EPK50 LA-G073P Bios dump need
  • Dstecno
    • Jun 2019
    • 30
    • México
    Hello friends, i have a HP 15-da0002la with motherboard EPK50 LA-G073P rev 1.0, with the next error code, the caps lock blinks 5 times slow and then 3 times quickly, does somebody have the bios dump of this machine? or does somebody have more information about this error code ? thanks a lot.
  • peste
    • Dec 2016
    • 13600
    • ROMANIA
    Re: EPK50 LA-G073P Bios dump need
    try...
    • andrew25
      • Feb 2016
      • 224
      • Malawi
      Did you solve it, i have sam issue
      • lapfix
        • Mar 2020
        • 2764
        • my workshop
        Remove all accessory devices from the notebook.
        https://support.hp.com/us-en/document/c01732674
        • alterr333
          • May 2019
          • 43
          • México
          Originally posted by peste
          try...
          Thank you sire.
          • alterr333
            • May 2019
            • 43
            • México
            Mine does the exact same thing, just took out the MOBO found some rusted CAPS below the CPU
            I've cleaned them, checked the Tension fall on BIOS seems ok, let's cross fingers
            • Drivit
              • Mar 2021
              • 5
              • Mexico
              HP Notebook 15-da0019la (EPK50 LA-G073P)
              Hi, dear friends!
              Computer: HP Notebook 15-da0019la
              MoBo: EPK50 LA-G073P Rev: 1.0
              BIOS chip: XMC QU64AHIG
              I have this laptop with a frozen BIOS because of a Windows update. I already tried to reprogram the flash memory with a EZP2019 programmer (the autodetect doesn't work for the chip, so I used the W25Q64 chip option at 6 MHz, but not sure if this is correct way), unfortunaley, when I turn on the laptop it just blinks the code 5.3 in the caps lock.
              Besides, I found out that at the HP site for the model there is a software tool (https://support.hp.com/us-en/drivers...model/21909979) that extracts the BIOS file, but there are 6 different bin files (3 with 16MB size and the other 3 with 8MB size) plus another 6 files with .s12 extension (with the same names as the bin and 1KB size each one), with these names:
              084A6 -- 8MB
              084A8 -- 8MB *
              084AA -- 8MB *
              086B3 -- 16MB
              086C1 -- 16MB
              08532 -- 16MB
              According to the BIOS chip, I need an 8 MB file, so I tried with those marked with an * from the previuos list. But it didn't work, just the appear the blinking code again. I'm here to see if anyone could share the correct BIOS file (or a dump from the same laptop model), or if really worth it to try with the last 8 MB file; beacause I already de-soldered the chip twice. So, I think this is my last chance before a possible damage to the MoBo.
              I really apreciate your comments and help!
                • 21914
                Re: HP Notebook 15-da0019la (EPK50 LA-G073P)
                If you made a bios backup post it here .
                • Drivit
                  • Mar 2021
                  • 5
                  • Mexico
                  Yes, I did a BIOS backup of the chip. Here is the dump file, but the laptop didn't start with that BIOS.
                  • juaquinbab
                    • Aug 2020
                    • 1
                    • Colombia
                    I have the same problem, which they have been able to solve, thanks
                    Last edited by SMDFlea; 04-05-2021, 10:52 AM. Reason: https://translate.google.com
                    • Drivit
                      • Mar 2021
                      • 5
                      • Mexico
                      How did you solved it? Did you reprogram your chip with another BIOS file?
                      • el panke
                        • May 2019
                        • 78
                        • argentina
                        did u get the file?
                        • bachir2004
                          • Feb 2015
                          • 439
                          • maroc
                          Originally posted by el panke
                          did u get the file?
                          using hxd,you can see what is the MB bid.
                          • el panke
                            • May 2019
                            • 78
                            • argentina
                            i mean if he found the bios file that fixs it
                            the file posted here doesn't work
                              • 21914
                              The bios file posted here won`t work,its corrupt,also its been booted on another machine its "initialised" . Clean ME/TXE firmware will be in a "Configured" clean state. You can check it for yourself with MEAnalyzer - https://github.com/platomav/MEAnalyzer/releases
                              Post your original bios backup if you have one .
                              • el panke
                                • May 2019
                                • 78
                                • argentina
                                heres bios backup
                                hp 15 da0051la
                                  • 21914
                                  Your bios BID is the same as the OP , BID084AA .The link to the bios is in the first post,run the exe to copy the 8MB 084AA.bin .Program the bios, then enter your DMI info using wndmifit/HP Bios config utility .
                                  • kalisko
                                    • May 2016
                                    • 45
                                    • Serbia
                                    HP 15-da0044nm (4RM58EA)
                                    Processor: Intel Pentium Silver N5000, nVidia GeForce MX110,
                                    KB 9022q
                                    please for bios + EC
                                    thanks in advance
                                    • kalisko
                                      • May 2016
                                      • 45
                                      • Serbia
                                      Hp 15-da epk50 la-g073p
                                      KB 9022q
                                      thanks in advance
                                      My old bios
                                      PS:There are some bios on the forum but none are for this model I listed.
                                      • lapfix
                                        • Mar 2020
                                        • 2764
                                        • my workshop
                                        Re: Hp 15-da epk50 la-g073p
                                        Try and give feedback
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • mkdj
                                          ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                                          by mkdj
                                          Dear all,
                                          I have a ASUS ZenBook UX480F with the following symptoms:
                                          I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                                          I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                                          10-19-2025, 04:41 AM
                                        • Habble7
                                          I need a BIOS dump for the Samsung S49CG934SU monitor
                                          by Habble7
                                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                          Suspected Cause:
                                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                                          by Citymin
                                          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                                          The charging red LED lights up, but the charging screen doesn't show any indication.
                                          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                                          (I've tried removing the battery and resetting the device, but the issue persists.)
                                          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                                          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
