Laptop Screen Compatibility
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Dear Forum Members,
    Sometimes, I get a number of defective laptops with healthy screens. I have a generic question on finding a compatible laptop screen with LED-backlight.
    I know the following items must match to be a compatible screen:
    - The same resolution
    - The same screen size
    - The same connector location
    - Pin compatibility on the screen connector
    - Screen Type
    But I guess some other things may be important too that I do not know. For example, the LVDS version?
    Could anyone please clarify what other things must match to be a compatible screen?
    Even if a replacement screen is compatible with a different model number, how long is it expected to work on the laptop?
    Is it possible that this new screen that has a different model number, fail after a short period due to some hidden incompatibility? (For example, due to weakness of ICs on the screen board)
  • KvnTM
    • May 2018
    • 434
    Re: Laptop Screen Compatibility
    The most important thing to look out for is the pinout of the connector. Especially power rails. I've blown up a board by plugging in a wrong panel which shorted out the backlight rail.
    Another important thing is the protocol. Either LVDS or eDP.
    LCD panels usually live longer than the hardware driving it. They rarely fail if you don't damage or abuse them mechanically.
    • caspian
      • Oct 2015
      • 1591
      • Laptop
      Is it possible that this new screen works fine at first for a while and then it will fail after a month due to some hidden incompatibility between the new and the old screen?
      • jasko_jacker
        • Oct 2014
        • 1140
        • italy
        I don't think, there may be problems if some signals coming from the motherboard are outside specifications. These problems, in my experience, are very rare. On some types of screens it is possible that the firmware for identification becomes corrupted.
        Normally, even on the same notebook model, the manufacturer uses different brands of LCD.
        • KvnTM
          • May 2018
          • 434
          Not really. As long as all voltages are the same. Especially for the backlight. Some screens have the led/ccfl driver in the panel itself with a pwm control line and some have direct connections to the leds like in MacBooks which are driven by a high voltage.
          If there is a backlight on & pwm signal on the lvds connector then the panel itself includes the led/ccfl driver. Newer panels only have two connections (anode & cathode) for the led backlight strip. The whole led driver/backlight control is on the mainboard. Those led strips are driven up to 50V which would kill any older panel with an integrated driver. Those usually expect 19V for the backlight and 3.3v for the LCD/logic itself.
          Just pay close attention to the pinout and if it's the same you should be fine. But always double check everything.
          • KvnTM
            • May 2018
            • 434
            Normal windows laptop usually don't b*tch about the EDID/firmware.
            Only apple makes it impossible to replace the screen and remain brightness/color control. Same panel but wrong EDID? Well no backlight control and True Tone for you
            There are even threads on the internet where people replace the screens to get matte, full hd or even 4k displays in "older" laptops.
            • piernov
              • Jan 2016
              • 4439
              • France
              It is possible to replace a LCD with another model and it shouldn't cause long-term issue. I've been replacing panels by random eBay or "local Craigslist" ones, or swapping from other laptops for a long time, and if it works then there's no reason for it to fail because it's not the original one.
              Now about compatibility, there are a lot of parameters to look for:
              — Dimensions: obviously if you want it to fit correctly you have to chose the same diagonal size, this is often given directly in the model number (eg. LTN156AT32 is a 15.6" LCD). But you also have to look at the actual outer height and width for it to fit perfectly (it's rare but sometimes you have a few mm difference and it won't fit). Also, in some rare cases the thickness can matter too.
              — Mountings: if it's a "slim" panel (no metal case all around the panel, circuit board on the bottom protected by black tape), you can have a variety of mounting tabs (none at all, on the side, top/bottom…). If it's a "standard" panel (with metal case all around), you either screw the hinges directly or there are screwable tabs, the screw position should be the same on all panels.
              — Protocol: LVDS or eDP (even older panels used TMDS or a custom protocol).
              — Channels: 1, 2, 4 channels… linked to the definition, the higher the definition the higher the number of channels required. A 1-channel panel on a 2-channel motherboard should work, but not the opposite. With LVDS, if you use 2-channels panel on 1-channel board, typically the odd columns will be gray. Sometimes you can swap a 1-channel panel to a 2-channel panel (to get higher definition) because the laptop is actually designed to take the 2 definition. The 2nd channel needs to be enabled and routed to the LVDS connector, and the cable has to have the required wires (some rare laptops have 2 different cables for the 2 different definitions available).
