Proview 17 inch lcd monitor model #700P
  • starmaxpc
    • Oct 2009
    • 117
    i have a proview 17 inch lcd monitor model #700P. it powers on with good signal for a couple seconds then goes black. i changed out 2 capacitors,( the bigger blue ones) 1000uf-25volts, that were popped and could see one smaller chip with 8 pins at u101 on the board that has a burn like it popped. also there are some darker like burn spots on the board by the what i do believe are the inverter chips. does this have anything to do with this problem?
    thanks.
  • EGuevarae
    • Nov 2008
    • 1336
    Re: Proview 17 inch lcd monitor model #700P
    thanks.
    Give series, values & cap ratings of remaining caps. Normally, on those power/inverter boards, all caps are replaced. Also, a picture from the other side of the board would help.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • Windows 10 Pro x64
    • GeForce GT1050
    • PlainBill
      • Feb 2009
      • 7034
      The discoloration to the right of T101 is normal. The discoloration to the left of T102 is excessive. I would expect there is a problem with the components on that side. As eguevarae has indicated, a picture of the bottom of the board is indicated.
      PlainBill
      • starmaxpc
        • Oct 2009
        • 117
        here is the pic as requested.
        caps remaining
        2 x 1000uf x 25v capXon
        2 x 470uf x 25v samXon
        1 x 220uf x 25v capXon
        2 other caps at L001 L002 i cant really identify best description is
        cc000331 LITAI
        the big cap is 50volt
        i hope this helps. please advise if anything else is required. thanks.
        • PlainBill
          • Feb 2009
          • 7034
          caps remaining
          cc000331 LITAI
          L001, etc are inductors, and have a very low failure rate.
          CapXom and SamXon are two manufacturers known to supply bad caps. As a matter of routine I will replace ALL of them with Panasonic FM series or a similar low ESR series cap from other reputable manufacturers.
          On the back side of the board, U101 appears to be damaged. U101, U102, U104 and U105 are probably all the same part number. C101 (and C105?) should also be replaced, and all leads on the transformers should be resoldered.
          As a final suggestion for future reference, I've found that turning the flash off, using a tripod, and taking the picture under room light eliminates the glare and makes the picture a lot easier to use. On a positive note, the pictures were of an excellent size for providing good detail.
          PlainBill
          • starmaxpc
            • Oct 2009
            • 117
            ok i have replaced caps, as mentioned, to a point where i have got it to power on with a good signal for approx 10 - 15 seconds then i get a black out. i then unplug cable from back of computer and then i get a no signal on lcd then plug cable back in to computer and the steps repeat over again is it possible the U101 chip is causing this fault?
            • PlainBill
              • Feb 2009
              • 7034
              This will require further troubleshooting. When the display 'blacks out' does the power led on the monitor stay green? If you press the power button (on the front of the monitor) twice does the display come back, then go black again after a few seconds? When the display has gone black can you see the 'desktop' if you use a very bright light to illuminate the screen? If the answer to these questions is 'yes', then U101 could very well be responsible.
              Time approximations are notoriously subjective. The normal sequence for inverter operation goes like this: The inverter controller gets a command to turn on the backlights. It then drives all CCFLs at full brightness. A few seconds later it begins monitoring the voltage across and the current through each CCFL. If any are out of range (too high or too low) it will turn off all backlights.
              When a fault exists, typically the backlights will be on one or two seconds, not 10-15 seconds. If U101 is bad, I would not expect the backlights to be on more than 1-2 seconds.
              PlainBill
              • starmaxpc
                • Oct 2009
                • 117
                yes to all of these!
                PlainBill
                from what i can see of the type of chip at u101 the i.d. of it is A 4606 BE4Y15. and from what i could see when the screen lit up it is in really great shape! im sure hoping i/we can fix this. thanks.
                • PlainBill
                  • Feb 2009
                  • 7034
                  A good picture of U105 might help. The ID you gave doesn't come up in a search.
                  PlainBill
                  • ecking767
                    • Oct 2009
                    • 492
                    Hello I have fix this boards alot and the 4 chips are AO4606.made Alpha & Omega Semiconductor They sell them on eBay cheap. From the picture I see one of the four burn out. replace all four and check the other components around that burn MOSFET like that zener diode and resistor. You may need the Inverter chip BIT3193G maybe?
                    • Bobdee
                      • Jun 2008
                      • 461
                      PlainBill
                      This is the one I think
                      http://pdf1.alldatasheet.com/datashe...MD/AO4606.html
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Thanks for the information and welcome to Badcaps.net!!
                        PlainBill
                        • starmaxpc
                          • Oct 2009
                          • 117
                          thanks for the info but upon further inspection the metal contact on the board where this chip goes is damaged. i guess it was cooked for a reason. there is no way ill be able to resolder a new chip onto this. i guess i'll keep the lcd for now maybe somewhere along the way i'll come across one that has a broken lcd or i could use the parts from this one to fix another??? thanks for all the help. it definetley was a learning experience.
                          • ecking767
                            • Oct 2009
                            • 492
                            Thank PlainBill for the welcoming. This is a excellent website. happy to share and help !!!
                            • ecking767
                              • Oct 2009
                              • 492
                              Looking at the picture bottom side of your circuit board I don't see any damage. Try cleaning the board with alcohol and a small brush. If you have an magnifying glass that will give you clearer picture of the trace and padding. Also there is some glue holding those transistors into place. So a hot air gun will be the best way to remove them to avoid damaging the circuit board.
                              • Bobdee
                                • Jun 2008
                                • 461
                                I am sure that if you post close up picture of bad area, some members will suggest good bridging methods for you to get over this problem
                                • smoresh
                                  • 4
                                  In my 700p I dismantled the power board as the green power led didn't come on. Found shirt across cc000331/litai504, (looking for data came to this site) unable to identify. Now seem to be part of filter. Now found short over 7815 in to gnd, and short of 2xdiode D6 also one cap looks swollen. Not handling screens normally. Any advise accepted.
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    Post pictures. Good, clear pictures, and indicate the problems you have identified.
                                    PlainBill
                                    • smoresh
                                      • 4
                                      dis soldered pins found 7815 and 2xdiode good. opened suspected route until U101 4606 seems cousing trouble. i am GMT+2, plese, what is that 4606 ? Thanks D.
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        assembly line worker lost his shirt in it?
                                        ROFLOL!
                                        anyway what range is your ohmmeter set to?
                                        some power supplies have loading resistors to keep it stable.
                                        if you really have a SHORT it wont work at all.
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • ChristianBr01
                                          Dell 34 inch U3419W Monitor with thin stripes on partial screen
                                          by ChristianBr01
                                          I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
                                          This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
                                          This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
                                          Does someone have seen this before?...
                                          05-23-2025, 06:06 AM
                                          HP ZBook Firefly 16 inch G10 Notebook Specification for Upgrade or Repair
                                          This specification for the HP ZBook Firefly 16 inch G10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 inch G10 boardview and 16 inch G10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 07:20 AM
                                          09-07-2024, 07:19 AM
