Apple 27" Cinema Display (A1316) has trouble turning backlight on
  • Misterkeeks
    • Nov 2013
    • 74
    • America
    I have an Apple A1316 27” Display (non-Thunderbolt) that is exhibiting a weird backlight issue.
    When first plugged into a computer, when it receives a signal, the backlight flickers briefly but fails to stay on. Otherwise the monitor works fine (the computer thinks another monitor is attached, I can see that it is displaying using a flashlight).
    I tried turning it's brightness all the way down before connecting it. When connected, it flickered, then stayed on. So it seems that it can barely muster enough energy to turn the backlight on, but once it's on, it's fine. Other people have had issues with no backlight after a period of functionality, my issue seems to be kind of the opposite.
    What should I start testing on this? It seems like the power supply just can't handle the load it's getting all of the sudden.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8339
    Re: Apple 27" Cinema Display (A1316) has trouble turning backlight on
    If your back lights stay on, when the level is turned down to next to nothing, then one or more LED's in the back light strip could be still bad. LED's can fail like that.
    • Misterkeeks
      • Nov 2013
      • 74
      • America
      I think maybe I provided an iffy problem description.
      If I turn the display brightness all the way down before connecting the monitor (and thereby turning it on, as it has no physical button of any kind), the backlight successfully turns on, after which I can turn it up as much as I want with no issues.
      Basically, once the backlight is on, things are fine. No problems.
      But getting the backlight on requires the brightness to be turned way down, or it won't turn on.
      • R_J
        • Jun 2012
        • 9602
        This does seem like a bad capacitor on the power supply, The weak capacitor will take some time to charge to the full voltage, so by turning down the brightness/backlight will allow the cap to charge with minimum current being drawn from the circuit. Once the cap is charged, you can then draw more current from that circuit.
        If the brightness is tured up at start, the caps voltage will be too low tripping the led's error circuit and shutting it down.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8339
          I agree with RJ. In order to test this, heat up the caps with a hair dryer, so the caps are warm, but not hot that you burn yourself. Then turn the monitor on and see what happens.
          • Misterkeeks
            • Nov 2013
            • 74
            • America
            So, I ended up trying a replacement power supply as I got one for a lower price than they usually go. Issue persists in the exact same way.
            So, next suspect I guess is the main board, which also contains the backlight circuitry. I’ve attached a stock photo of this board to the post. The backlight connector is the black plastic connector on the bottom left/middle area.
            Seems like there are a lot of SMD electrolytic capacitors, as well as some voltage regulators (?) in that region. I can replace the whole board for $35, but are there any things I can diagnose now with a multimeter?
            Also, is it possible that failing LEDs would require more current to start up, thus causing an intermittent failure to turn on the backlight?
            I guess I’ll try the hairdryer trick on the main board as well.
            • Misterkeeks
              • Nov 2013
              • 74
              • America
              Replacing the backlight with new LED strips fixed the issue. So, I'm inclined to say that a lot of the common no backlight failures on this model stem from a failure of the LEDs.
              Unfortunately in the process of replacing I must have strained one of the ribbon cables - I now have a line running down the side of the screen.
              • jetadm123
                • 2169
                Good job on the fix. For future reference, can you please supply the part number or seller you purchased the LED strips from?
                • Misterkeeks
                  • Nov 2013
                  • 74
                  • America
                  This is what I purchased - later on I realized that other sellers on AliExpress had it cheaper - about $11. Attached a picture for posterity.
                  This is the same panel used in the 27” iMacs- the backlight likes to fail there too, typically the connector on one side goes out, leaving half the display dim.
                  • jetadm123
                    • 2169
                    Thanks! I'm sure others with the same problem will appreciate this info.
                    • Misterkeeks
                      • Nov 2013
                      • 74
                      • America
                      Hopefully. Other people with no backlight found that giving a constant 3.3v to the PWM input on the backlight controller restored the backlight - at full brightness, permanently of course. They seemed to think that the issue lay in a bad microcontroller that failed to produce the signal. Given the success of this repair, I'm inclined to think that the issue was in the overcurrent protection correctly triggering and the failure to generate the PWM signal was merely a symptom of aging backlight.
                      • Misterkeeks
                        • Nov 2013
                        • 74
                        • America
                        I spoke too soon regarding the success of this repair. Shortly after replacing the LED strips, the problem persisted.
                        So,
                        • Replacing the Power Supply
                        • Replacing the LED Strips
                        both have failed to fix the issue, which leaves me with the logic board.