              Higher number of channels may also mean connector with more pins.
              — Bit depth: 6-bit (262k colors) or 8-bit (16.7M colors), rarely matters, on laptops you can typically exchange between the 2. It's relevant on desktop monitors where the panel configuration is programmed statically in the scaler, if you use the wrong type you'll have scrambled image.
              — Connector type: there are 2 kinds of connector for LVDS, one with large pitch and one with small pitch with a large latch going all over the connector, typically large pitch is found on CCFL backlight and small pitch on LED backlight. eDP only has one kind as far as I know, similar to the small pitch for LVDS. There are 30 and 40 pins connector (some 20 and 50 pins exist too).
              — Connector pinout: pinout is standard, if you match the protocol and the connector type you should have the same pinout. One exception though, the large pitch LVDS on desktop panels has the pinout reversed compared to laptop panels, if you pick the wrong one (desktop panels usually don't fit in laptop but you never know) you can indeed fry the board.
              — Connector placement: typically CCFL panels have the connector on top and LED panels have the connector on the bottom. Horizontal positioning can vary so always compare with a picture. Some laptops that are sold with different panel have different cables depending on the connector position.
              — Backlight:
              CCFL: not used anymore on 2009+ laptops, some desktop monitors used it for a bit longer. Typically the connector is always the same on laptop, on desktop monitors you have a 2 pins (same as on laptop) and a 3 pins (middle pin is not connected). You can also have more than one tube on larger panels.
              LED: with integrated backlight driver or external backlight driver. Most laptops use panel with integrated backlight driver, they send the 19V directly to the display. Most desktops have the backlight driver on the mainboard or the power supply board.
              None: sometimes you can have panel without the backlight assembly, very rare though. Or OLED, haven't seen one yet so cannot tell you the difference.
              — Panel orientation: this is a bit of an odd one and never seen it on laptop, but I had the case of a desktop panel that was addressed "upside-down". No way to know it beforehand, and the original panel was not available, so I rotated the display in Windows, not very good as BIOS was still showing upside-down…
              — EDID whitelist: some rare laptops may have a whitelist for panels. Seen that only on a couple of older ones with LVDS, in that case you have to use a panel with very close characteristics (definition, bit depth, refresh rate) and swap (or flash) the EDID ROM chip; it's a 24-series I2C ROM.
              While it's not a whitelist, some machines may have the EDID panel configuration statically defined in the BIOS, in that case you also have to use a panel with very close characteristics. It's very rare on laptops, I think some Chromebooks with Coreboot did it… On desktop monitors it's commonly the case as I said earlier, the panel configuration is in the scaler firmware on the mainboard.
              There are certain combination of parameters that are extremely common, the 15.6" LVDS panel with LED backlight (integrated backlight driver), 1366x768 definition, "standard" shape (non-slim), connector on bottom left… This is typically used on your low to mid-range 15" consumer laptop from Acer, Toshiba, HP… 2008 to 2014 or something like that. So yeah, those are easy to find and won't cause much trouble, there are loads of different models that are compatible.
              And now, Apple: as expected, most of this doesn't apply with Apple panels. You have to use the original panel on Macbooks. Connector and pinout can be proprietary, they use a backlight driver on the mainboard rather than on the panel, panel shape and dimensions aren't like other laptops, they have an EDID whitelist, and you can't even use a 2013/2014 Retina panel on a 2015 Retina even though they have the same characteristics because they decided that backlight should be controlled a bit differently… Same for newer iMac. On old iMac like 2006 models you could swap the panel but it was a bit involving: there is an EDID whitelist so you have to swap the ROM, they used a desktop panel for the 17" iMac so pinout is reversed, it's thicker and has special mountings, and it has 2 CCFL tubes (laptops 17" panels have only one) so you have to connect a dummy tube behind the panel.
              Touch panels are another beast, and I haven't had to replace a fused panel yet but if you do, you have to use the original panel as well (since the digitizer is pretty much designed for a specific model). For non-fused panel (where you can separate LCD from digitizer) then you can use another model if it fits properly.
              • KvnTM
                • May 2018
                • 434
                Well that's a comprehensive explanation. Thank you very much for this. That should cover all questions.
                • caspian
                  • Oct 2015
                  • 1591
                  • Laptop
                  thanks @piernov and @KvnTM for spending much time on this question. I am reading your posts. I hope I will help you back some day.
