good evening. I have put the panel model, because it is a generic Chinese tv. The symptoms are the following: The rear light turns on, but there is no image, 12v arrives at the tcon integrated in the panel. I have made measurements of vgl, vgh and vaa. They are not present but they all act as rectifiers except for vaa, which is shorted. my questions are. Do you know any quick method to know the capacitor that is shorted without having a laboratory source? How could I know the value of the capacitor once extracted? I can't find schematics for this panel. a greeting
Tdsystems K40dlt3f Panel V400HJ6-PE1 REV C2 short circuit no image
Re: Tdsystems K40dlt3f Panel V400HJ6-PE1 REV C2 short circuit no image
test them with multimeter for shorts or very low ohms, just put a probe on each end of capacitor, if you have a meter that beeps in continuity mode and you get a steady beep its shorted, meter not the type that beeps no worries, if its very close to 000 its shorted, one bad cap can make the rest read short also.Last edited by nomoresonys; 12-24-2022, 11:22 AM.Comment
Thank you very much for answering. I already did that, the problem is that there are several short-circuits in the Vaa area. but I don't know which of them will be shorted without removing them from the board. with the circuit shorted, many capacitors beep. I do not know if it is possible to know in any way which of them it can be, without disassembling and without an external source to inject voltage. Thanks in advancetest them with multimeter for shorts or very low ohms, just put a probe on each end of capacitor, if you have a meter that beeps in continuity mode and you get a steady beep its shorted, meter not the type that beeps no worries, if its very close to 000 its shorted, one bad cap can make the rest read short also.Comment
something like this may help you find the shorted component: https://www.amazon.com/milliohm-mete...c7q6%2FkMXU3oQComment
there's other methods too, involving feeling for hot ones, voltage injection, infrared cameras, iso alcohol, candle wax etc, can check youtube, some say it's an obsolete method but I usually start at the end and remove one at a time til I find the shorted cap, they aren't that hard to replace with a little practice.Last edited by nomoresonys; 12-26-2022, 09:38 AM.Comment
by OOF DIO(If anyone has a functional boardview file of FX505DV/DU that would be helpful)
(Had 3 problems, now just 1)
I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I... -
by rimwallThis TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or... -
by AK_777Hi everyone!
I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and... -
by dragometinTV Model: Hitachi 40HYC42
Power Supply: 17IPS71
MainBoard: 17MB95M
Panel: VES400UNDS-2D-NO3
When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
Is there any variants on 17IPS71 power supply's?
UART output pins 10 and 12 on scart connector:
...Code:12:24:04.595
by salah11Hello everyone,
I have a persistent issue with a commercial intercom system (likely made in Turkey, based on the unit). Voice communication (audio) works perfectly, but the outdoor panel did not return the ring when the call button is pressed.
Whell the system consists of three main circuit boards (see attached photos):
A. Board 1: Power Supply / Ringer Generator (White Board) with LS1240A, BD442 and BD140 Power transistors for ring amplification.
B. Board 2: Handset (Indoor Unit) Role: Contains the microphone, the speaker/baffle, the manual hook switch, and the open-door...-
11-21-2025, 01:08 PM -
- Loading...
