HP-D2402E0 PSU starts then stops
  • dannobyte
    • Mar 2012
    PSU with a model number HP-D2402E0
    Fault: When the start button on the desktop is pressed the fan briefly (1 or 2 seconds) starts spinning and then stops. Sometimes it will continue starting and stopping, other times it will cycle once and then stop.
    Tests conducted: I removed the PSU from the desktop case and plugged it in to the mains. I then shorted the green wire to earth and the fan spun up normally So when the PSU is connected to the motherboard it fails but when it is disconnected from the motherboard it works as normal.
    Possible conclusion: From what I can see I think it may be the motherboard.
    Any thoughts on the subject would be appreciated.
    • Jul 2011
    • 6059
    Re: HP-D2402E0 PSU starts then stops
    Does it normally in another computer correctly
    • glovecaps
      by glovecaps
      11-25-2024, 04:23 PM
    • Docus
      Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
      by Docus
      Hi everyone 😀,
      I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
      To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
      Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
      1. I already own the exact same model, but its plastic chassis is badly damaged.
      06-10-2025, 04:24 PM
    • Victor Petrovich
      Lenovo IdeaPad 3 15ITL6 doesn't start
      by Victor Petrovich
      I have laptop Lenovo IdeaPad 3 15ITL6 with Intel Core i3-1115G4. When I press the start button, LED light on the start button starts blinking 12 times, then stops and after some time starts blinking 12 times again. When it stops, all voltages are down.
      The motherboard is HS460 HS560 HS760 NM-D471 Rev: 2.0
      S/N: PF3Q0WTF
      The motherboard is not mine, also there were corrosion on the board which I cleaned.
      Methods of fixing like fully turning off the motherboard or starting only with adapter doesn't work. All testing were did only with adapter on.
      06-07-2025, 02:40 AM
    • Caimano
      Asus P2520L starts and stops ok but no display
      by Caimano
      Model Asus P2520L
      MB P552LA_LJ Rev 2.1 with soldered I3 5010U processor
      The laptop charges battery and seem to react to power on, power off, reset regularly, but nothing appears on screen or HDMI or VGA monitor.
      Same behaviour when running on battery only, on mains only or on both.
      Battery charges fine. RTC battery ok at 3.025V.
      When powered on the power on led lits, after a short while the HDD led flashes, but no video. All voltages seem present. ALL_SYSTEM_PWRGD is present, BUFF_PLT_RST# goes high. CPU warms up and fan starts and stop from time to time....
      03-29-2023, 03:05 AM
    • Archimedes
      HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
      by Archimedes
      Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
      Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
      Fans are spinning. Blindly could install windows11 and got the device manager...
      07-30-2024, 05:14 PM
