Bios Asrock Z87 Extreme3 Rev. G/A 1.05
  • cnx24
    • Oct 2017
    • 3
    • Poland
    Hello, I need bios bin file for Asrock z87 Extreme3 Rev. G/A 1.05
    • 21874
    Re: Bios Asrock Z87 Extreme3 Rev. G/A 1.05
    Go to the support page,download the "Instant Flash" bios version. Extract the 8,196KB bios then open the bios with UEFITool,right click,select "extract body" .That will remove the 4KB header leaving you with the full 8,192KB bios .
    https://www.asrock.com/mb/intel/Z87%20Extreme3/#BIOS
    https://github.com/LongSoft/UEFITool..._A57_win32.zip
    • luvbe3
      Chicken
      • Oct 2017
      • 152
      • JAPAN
      try and rep
      • cnx24
        • Oct 2017
        • 3
        • Poland
        Hello. i did as you advised SMDFlea, now this motherboard is working fine, thanks a lot people
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • gabrieljma1
          Request: Full BIOS dump for ASRock Z790-CX (DDR5)
          by gabrieljma1
          I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
          The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
          I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
          10-08-2025, 03:32 PM
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
        • paulwal
          Updating a BIOS on ASROCK
          by paulwal
          Hi. I am not too up on installing BIOS so am looking for a little direction installing a BIOS update.
          https://www.asrock.com/MB/AMD/AB350%...index.asp#BIOS
          I have an ASROCK AB350 Pro4 that is running a P3.00 BIOS.
          CPU is AMD Ryzen5 1500X which I believe is a "Summit Ridge."
          Before I go ahead and update it to the latest version, I thought I would ask whether my plan is right to try and be sure I don't make a mess of things.
          It appears that the latest BIOS for this chip is the 5.80; therefore I need to install (one at a time)…
          10-02-2023, 04:13 PM
        • survivalbloke
          Unable to extract bios file from Lenovo bios exectuable
          by survivalbloke
          I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
          Code:
          "innoextract 7wcn38ww.exe"
          it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
          The trouble I'm having is that I'm not getting the newly...
          06-12-2024, 07:55 AM
