Lenovo G50-30 no POST on powerup
  • mastsrl
    • Apr 2019
    • 38
    • Argentina
    i'm having an idsue with a Lenovo G50-30, motherboard ACLU9/ACLU0 NM-A311
    REV: 1.0
    motherboard powers on(power LED), but no post, no video(internal or external), no beep, nothing.
    All power rails check ok, i have all the ALW rails(5, 3.3, 1.8 and 1.0) on standby as well as the LP rails, i have also all the VS voltages and Vcore(0.76v) Vgfx(0.86v), Vsoc 1V and active voltages(Vddr at 1.35v, etc)
    There's nothing on the screen, so it's not a no backlight scenario only.
    reflashed bios with a dump that i got here: https://www.badcaps.net/forum/showthread.php?t=54053 with no result.
    Also, pressing the power button for several seconds turns the motherboard off(so at least that logic is working).
    ¿any ideas?, ¿try another flash image?(flash chip seems to be ok, as i programmed it with blank check and verify and it passed everything ok)
  • lapfix
    • Mar 2020
    • 2751
    • my workshop
    Re: Lenovo G50-30 no POST on powerup
    Try to Clean me region fo your dump .
    • mastsrl
      • Apr 2019
      • 38
      • Argentina
      how to do that?, i've never done it before with a BIOS dump, i just googled and found wildly varying information
      • Stevedb
        Stevedb
        • Feb 2018
        • 624
        • Belgium
        Hi upload your Biosdump and ask in the bios section to clean your dump somebody Will do it for you then. Regards Steve
        • Duranitron
          • Jul 2014
          • 544
          • Philippines
          measure the vcc of the bios ic.. also the rtc battery
          Never stop LEARNING because life never stops TEACHING!
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3616
            • slovakia
            just throw in other bios dump and ofcourse measure all coils for voltage
            • mastsrl
              • Apr 2019
              • 38
              • Argentina
              i already managed to clean the ME settings after finding a guide, it didn't work.
              I also have another exact same model motherboard with another failure(blown EC), so i swapped flash chips between motherboards... nothing, same failure.
              I dumped that motherboard flash and did a ME cleanup, same issue.
              so far the bios i've tested are: one downloaded from the post i mentioned, no work
              swapped flash chips with another exact same model, no work.
              dumped that flash and cleaned ME region, no work.
              everytime same failure, no video out(in fact, screen remains totally dead, it's not a baccklight on but no graphics, it's totally dead), only power led
              @duranitron all voltages check ok, bios included.
              i'm baffled
              • mastsrl
                • Apr 2019
                • 38
                • Argentina
                i've been sent another BIOS, with replaced DMI area.. exactly the same issue
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  These sort of cases are very difficult to solve on soc structure. Still check ram clock/data signal(if u have oscilloscope better). Dramrst# on pin 30 of ram slot. All sys pwr good present??
                  • mauda
                    • Mar 2016
                    • 24
                    • Czech republic
                    Hello @mastsrl, did you find a solution? I have a very similar problem.
                    • mastsrl
                      • Apr 2019
                      • 38
                      • Argentina
                      no, and it's getting to be quite an issue with the customer.
                      I haven't checked dramrst, but as i've said in the 1st post, ALL power rails that i could measure are present and good.
                      So far we think it's a fried CPU, it's not the first lenovo with soldered CPU that has died
                      • piernov
                        • Jan 2016
                        • 4437
                        • France
                        Known good compatible DDR3L RAM?
                        Caps lock key triggering caps lock LED?
                        PLTRST# present?
                        • mauda
                          • Mar 2016
                          • 24
                          • Czech republic
                          @piernov
                          Known good compatible DDR3L RAM = yes, I tried.
                          Caps lock key triggering caps lock = no LED indication
                          PLTRST# present = 1.8V
                          Any other idea?
                          • mauda
                            • Mar 2016
                            • 24
                            • Czech republic
                            I will measure all power rails before/after power on again and write them here.
                            I hope that this motherboard is not death
                            • mauda
                              • Mar 2016
                              • 24
                              • Czech republic
                              Here are my measurements:
                              PL_coil = stand_by voltage, power_on voltage
                              PL301 = 20.4V, 20.4V
                              PL302 = 2.74V, 2.74V (without battery)
                              PL402 = 3.38V, 3.38V
                              PL404 = 5.1V, 5.1V
                              PL502 = 0V, 1.37V
                              PL601 = 1.8V, 1.8V
                              PL603 = 0V, 1V
                              PL701 = 0V, 1.06V
                              PL902 = 0V, 0.9V
                              PL903 = 0V, 0.78V
                              Voltages on:
                              EEPROM 1st pin = 1.8V
                              ETC battery = 3V
                              DRAMRST# = 1.34V
                              PLTRST# = 1.8V
                              Not measured:
                              PL101, PL102, PL201, PL202, PL401, PL403, PL501, PL602, PL901
                              Please, help ... what next should I check?
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                You need to measure powergood signal of each and every pwm.
                                • mauda
                                  • Mar 2016
                                  • 24
                                  • Czech republic
                                  PG signals (coil>controller,PGpin = voltage):
                                  PL402>PU401,pin2 = 2.8V
                                  PL404>PU402,pin2 = 0.2V
                                  PL502>PU501,pin10 = 1.37V when power_on
                                  PL601>PU601,pin5 = 0.57V
                                  PL603>PU602,pin2 = 3.3V
                                  PL701>PU701,pin5 = 0.67V when power_on
                                  PL902+PL903>PU901:
                                  - pin8 = 5V
                                  - pin15 = 3.3V when power_on
                                  - pin22 = 5V
                                  - pin27 = 3.3V when power_on
                                  • mauda
                                    • Mar 2016
                                    • 24
                                    • Czech republic
                                    I also tried to measure some KBC pins (ENE KB9012QF A4).
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      PU402, PIN2 POWERGOOD should be 3V.
                                      • mauda
                                        • Mar 2016
                                        • 24
                                        • Czech republic
                                        Can you please explain to me why the PU402 pin2 is not connected anywhere in the diagram?
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                          Lenovo 3000 Series Schematic
                                          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                          3000 C100 laptop with Braille keyboard
                                          Lenovo 3000 C
                                          C100, C200 - 15-inch XGA screen
                                          Lenovo 3000 N
                                          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                          N500 - 15.4 inch screen.
                                          Lenovo 3000 V
                                          V100, V200 - 12.1-inch WXGA models
                                          Lenovo 3000 G
                                          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                          10-04-2024, 06:05 AM
                                          Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                          09-06-2024, 06:40 AM
                                          This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                          09-06-2024, 06:06 AM
                                        • derradji89
                                          Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                          by derradji89
                                          Hi everyone 🤗
                                          I have a Lenovo MIX 320-10lCR computer.**
                                          1. **Operating System**: Windows 10 ** Education** 64-bit.
                                          2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                          3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                          4. **BIOS Chip Reflashing**: Currently,...
                                          04-19-2025, 03:04 PM
