"amd" ddr2...
  • zunasthegreat
    • Dec 2017
    • 92
    • EU
    Re: "amd" ddr2...
    Originally posted by Uranium-235
    The G41 intel chipset supports 4gb ddr2 sticks
    4GB DDR2 dimms that are fully intel compatible are rare and expensive not worth it, last time I checked the price was over 100$ for a pair. Cheap China AMD DDR2 patent ones sell for less than 15$ a piece.
    Even DDR3 support on s775 Intel Chipsets has some limitations, if you want to use DDR3 4GB Dimms these have to be 2Rx8 (2 Rank). Single Rank (1Rx8) 4GB DDR3 won't work.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      Re: "amd" ddr2...
      I did bring that up...
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • brethin
        • Dec 2008
        • 1907
        Re: "amd" ddr2...
        I have plenty of 4g 6400 ddr2 intel good, and yes they are $100 a pair.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Re: "amd" ddr2...
          How about DDR3 - there also seems to be "AMD" DDR3... what gives?
          Seems 8G DDR3 modules are "AMD"ized... same deal?
          • brethin
            • Dec 2008
            • 1907
            Re: "amd" ddr2...
            AMD Ram adds a extra setting in the presets, it's nothing special really,. You can program any ram to include it.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Re: "amd" ddr2...
              Hmm.... so no problems with intel chipsets?
              ugh. hate trying to buy ram at minimal prices. Too much crap to avoid...
              Need to get 4GB of DDR2 (in no more than 2 slots) and 8GB of DDR3 (in one slot), both intel boards... Too much sneaky and useless buffered RAM... unless if there was a way to disable it...
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Re: "amd" ddr2...
                When I had 8 GB of DDR2, I just mixed the sticks and ran them at 333 Mhz (666/667) with the RAM voltage at 1.90V.
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Re: "amd" ddr2...
                  Hmm...tempting... a pair of DDR3 "Apple" Crucial SODIMMs... I wonder if they will work in an HP...
                  Then I need to sell off the other memory I have since I only have two slots...
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Re: "amd" ddr2...
                    What the H*LL
                    is there such thing as 2GB "AMD" DDR2's?
                    GRR.
                    I got a 4 set of 2G DDR2's and they don't play well, and it doesn't matter which MB I try:
                    4x old 1G = 4G (2 sets of 2 matching 1G modules)
                    2x old 2G = 4G (incidentally, one is ECC PC2-6400, other is plain PC2-5300)
                    2x old 2G + 2x old 1G = 6G
                    4x new 2G = Beep Beep Beep
                    2x 2 of the new 2G = 4G ("works set")
                    2x other 2 of the new 2G = Beep Beep Beep ("doesn't seem to work set")
                    2x new 2G (that works) + 2x old 2G = Dead machine
                    2x new 2G (that works) + 2x old 1G = 6G
                    2x new 2G (that doesn't seem to work) + 2x old 1G = Beep Beep Beep
                    grumble...
                    • brethin
                      • Dec 2008
                      • 1907
                      Re: "amd" ddr2...
                      You don't say what brand and what speeds the sticks are so I can't help you, just saying you have 4 sticks of 2g ddr2 is like saying I have 4 20" tires. Good luck.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Re: "amd" ddr2...
                        Well, I really didn't really need to know if the specific ones I had were problematic, just whether the existence of such was sufficient.
                        They are Hynix PC2-5300's if it's necessary to know the existence that these or some other brand are problematic.
                        Incidentally the two that "work" seem to pass memtest86 and was able to allow the computer to compile clang and firefox, so at least those look ok. The other two are still no show.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          #32
                          Re: "amd" ddr2...
                          There's been incompatibilities between some memory and motherboard combos for as long as I can remember. Knowing specific details like the make and model number will confirm the existence of such incompatibilities.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            Re: "amd" ddr2...
                            Well, of the four seemingly identical modules, I found three motherboards that have similar behavior with these two modules that don't behave properly. Bunk modules I think (but I don't have any AMD DDR2 boards).
                            So much for fleabaying memory modules...
                            One of the modules seems to have a stuck at fault. Other one, I don't know yet...
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Re: "amd" ddr2...
                              OK found the exact problem with the stuck fault: one of the data lines is broken
                              Ugh.
                              However... this may be somewhat fortunate - I have a dead 512M DDR2 DIMM that I can steal parts from Though I wonder if there's a way I could test my theory out with out destroying either...
                              Now the other one will be tougher to rootcause as I don't have memtest86+ data.
                              So nope, I don't think these are "AMD only" DIMMs, just faulty DIMMs I think. But the question remains: Are there any "AMD" 2GB DIMMs out there?
