"amd" ddr2...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    "amd" ddr2...
    So what's with the "AMD" DDR2?
    My (Intel) board "officially" supports 4G DDR2's (four slots, 16G total) but this "AMD" deal is kind of scary recalling back to the old SDRAM deal. In fact I have a few 512M SDRAM modules now but they don't work in my 440BX board, which is too bad, would rather run this board with 2GB RAM through its four slots, else have to use the VIA boards with only 3 slots is the best I can otherwise do.
    But anyway I heard these "AMD" DDR2 still "work" on an Intel board but cannot clock at PC6400 speeds if it comes labeled as such, and must underclock and run at PC5300 speeds... but is that all?
    Really should look into getting 8GB DDR3's instead of dumping more into DDR2...
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: "amd" ddr2...
    They have special timings for AMD IMC's, but will work in intel just fine, speeds might have to be set manually
    I think AM2+ can use 4gb sticks
    • lti
      • May 2011
      • 2557
      Re: "amd" ddr2...
      I saw some really goofy modules with recycled (and overclocked, but that isn't unusual today - look at modern DDR4 "gamer" RAM) chips in a configuration that Intel's memory controllers didn't support.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Re: "amd" ddr2...
        I was thinking about ripping up old modules and sticking more chips on unused double sided boards but finding equivalent chips is kind of tough.
        But the weird thing is that some of these 4G modules look legitimate... 32-chip modules, 2x8=16 on a side, samsung, hynix ?
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Re: "amd" ddr2...
          That's 99 percent true, if using 4 sticks and you likely need 1.90 V for VDIMM with 4 slots.
          Welcome to the IMC days, where the compatibility is mostly determined by the CPU chip, per-se!
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Re: "amd" ddr2...
            DDR2 predates IMC however, or did AMD design around DDR2 that doesn't quite fit JEDEC specs?
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Re: "amd" ddr2...
              True, in the case of Intel, where they clearly stuck to FSB until at least socket 1366 and socket 1156, IIRC.
              Arc A770 16 GB
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Re: "amd" ddr2...
                Nope. The last FSB sockets were 771 and 775. Nehalem and later uses IMC (to include DMI-based LGA1156).
                sigpic
                (Insert witty quote here)
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  Re: "amd" ddr2...
                  With the exception of soDIMM's, I don't think I've ever seen a PC2-5300 or 6400 that was non-ECC/non-FB/unregistered larger than 2gb.
                  <--- Badcaps.net Founder
                  Badcaps.net Services:
                  Motherboard Repair Services
                  http://folding.stanford.edu/
                  Team : 49813
                  Join in!!
                  Team Stats
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    Re: "amd" ddr2...
                    yeah triple channel imc. Was kind of impressive for the time for retail. I had a 920. Still have. It's my shop box
                    AMD's first IMC's since s754 around 2003, far before 1366
                    I've seen tons of them. 533, 667, 800, SO-dimms, regular dimms, Ecc, Registered, though i've seen few FB's over 667. It's easier to make 4gb and higher sticks with registered obviously.
                    AM2+ in particular can take 4gb sticks
                    • piernov
                      • Jan 2016
                      • 4437
                      • France
                      Re: "amd" ddr2...
                      DDR2 AMD only RAM is a thing because Intel had one less (column) address bit available on their memory controllers, so depending on the memory organization some sticks aren't compatible with Intel platforms.
                      The well-known RAM stick manufacturers very rarely used these chips, probably to avoid confusion with the end-user, but it seems like the sellers on Aliexpress got a hold of these (probably used) chips and are selling sticks with them cheaper than the "Intel-compatible" ones.
                      You can look for the datasheet of the RAM chips to see what the memory organization is.
                      I'm not sure about DDR3, but I remember that in the early days sticks were mainly 1.8V instead of 1.5V, and people were saying that it is an issue with (DDR3-only) Intel's Integrated Memory Controller, Intel specifications were only for 1.5V DDR3.
                      AMD AM3 CPUs still supported DDR2 that typically ran at 1.8V so it may be the reason why it wasn't seen as a problem for AMD.
                      I did confirm myself that both AMD-only DDR2 and DDR3 won't work in an Intel platform. So there may also be an issue similar to DDR2 addressing with DDR3 on Intel.
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16958
                        Re: "amd" ddr2...
