Samsung UN60F7100AF blue screen no image with sound
  • Gasvan
    • Feb 2020
    • 17
    Hi i am new here and just wanted to get some feedback from the pros. Have a samsung here with no image but has sound with blue screen. I guessing its the tcon board its getting 12 volts. I unplugged the left side of ribbin cable from tcon to panel and left side of panel goes white right stays blue.then did same on right side with right side going white and left stays blue. Any help would be appretiated. Only thing i havent tried is testing the fuse on tcon board.
  • nomoresonys
    • 12218
    • U.S.
    Re: Samsung UN60F7100AF blue screen no image with sound
    Test it, black - probe on chassis ground and red probe on each side of fuse, should be around 12 volts each side.
    • Gasvan
      • Feb 2020
      • 17
      Hi ty i just took it apart again and tested the fuse its getting 12.2 volts at both ends
        Please upload good clear pictures of the whole backside of the TV showing all the boards so we can see what we are dealing with.
        • Gasvan
          • Feb 2020
          • 17
          Do i test the caps on the panel board in diode mode to see if there is a short
          • Gasvan
            • Feb 2020
            • 17
            Hi the tv has some kind of image now fades in and out and only in red
            • Gasvan
              • Feb 2020
              • 17
              Can any one take a look at the last pictures of my display im thinking the lcd panel is shot. Or might still be the tcon? Any feedback is appretiated
              • mar1in
                Samsung TU8000, backlight and sound on, stuck in blue screen
                by mar1in
                Hi everyone,
                I've got this Samsung here that would be stuck in a boot loop.
                After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                Thanks in advance
                11-08-2023, 05:43 PM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • wolf1976
                samsung ue40d6100 has no backlight no sound and image
                by wolf1976
                hi to all
                on the above model of samsung i have the faults i have told already on the title
                iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
                any idea from someone what can i measure so i can find the problem ?
                the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
                11-17-2024, 01:02 PM
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • Chrissygizmo
                samsung galaxy ao2s very temperamental after screen replaced
                by Chrissygizmo
                Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                Ive eventually managed to get it on and working but it's very temperamental...
                The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                05-26-2024, 12:05 AM