                  • KvnTM
                    • May 2018
                    • 434
                    No worries my friend. You already helped me once or twice
                      • 21907
                      +1 .Thread stickied .
                      • Dan81
                        SNES-powered
                        • Oct 2013
                        • 1866
                        • Romania
                        Some Acers will boot (at least 6530G did) with different size screens. My 6530G had a broken Samsung 16" CCFL panel, but plugging in a 15.4" screen worked and I had a clear picture. (main NB died on it after a few hours, now I'm going to order a 6930G board + cooler so I can finally steer clear of AMD chipsets)
                        Main rig:
                        Gigabyte B75M-D3H
                        Core i5-3470 3.60GHz
                        16GB DDR3-1600
                        Samsung SH-224AB DVD-RW
                        Delux MG760 case
                        • caspian
                          • Oct 2015
                          • 1591
                          • Laptop
                          thanks, this is a useful topic too:
                          Connecting a laptop to a pin-compatible screen with a different screen size
                          this is useful when we want to test a laptop using a different-size screen where we do not have a same-size screen.
                          It would be great if members share their experiences in such situations.
                          Does connecting a laptop to a pin-compatible screen with a different screen size cause any damage after a while?
                          • Dan81
                            SNES-powered
                            • Oct 2013
                            • 1866
                            • Romania
                            Not really. At least my 6530G (soon to be 6930) worked fine with a 15.4 LCD but wouldn't fit into the case. Thing is you will need to match the manufacturer. In my case the shattered screen was a Samsung, and the good 15.4 LCD was a Samsung too. Interestingly, a 15.6 AU Optronics did work as well, but the backlight would shut off as soon as the BIOS splash screen would appear.
                            Main rig:
                            Gigabyte B75M-D3H
                            16GB DDR3-1600
                            Delux MG760 case
                            • caspian
                              • Oct 2015
                              • 1591
                              • Laptop
                              good/bad experiences on the following topic are welcome:
                              "Connecting a laptop to a pin-compatible screen with a different screen size"
                              • rediii
                                h???, spurrrn
                                • Mar 2018
                                • 501
                                • somewhere in europe
                                great explanation!
                                • caspian
                                  • Oct 2015
                                  • 1591
                                  • Laptop
                                  In addition, good/bad experiences on the following topic are welcome:
                                  "Replacing a laptop screen by a compatible screen belonging to a different brand"
                                  For example, somebody replaces an AUO screen by a compatible Samsung screen in a laptop.
                                  Is there any possible issue if we change the brand of laptop's screen?
                                  How long is such a replacement expected to last?
                                  Which screen brand is more durable?
                                  Recently, there exist various brands such as CMO, CHEMI, and Innolux that I am not experienced of. how are these screens?
                                  • shiftlord
                                    • Apr 2020
                                    • 2
                                    • United Kingdom
                                    Agreed, great explanation.
                                    I bumped into this site recently, might help somebody...
                                    http://lcdtech.info/en/data/lcd.panels.in.laptops.htm
                                    • lobz
                                      • Jul 2020
                                      • 3
                                      • Andorra
                                      led's are powered with dc and you have a led display.
                                      a lcd for backlight has cfl lamps and needs inverter to convert dc to ac.
                                      leds do not need this inverter because they operate with dc curent so you will need to replace with a led display not lcd.if the led display they find does not have touch they should be able to change it. it will work.
                                      • Duranitron
                                        • Jul 2014
                                        • 544
                                        • Philippines
                                        Do anyone can provide lcd screen model # compatibility list that we can safely swap.. so that we dont need to blow up a gpu chip if we make a mistake..
                                        here is mine.... samsung lcd screen 15.6 inch 40 pins model # LTN156AT27
                                        it is compatible with this screen model #
                                        BT156GW01
                                        LTN156AT24
                                        B156XTN02
                                        B156XTN02.0
                                        B156XTN02.1
                                        B156XTN02.2
                                        B156XW02
                                        B156XW02 V.6
                                        B156XW02 V.7
                                        CLAA156WA11A
                                        LP156WH4
                                        LTN156AT02
                                        LTN156AT05
                                        LTN156AT15
                                        LTN156AT17
                                        LTN156AT22
                                        LTN156AT28
                                        LTN156AT32
                                        N156B6-L04
                                        N156B6-L04
                                        N156B6-L0B
                                        N156BGE-L21
                                        NT156WHM-N50
                                        Never stop LEARNING because life never stops TEACHING!