                              But ... all right! I was able to coax the computer to boot with the other faulty DIMM and get memtest86 running.
                              WOAH, major mess. Looks like it's either writing things to the wrong to the wrong address or doesn't have write timing down right. Hmm. Will need to muck with timings to see if it affects anything, too many bit errors to discern any patterns..
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                Re: "amd" ddr2...
                                AHA! Sigh, found a problem with the board: a broken track on the module, no wonder why changing timing did not help.
                                Now that bad 512M PC3200...whether it should be an organ donor...
                                • Retrorockit
                                  • Feb 2020
                                  • 105
                                  Re: "amd" ddr2...
                                  My understanding of this issue, and it applies to DDR2 qnd DDR3 is that AMD RAM is newer high density x128 chips, and Intel, or Dell RAM (they stuck with it longer than others I believe) is low density x64 RAM.
                                  Yes 4GB DDR2 x64 chips are rare and expensive. Partly because FBDIMMS filled that size slot back in the day, so there are very few old ones out there.
                                  Low density DDR3 used to be fairly easy to find, but now even the same part number replacements can be high density chips.
                                  • ChaosLegionnaire
                                    HC Overclocker
                                    • Jul 2012
                                    • 3266
                                    • Singapore
                                    #37
                                    Re: "amd" ddr2...
                                    yeah, i remember during the p4 and athlon xp/64 era, gigabyte boards didnt like corsair ram.
                                    when i built my first diy pc, i didnt know this but luckily i bought a gigabyte board with kingston ram. saved by serendipity! lol!
                                    • @udiophile99
                                      • Mar 2021
                                      • 14
                                      Re: "amd" ddr2...
                                      Believe it or not, that pair will definitely work in an HP. In act, they could work pretty well...
                                      • Lisa Su
                                        Badcaps
                                        • Apr 2021
                                        • 216
                                        • Taiwan
                                        #39
                                        Re: "amd" ddr2...
                                        You mean those cheap, unknown brand "AMD Only" DDR3 rams from China?
                                        I read that they are manufactured by using ECC/REG memory ICs from recycled server sticks. Apparently it's impossible to make them fully compatible with Intel chipsets so there we have "8GB DDR3 Only compatible with AMD".
                                        • Retrorockit
                                          • Feb 2020
                                          • 105
                                          Re: "amd" ddr2...
                                          Crucial.com lists the density of their modules at their website. If you go there and they list only X64 for your system then AMD RAM won't work. If they list X128 modules then it should be OK.But X128 modules can be much cheaper. Often it takes 1/2 as many X128 chips to make a module (single sided) as x64 (double sided).
                                          On Optiplex 360 builds with 2 DDR2 RAM slots it's cheaper to get an Opti 380 MB and 2x4GB x64 DDR3 modules than to try for 2x4GB DDR2 x64. About the only Intel chipset I know that can use 4x4GB x64 DDR2 are the X38 systems. In Dell that's the T3400 workstation and the XPS 420.I'll bump those up to 12GB so I can use modern 6GB GPUs, but it ain't cheap.
                                          • KYBOSH
                                            OTHER WORLD COMPUTING OWCTB3DK13PSL OWC 13 Port Thunderbolt 3 Dock - Disconnects when READING from External HD at high speeds
                                            by KYBOSH
                                            Weird one and way out of my league but I thought i drop it here in case anyone might have an idea on where to start looking.
                                            I have a Thunderbolt Dock that has been behaving fine for a long time.
                                            Admittedly I have only used it for menial data transfer tasks.
                                            A few days ago I connected a USB-C external hard drive to it and wanted to test the transfer speeds.
                                            I connected the proper high speed cables (USB-C to USB-C) and started the test with BlackMagic Disk Speed Test.
                                            It wrote to the disk just fine. Got nearly 900MB/s+ write speeds but when it came time...
                                            07-31-2024, 12:30 AM
                                            HP 260 G2 i3-6100U Specification for Upgrade or Repair
                                            This specification for the HP 260 G2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 boardview and 260 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP 260 G2 is accurate, safe,...
                                            09-12-2024, 03:44 PM
                                            ASUS VivoMini VM45-G027Z VivoMini 3865U Specification for Upgrade or Repair
                                            This specification for the ASUS VivoMini VM45-G027Z can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the VivoMini VM45-G027Z boardview and VivoMini VM45-G027Z schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            HP 260 G2 Mini i3-6100U Specification for Upgrade or Repair
                                            This specification for the HP 260 G2 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Mini boardview and 260 G2 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP 260 G2 Mini...
                                            HP 260 G2 Desktop Mini PC i5-6200U Specification for Upgrade or Repair
                                            This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
