Rca L32hd32d
  • Kevin O'Henly
    Ontario Member
    • May 2009
    • 48
    Rca L32hd32d
    Good folks at Badcaps,
    symptoms:
    ~ TV power-on dual-color LED shows green after red.
    ~ backlighting winks on and off once an stays off.
    ~ no bulging capa or bad caps using the ESR scope and signal generator method.
    ~ no sound from external signal sources or internal DVD.
    ~ DVD responds to panel switches: "ON" and "EJECT"
    RCA has not provided the power supply connector voltages for CP3908-1 and CP3909-1. These connectors go to the control board.
    Thank you for any assistance you can provide.
    Be yourself,
    everyone else is taken.
  • Wizard
    • Mar 2008
    • 2296
    Re: Rca L32hd32d
    This is horrible version of "T-CON"-less design. If there's problem with display and is traced to the this, whole mainboard replacement is necessary.
    Make sure there's none SMD fuse blown. Also make sure the backlight is perfectly neutral not pink or missing tube lit or 2 second and out syptom. This bear investigated especially around lamp supply & lamps section.
    Cheers, Wizard
    • markchess1960
      • Oct 2006
      • 4
      Re: Rca L32hd32d
      I may be of help with this.
      I have repaired this problem several times. For me so far the repair has been:
      On the main board (the one in the photo with the tuner and ribbon cables that go to the lcd panel itself) there is a surface mount ic. It is a 6 pin op amp - location IC1303. It usually shows signs of overheating and sometimes one or more of the traces connecting to it are burnt. The part number for it is: ec5461ab3-g and you can find them at B&D Enterprises online.
      You need some pretty good soldering skills to replace it though... it's very small, has to be installed in the correct direction, and you may have to repair or jump burnt or broken traces.
      You can find the location of this part by looking at the board about an inch inboard of the left edge of the left (as viewed from your photo) lcd panel ribbon cable connector CP1203
      • Mrtello
        • Jul 2011
        • 1
        Re: Rca L32hd32d
        My Problem with this tv ( L32hd32d)is that i got power but no picture the backlight is on but no display or menus, i got no voltage on the board that is on top of the lcd panel
        • bobsovacool
          • 1
          Re: Rca L32hd32d
          Mark- thanks for sharing this fix... it looks like my RCA had this problem, and yes, the IC was hard to R&R (i even trashed a new one by not using a small enough soldering iron tip and magnifier). What i did was surf around for a less expensive suitable cross referenced IC. The National Semi LM7321/7322 has specs that are close enough. I picked the 8-pin soic package, which will run cooler than the original IC (5-pin sot-23), since it is larger (and should therefore last longer reliability-wise). I bought an 8-soic experimenting circuit board (PCB) to solder this 8-SOIC onto. Then i soldered small leads to the TV pcb (very small leads such as those used for wire wrapping). Individual leads from stranded wire can be used, with thin shrink- tube used to insulate them. You can download the datasheets (original EC5461A) and replacement Nat Semi LM7321/7322 from their websites, cross reference which pins to solder where via the datasheets, and enjoy your tv again! By the way, the amplifier IC is used in the unity gain mode, which means that 2 of the pins are connected together (output connected back to inverting input) which can be done on the experimenting pcb, rather than on the main tv pcb (much easier to do). A total of 4 small wires are required to connect this IC pcb to the main pcb (power, ground, output, and non-inverting input). You can verify this by looking at the main pcb and the EC5461A datasheet) This fix cost just $5 rather than $20 plus! Again- i would not have accomplished this without Mr Mark Chess's input, so thank you Mark Chess!
          • Plocmstart
            • Jul 2012
            • 5
            • US
            Re: Rca L32hd32d
            Thanks for the tip. I also found that the voltage at the inductor L3502 powers up to 3.3V and then drops to around 900mV as the op amp must pull the supply down. I removed the op amp at first to see if this would keep the rail from dropping and it did. So I connected all the cables and the screen works fine again with no part populated. So I'm wondering what this part is doing. Does it set a bias voltage on the LCD panel, or some auxillary function for the TCON? I will probably still get a replacement part, but just curious how critical it might be. Thanks.
            • A Man
              • Jun 2010
              • 39
              • United States of America
              Re: Rca L32hd32d
              I just bought one of these sets and found the mains 6.3A fuse and varistor were toast. I replaced both and now get a red LED when I plug in the set. The LED changes to green when I push the power button and the DVD will load/eject. The display momentarily flashes "Please Wait" while the backlights flash on, then they go off and it stays like that.
