No power ACER C5V01 LA-E891P
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi I have motherboard that has no power 19v power rail is prsent no shorted found, checking the PU501 i dont have +1.2vp voltage then +0.6VSP voltages
    MOD Edit: Schematic & Boardview moved to Schematic requests sub forum --> https://www.badcaps.net/forum/showthread.php?t=123071
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: No power ACER C5V01 LA-E891P
    +1.2VP +0.6VSP comes after pressing the power button first check
    +RTC VCC
    SOC RTCRST
    +19VB
    +3VLP
    EC ON
    +3&5VALW
    SPOK
    +1.8VALW PRIM
    +1.8VALW PG
    1.0VALW PRIM
    EC RSMRST
    ON/OFF
    Unless you don't have this requirements the MOB will not power on
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      i only have the +3VLP on the supply unit I dont have any responses , what maybe the problem of this board. even pressing power or jumpering the power pins
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Does PL401 PL402 output 3/5ALW? Test impedance test with multimeter on PL401/2
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          +RTC VCC
          SOC RTCRST
          +19VB
          +3VLP
          EC ON
          +3&5VALW
          SPOK
          +1.8VALW PRIM
          +1.8VALW PG
          1.0VALW PRIM
          EC RSMRST
          ON/OFF
          PL401 HAS 5V present but in pl402 has no voltages
          • Techtiger
            • Oct 2014
            • 1602
            • france
            Remove the jumper pj403 and test Ohms both sides , test 19V in PQ402 , test cap PC413 Ohms , test PU401 pin 6 7 8 9 10 11 Voltage
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              PJ403 the left side has 19ohms the right side has 400 ohms PQ402 has +19v PC413 has 200 ohms PU401 pin 9 has 4.7vpin 10 has 4 milli volt pin 11 has no voltage
              • Techtiger
                • Oct 2014
                • 1602
                • france
                if thats so 19 Ohms then PL402 should be the same that's not good now you have to test PC416 PR410 PQ402 for short and pin 6 of PU401 must have 3.3V EN or change the PU401
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  PC416 pr410 has no smd part but it has no short pin 6 has no voltages at all
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    Trace it back 3V_EN comes from this pic point MAINPWON becomes EN through a Z-Diode
                    • kalilinux25
                      • Mar 2018
                      • 2089
                      • ZAMBOANGA SIBUGAY
                      MAINPWON has 3V the other side has no voltage at all
                      • Cesert
                        • Jun 2013
                        • 32
                        • Brazil
                        Thx for the schematics and board views.
                        • adonees
                          • Jun 2015
                          • 1
                          • Iraq
                          Thanks for the schematics I just figured out that the Camera module failed and was causing short and the laptop was only blue light flashing.
                          • FixStation2020
                            • Oct 2020
                            • 8
                            • Philippine
                            File Type: pdf Acer Aspire A515 series Compal LA-E891P r1A.pdf (1.83 MB, 590 views)
                            File Type: rar ACER C5V01 LA-E891P REV 2A.rar (329.4 KB, 530 views) i have thesame prob.of this laptop ....thanks to someone giving file
                            • kalilinux25
                              • Mar 2018
                              • 2089
                              • ZAMBOANGA SIBUGAY
                              great
                              • Mazorca
                                • Jan 2017
                                • 463
                                This board has the power button on the keyboard on the laptop. How do I bypass that button and turn it on manually? The keyboard had liquid damage and has been taken out.
                                • stingerchamp
                                  • Sep 2020
                                  • 425
                                  • Pakistan
                                  Provide ground to connector pins
                                  When you press power button below power button connects to ground and this gives ground to connector pin and board turns on
                                  At connector with tweezers short pin 1 or 2
                                  Look in schematic
                                  • Mazorca
                                    • Jan 2017
                                    • 463
                                    Thank you stingerchamp. I tried shorting pin 27 (ON/OFFBTN#) on the keyboard connector, no luck, there is no voltage either. There is no ACOK(on the charger) or +3VLP either so Im just going to put it aside.
                                    • Sephir0th
                                      • Oct 2020
                                      • 1289
                                      Did you solved this? It's exact the Same Case Here. 3V_EN isn't Coming Out, but MAINPWON present. No short found. Diode Reads 0.344V/O.L. in Diode Mode. Do i have to replace the diode, the IC or the whole SIO?
                                      Thank you in advance!
                                      FairRepair on YouTube
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        RB16 both sides 3V present?? If present, you can cut the track between diode and 3v_EN and thereby enabling 3V_EN from 3V_EN_R. Revived a dell 3567 15341 mb using this trick where the ram ic was not generating VTT but 1.2V was present on coil.