                        For what it's worth, 27" iMacs use the same panel, but do not fail in the same way. I guest that should suggest that the failure is not located in the panel, but in the logic board (which is not shared with the 27" iMac. Any ideas on how to troubleshoot this?
                        This problem happens when the backlight controller does not provide a PWM signal to the LED drivers for brightness. Previous "repairs" seem to simply bypass the controller and tie the PWM to 3.3v, thus keeping the backlight on at full brightness.
                        • Misterkeeks
                          • Nov 2013
                          • 74
                          • America
                          Any thoughts before I spend $30 on a (used) logic board/backlight controller?
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8339
                            Personally, I’d stick it in my ultrasonic cleaner and after that I’d bake it in the oven for 20 mins. Got nothing much to loose.
                            • avneeshshrotria
                              • Oct 2019
                              • 25
                              • India
                              guys I need the values of some of the components around NCP1605 on the power supply board .
                              I'm attaching an image for reference . I would really appreciate it if someone could help.
                              Apple thunderbolt display PSU
                              Board model number : PA-3251-3A
                              the first one I got the this thread itself.
                              and the burnt one is what is the current condition of my power supply .
                              Also if someone is aware of schematics . I could just use that.
                              thanks everyone. this is one of the best fourms I've come across .
                              • avneeshshrotria
                                • Oct 2019
                                • 25
                                • India
                                Hey , can someone please help ?
                                • Misterkeeks
                                  • Nov 2013
                                  • 74
                                  • America
                                  Do you still want this info? Let me know and I will look. Send me a PM or I will likely not see your post.
                                  • avneeshshrotria
                                    • Oct 2019
                                    • 25
                                    • India
                                    Thanks very much. Yes I’m still stuck with a non working display dude to this power supply issue! Please share images or values as you see fit !
                                    • iuliantv
                                      • Aug 2009
                                      • 36
                                      • Romania
                                      hello, I have this apple cinema display 27 "A1316, with well known problem, it has no backlight, I applied the method described in other forums, I minimized the light from the macbook, I restarted the systems, it started ok apple cinema display 27", the light seems to be correct, without shadows, spots or dimly lit parts, which leads me to think that the LEDs, the backlight is ok, I applied the method described on other forums, I removed the 3 resistors, and I applied 3v on the ends of 2 of them, I put on all 3 ends, without result, did anyone find another solution? something needs to be done besides removing the 3 resistors and applying 3v ,? thank you
                                      https://www.ifixit.com/Answers/View/...he+Logic+board
                                      • iuliantv
                                        • Aug 2009
                                        • 36
                                        • Romania
                                        Thanks very much. Yes I'm still stuck with a non working display dude to this power supply issue! Please share images or values as you see fit !
                                        I'm sorry, but my apple display 27 "has a completely different source of power, otherwise I would put pictures with it
                                        • roxboy1984
                                          Apple cinema display A1316 takes forever to turn on!
                                          by roxboy1984
                                          Please could someone help or advise. I have an Apple Cinema Display A1316 and it all of a sudden is taking a really long time to come on. I assume it's probably a capacitor related issue on the power board, I'm just wondering if anyone has experienced something similar and if these monitors are easy and or worth trying to get repaired. Thanks in advance for the help.
                                          12-12-2022, 01:14 PM
                                        • a_p3rson
                                          Apple Watch Charging Controller Schematics / Boardview - 820-02601
                                          by a_p3rson
                                          Hi there,
                                          I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                                          You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                                          This daughterboard uses an interesting...
                                          04-21-2025, 11:41 PM
                                        • mikiotty
                                          Apple Cinema Display 23" A1082 turning on but no image
                                          by mikiotty
                                          Hi everyone!
                                          A friend of mine gave me an Apple Cinema Display 23" A1082, the aluminum one from late 2005.
                                          The display turns on, as I can see the backlight increase or decrease following the input from the controls.
                                          The computer sees the monitor, and supposedly sends signal to it, but all I can see is a black screen.
                                          Ideas?
                                          04-16-2020, 04:09 AM
                                          HP ProDesk 600 G5 + Apple AirPods ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + Apple AirPods can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Apple AirPods boardview and ProDesk 600 G5 + Apple AirPods schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-12-2024, 02:30 PM
                                          HP EliteBook 830 G6 + Apple AirPods Pro Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 830 G6 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Apple AirPods Pro boardview and 830 G6 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 07:50 PM