              I've checked IC1303; it appears intact and normal. So I don't believe that is my problem.
              I'm leaning towards this... but need a little guidance please.
              Cheers, Wizard
              Thank you!
              • A Man
                • Jun 2010
                • 39
                Re: Rca L32hd32d
                Does anyone have the service manual or schematic diagram for this set? I've been unable to source one on the internet.
                Particularly I need to know the value of D3802. It is on the input side of the power supply and tests open in both directions.
                Any help would be greatly appreciated.
                  Re: Rca L32hd32d
                  That is likely a TVS, and unlikely to be at fault. It will normally test open.
                  • A Man
                    • Jun 2010
                    • 39
                    Re: Rca L32hd32d
                    Could this Transient Voltage Suppressor possibly fail if the mains fuse and varistor were both blown?
                    If this is not the problem, any ideas where to look? I have power to run the audio and DVD drive but the backlights shut off after saying Please Wait. This is my first problem like this.
                      Re: Rca L32hd32d
                      Oh, if the mains fuse is blown, that could be the fault. However, if it is open, it has not yet failed.
                      • A Man
                        • Jun 2010
                        • 39
                        Re: Rca L32hd32d
                        I've already replaced the mains fuse. (See post #7)
                        Are you saying the TVS will show show shorted if it has failed?
                          Re: Rca L32hd32d
                          Yes, almost always, unless a surge was really bad and completely destroyed it, but that usually shows externally.
                          • techtip
                            • Oct 2013
                            • 22
                            Re: Rca L32hd32d
                            32hd32d power supply
                            • techtip
                              • Oct 2013
                              • 22
                              Re: Rca L32hd32d
                              l32hd32d timing controllr2 schematic
                              • mrdoob
                                • Nov 2013
                                • 4
                                Re: Rca L32hd32d
                                Anyone have the regulator section of the schematics for this TV. I changed the op amp a couple of years ago and now I have the same issue where sound but no picture (back-light on). But there is no VCC getting to the op amp. I even disconnected the VCC from the op amp to make sure that the voltage wasn't being pulled down.
                                Thanks.
                                • Ariu
                                  BMW M-ASK PL2 blackscreen, no radio,  no Reaktion of DVD eject button!
                                  by Ariu
                                  I have a device (BMW CCC Unit), which no longer posts anything also blackscreen.
                                  The unit is getting power, dvd player is spinning but does not eject the DVD when eject Button is being pressed.
                                  Everything seems to be normal on the board ( no short), except „OASIS xs8805b0aq chip „, it is getting hot when the board is turned on.
                                  Does anyone has the datasheet or pinout diagram of that specific IC?
                                  Thanks.
                                  06-04-2025, 07:58 AM
                                • Tech 57
                                  Magnvox mwd2205 DVD Eject Problem
                                  by Tech 57
                                  This has A strange Problem No eject when plugged in if you plug it in 3times works Normally acts up when you unplug unit say 30min hit power or eject
                                  I dont know if the dvd driver board is defective or the power supply has bad caps I seen some posts where you hold power button and unplug Nothing works
                                  Unit Will Work normaly if you replug 3 to 5 times im repairing it for someone so they are not going to like this
                                  phil
                                  01-19-2022, 01:27 PM
                                • grimacelord
                                  No Power - Only Beeps - Missing 5V Rail Near F7502
                                  by grimacelord
                                  Working on a PS5 that came to me for no power. Console would not beep or power on when pressing the power button initially. Board model is EDM-010.
                                  I began by taking the console apart and performing a visual inspection on the board. Everything looked fine. I then tested the various fuses across both sides of the board and found that F7001 and F003 were both blown. I then looked closer at F7001 and found that the right side of the fuse read short on my multi-meter, so I injected 1V and found that a capacitor near the F7502 was getting hot, so I removed it and the...
                                  10-28-2024, 09:24 AM
                                • Natob82
                                  Micro Momentary Push Switch?
                                  by Natob82
                                  Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                  12-21-2022, 05:22 AM
                                • ratdude747
                                  Lite-On DVD drive eject issue
                                  by ratdude747
                                  Here's an odd one. I have two Lite-ON dvd burners that both won't eject correctly. Both of them make a clunk, and one will only eject if one "helps" it start by using a paper clip in the eject hole when hitting the button. The other will work after a few tries but usually "clunks" on the first few hits. One is a PATA lightscribe burner; the other is a SATA Burner.
                                  Is there a known cause for this issue? First time I've ever had issues with Lite-on drives.
                                  01-07-2018, 10:41 PM
