Lenovo G50-30 bios dump needed
  • salawayon
    • Nov 2012
    • 568
    • philippines
    Infos:
    ACLU9/ACLU0 NM-A311
    REV: 1.0
    2014-03-12
    No display problem with this unit.
    Thanks..
  • kazia
    • May 2015
    • 145
    • indonesia
    Re: Lenovo G50-30 bios dump needed
    my be this your dump, make backup
    • mek007
      • Mar 2015
      • 13
      • Zambia
      Did you manage to solve problem.
      And what programmer are you using to read the gd25lq64cvigr eeprom chip
      • kadi144
        • Aug 2015
        • 690
        • algerie
        Lenovo g50-30 bios
        hi all
        i need a bios for IBM LENOVO G50-30
        the mother number is
        ACLU9-ACLU0
        NM-A311
        REV 1.0
        2014-03-12
        many thanks
        • kazia
          • May 2015
          • 145
          • indonesia
          Re: Lenovo g50-30 bios
          try..
          https://www.badcaps.net/forum/showth...ghlight=G50-30
          • kadi144
            • Aug 2015
            • 690
            • algerie
            thank you
            the problem is solved
            • fady
              • Apr 2016
              • 1
              • egypt
              thanxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
              • CARLOS RAMOS
                • Mar 2016
                • 1
                • colombia
                Gracias
                • rafik_40150
                  • Dec 2016
                  • 22
                  • algeria
                  its not supported by minipro tl866
                  • kazia
                    • May 2015
                    • 145
                    • indonesia
                    this chip has 1.8v spi, make sure your programmer support it.
                    otherwise use adapter 1.8v
                    • rafik_40150
                      • Dec 2016
                      • 22
                      • algeria
                      now i understand thank you kazia for information
                      just another qeustion and i am sorry if its stupide cause i read it in other forum
                      is it possible to replace the chip ( gd25lq64cvigr ) with a winband chip ( 16 mb ) when we donbt have the adapter?
                      thanks again
                      • abbas_govani
                        • Jul 2013
                        • 89
                        • India
                        thanks bro it works for me.
                        • abbas_govani
                          • Jul 2013
                          • 89
                          • India
                          for me minipro tl866 didnt work. it worked in rt809f with 1.8v adaptor
                          • mjalil28
                            Banned
                            • Oct 2015
                            • 45
                            Supported by BeeProg+
                            • GALVIX
                              • Feb 2015
                              • 2
                              • COLOMBIA
                              thanks....
                              • rickybucalan
                                • May 2013
                                • 322
                                • philippines
                                Lenovo G40-30 bios file.
                                hello everyone.
                                im looking for bios file for lenovo G4-30
                                MODEL :ACLU9-ACLUO NM-A311
                                REV 1.0
                                thanks in advance
                                • lzrman
                                  • Feb 2016
                                  • 3
                                  • georgia
                                  Re: Lenovo G40-30 bios file.
                                  its working dump..
                                  • bilinch
                                    • May 2015
                                    • 19
                                    • Turkey
                                    minipro tl866 works for me with 1.8v spi adapter. just unchecked id and manually choose ic "GD25Q64B".
                                    • swanand
                                      • Dec 2011
                                      • 50
                                      thanks
                                      • fsc2003
                                        • Mar 2015
                                        • 30
                                        • turkey
                                        thanks I will test it with tl866 and 1.8v adapter
                                        • Joluvillas
                                          Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                          by Joluvillas
                                          Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                          06-18-2024, 10:35 PM
                                        • AHmad_Salal
                                          Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                          by AHmad_Salal
                                          Hello all,
                                          I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                          11-28-2023, 05:28 AM
                                        • DynaxSC
                                          MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                                          by DynaxSC
                                          Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                                          I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                                          11-17-2023, 10:56 AM
                                        • TacticalFahrrad
                                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                          by TacticalFahrrad
                                          Hi everyone,
                                          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                          06-30-2025, 04:09 AM
                                        • hirens
                                          Lenovo ideapad 3 14IGL05 bios dump needed
                                          by hirens
                                          model: 81wh
                                          sn: pf36ta6h
                                          board no: nm-c961 gs453/gs553
                                          hey guys above is my laptop info
                                          it only blinks the power button kindly help me with a working dump
                                          old dump attached...
                                          07-21-2023, 04:48 AM
