Hi, I have kbc bios of ASUS p533UJ rev 2.0 . I need dump bios Thanks
need p533UJ rev 2.0 bios
Tags: None
Re: need p533UJ rev 2.0 bios
Asus PRO P533UJ
main Asus P553UJ rev2.0.bin
CPU SR2EZ I7 6500U
GPU N16V-GM-B1
KBC ITE IT8995E-128 CXAAttached Files -
here it is .Attached FilesComment
can you help us we also need for this model asus P553UJ REV:2.O
BACK-UPAttached FilesComment
https://www.badcaps.net/donateComment
Re: asus P553UJ Bios
I 'm not sure if the BIOS on this laptop comes with the BIOS.
The BIOS I sent cannot be updated.Attached FilesComment
That bios for Asus P2540UA.
Here : https://www.badcaps.net/forum/showthread.php?t=75439Last edited by hoaca388; 04-10-2022, 12:58 AM.↵
Try:Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Can you fix this bios?
Laptop turns on but turns off suddenly.
Asus P2540U
H8NXCV129361346
P2540UV-DM0035Attached FilesComment
P2540UVAttached Files↵
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
I have spent the last hour on this and I guess this is just over my head, so here I am.
I have an ASUS TUF GAMING Z790-PLUS WIFI motherboard here that needs to have the BIOS updated in order to accept the latest CPUs.
The BIOS chips seem to come as a set of two: GD25B64ESIG and GD25B128ESIG. My guess is one of them is a fail-safe for the main BIOS? I really don't know. Or one of them is ME and other is BIOS? I don't know.
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
Channel: BIOS & Schematic Requests!
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
by lrouw84Hi there,
I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....-
- Loading...
- No more items.