                        Just as I said....except the "regular DIMM's" part... Feel free to link me to some regular 4gb PC2-6400 DIMM's; unbuffered, non-ECC, unregistered. I have plenty of the rest, up to 8gb/module for the workstation/server stuff (FB, ECC/Reg)....but 'regular' ones for consumer level stuff, 2gb seems to be the biggest I can find.
                        Team : 49813
                        Join in!!
                        Team Stats
                        • zunasthegreat
                          • Dec 2017
                          • 92
                          • EU
                          Re: "amd" ddr2...
                          I have such dimms (2x4GB AMD DDR2), those dimms use different chips/arrangment/rows "256Mx4" that have issues/incombatible with the intel memory controller design. I have tested the memories on intel P35 and the board only read them as 2GB dimms. Other users said that these memories work fine on nVidia s775 chipsets. It was meant as a cheap DDR2 alternative for AM2 platform.
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            Re: "amd" ddr2...
                            The G41 intel chipset supports 4gb ddr2 sticks
                            • piernov
                              • Jan 2016
                              • 4437
                              • France
                              Re: "amd" ddr2...
                              It's not an issue with the total memory capacity but an issue with the RAM chip organization. The "x4" chips transmit 4 bits at a time for a given memory address and have to use an additional column address bit to address the full memory that apparently Intel memory controllers don't support.
                              However it should not POST at all if you use this incompatible memory. (the SPD profile inside the stick should report the memory organization, and since the memory controller doesn't support it the BIOS should fail RAM initialization)
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16958
                                Re: "amd" ddr2...
                                Many of those also support DDR3.
                                Team : 49813
                                Join in!!
                                Team Stats
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  Re: "amd" ddr2...
                                  For SDRAM, my 440BX does not support "AMD" organization DIMMs. When I stick in "AMD" 512M SDRAM into it, it reports them as 128MB modules. Likewise for "AMD" 256M SDRAMs.
                                  However my VIA boards happily recognize all 512M on these modules... one's an Athlon, other is a P3.
                                  Seems like it's SDRAM funnybusiness once again in the DDR2 world?
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16958
                                    Re: "amd" ddr2...
                                    The BX chipset doesn't support 512mb modules as it is, it's a limitation within the chipset. It supports 256mb spanned over 4 slots for a max of 1gb. If you want 2gb RAM in that era of board, you need the GX chipset. There were a few slot-1 motherboards that sported this chipset for this reason....but most were slot-2.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      Re: "amd" ddr2...
                                      One would expect 512M modules to show up as 256M if 256M is supported. But even certain 256M modules also show up as 128M modules, so all these modules show up as 128M instead of 0M and start beeping...
                                      • RJARRRPCGP
                                        • Jul 2004
                                        • 6304
                                        Re: "amd" ddr2...
                                        Yes, those were the last to use FSB. 1366 and 1156 marks the change to IMC, which AMD was doing at least since socket 940 (2003, albeit they still made socket 462 CPUs and that didn't stop until 2005-ish) and socket 754, IIRC.
                                        Arc A770 16 GB
                                        • KYBOSH
                                          OTHER WORLD COMPUTING OWCTB3DK13PSL OWC 13 Port Thunderbolt 3 Dock - Disconnects when READING from External HD at high speeds
                                          by KYBOSH
                                          Weird one and way out of my league but I thought i drop it here in case anyone might have an idea on where to start looking.
                                          I have a Thunderbolt Dock that has been behaving fine for a long time.
                                          Admittedly I have only used it for menial data transfer tasks.
                                          A few days ago I connected a USB-C external hard drive to it and wanted to test the transfer speeds.
                                          I connected the proper high speed cables (USB-C to USB-C) and started the test with BlackMagic Disk Speed Test.
                                          It wrote to the disk just fine. Got nearly 900MB/s+ write speeds but when it came time...
                                          07-31-2024, 12:30 AM
                                          HP 260 G2 i3-6100U Specification for Upgrade or Repair
                                          This specification for the HP 260 G2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 boardview and 260 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP 260 G2 is accurate, safe,...
                                          09-12-2024, 03:44 PM
                                          ASUS VivoMini VM45-G027Z VivoMini 3865U Specification for Upgrade or Repair
                                          This specification for the ASUS VivoMini VM45-G027Z can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the VivoMini VM45-G027Z boardview and VivoMini VM45-G027Z schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
                                          This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          HP 260 G2 4405U Specification for Upgrade or Repair
