Heard of the stacking method for LED repair. How about the side by side method.
  • neilc6
    • Nov 2015
    • 1550
    Looks like they repaired this just enough so they could flip the TV. Owner bought it used. Would have been less work to replace the strips. Had to patch all the holes in the reflector sheet. LG 50LN5750. Saved a diffuser panel for this one but not the sheet.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Heard of the stacking method for LED repair. How about the side by side method.
    That is such a shoddy repair I would never put my name to it.
    • notallbad
      • Oct 2012
      • 1190
      That is bad, hope I don't ever come across anything like that.
      • neilc6
        • Nov 2015
        • 1550
        I have also seen a 42LN strip installed in a 50LN. The narrower spacing caused the corner to be darker and I had to patch the reflector sheet which had new openings cut to fit the shorter strip.
        • brucetv
          • May 2015
          • 281
          • united states
          What a mess. Must have been smoking some of that legal weed. Shameful
          • flibidy
            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
            by flibidy
            I have here a Magnum IA.100 which belongs to my parents.
            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
            What Ive done........
            01-01-2025, 01:26 PM
          • bouny56
            Lenovo E15 Nm-c421 usb-c work only in one side
            by bouny56
            ​Hello
            Laptop E15 I5 10gen
            Mb nm-c421
            I have a problem with the usb-c power dc.
            The motherboard start only in one side of the usb-c
            Replace the usb-c port 2 times same problem
            With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
            Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
            Can the pd controler be the fault ? Or something else maybe ?
            Thx
            02-11-2025, 03:15 AM
          • howardc64
            Best method to remove Samsung screwless rear panel
            by howardc64
            I've done a few of these. Using Samsung Service Manul method always result in some broken bits and the snap lock metal wire always gets bent and not reinstall as nice as original. After reinstall often have some pops and clicks. This is the best method I found so far. Pull the wire out instead
            https://youtu.be/paYZAc1rcWs?si=GHdTOv5ySIJgjZOC&t=82
            Here is a pic of how the hook on the wire locks
            Stil ended up with a couple of small broken bits on the bottom haha. But the wire stayed perfectly straight and seems easier/less forceful. Fishing...
            10-12-2025, 07:52 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • Stephen
            A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
            by Stephen
            Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
            05-29-2025, 10:35 AM
