share a picture of this section (post #6, 8)
                        • budwich
                          • Jul 2015
                          • 3097
                          you might post closeup pictures of all the edge board connectors. As suggested, you may notice how the section is designed in the other connectors. You might get lucky or someone might see a "pattern". Then, perhaps consider doing some form of small wires and conductive glue... just a suggestion.
                          • mlemon
                            • Feb 2021
                            • 34
                            I had somewhat similar situation where looks someone had sprayed some sort of chemical on the display and leaked down to the cables, however not as bad as yours.
                            After I cleaned mine, luckily the cable was ok but found a small a blown trace and a couple of burnt capacitors. I managed to fix the trace by jumping with a fine wire and replaced two burnt caps. TV came back to life with beautiful picture.
                            I have never done this type of microscopic level de-soldering/soldering, was not pretty finish but got it to work. Just use fine solder tip and fine solder 0.3mm or less and I think you have nothing to lose and feels great afterwards after fixing it. And looking closely at yours, looks some of the traces in the cable two in one so it helps a bit. Good luck.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Would be possible though, I've done it before on a liquid damaged panel. Bit of a mess about if I don't say so and make sure you have steady hands
                              • alfatv
                                • Sep 2020
                                • 353
                                Thanks for support, I am not giving up yet, here is what I figured out.
                                Some of connections are supply voltages and apparently are duplicated, so it may be OK not to connect them.
                                What is really missing is 6 gamma voltages and I will focus on that.
                                I was able to remove part of the tape, thanks to corrosion under it, so at least I have access to connections.
                                The wire is from solder wick, the thinnest I could find.
                                I use Iphone as microscope.
                                Let's see how far I can get.
                                • alfatv
                                  • Sep 2020
                                  • 353
                                  With help of my gf holding iphone, I managed to solder those 6 wires.
                                  Also had to add one jumper wire to the next tab as one of vias was corroded.
                                  It worked right away the way it should be.
                                  The case is closed, thanks everyone for help and inspiration.
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    Well done. Excellent job. An example of never give up.
                                    • faxygian
                                      • May 2021
                                      • 1
                                      • newyork
                                      Great job ... very good
                                      • mlemon
                                        • Feb 2021
                                        • 34
                                        Awsome, happy ending !
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • edugimeno
                                          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                          by edugimeno
                                          Hi There!
                                          I'm trying to help my friend who owns a restaurant be just bought.
                                          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                          It's stuck using, I guess, the 2 sided tape that comes with the strip
                                          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                          09-05-2024, 09:34 AM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • japlytic
                                          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                                          by japlytic
                                          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                                          Tried (only with keyboard/mouse connected):
                                          • BIOS + database update
                                          • Using latest Windows 11 image built with official image creation tool
                                          • Previous setup version for Windows 11 installer
                                          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                                          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                                          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                                          06-19-2025, 04:59 PM
                                        • shlomim412
                                          samsung ua55es6800 - no image
                                          by shlomim412
                                          hi
                                          having problem with samsung ua55es6800
                                          tv had backlight on, sound working - responds to the remote control but no image.
                                          check tcon board - had 12v in but no other voltages present.
                                          when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                                          when leaving only left side connected - again no voltages and no image.
                                          put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                                          kept trying to block less pins on the left ribbon cable...
                                          05-15-2024, 05:00 AM
