Sharp LC-40LE810UN Dead
  • alfredomfr1
    • Oct 2014
    • 318
    • usa
    No Power, No blinking code.
    PD 1-4: fluctuating from 0v to 13v and back again
    PD 11: 5v
    others PD: 0v
    all BL: 0v
    all PL: 0v
    Main Capacitors: 168v
    C7912: fluctuating 14.95 to 16v
    R7972: Same as PD 1-4
    Re: Sharp LC-40LE810UN Dead
    So AC_DET is 0V? It should be around 3V if the incoming AC and the detector circuit is OK.
    BTW, this should be in the TV section.
    • alfredomfr1
      • Oct 2014
      • 318
      • usa
      and PD-11: 5v, sorry I don't know how to move to the TV section
        You report PD-11 which is 5VSTBY, but how about the AC_DET pin of the PD connector? It should not be 0V.
        Since you are not even getting the blinking code, I suspect there is problem with the main board.
        You need to provide the pictures of the whole back side of the TV showing all the boards.
        BTW, the 5Vstby and the 13V are generated by the same transformer so is the 5VSTBY really that steady?
        What happen if you run the power supply board by itself then report the Voltages?
        Make sure to put down pin name and follow by the Voltage reading for each pin which will make it so much easier without looking at the picture then looking at your pin number.
        • yohnsee
          Semi-noob
          • Dec 2017
          • 198
          • Hungary
          Referring to your picture:
          SG7006 is a spark gap, you don't need to worry about it.
          As the secondary 13V fluctuates, is the voltage on the main filter caps steady? Does it do the same when you disconnect the main?
          Edit: maybe the PFC tries to start, but can not for whatever reason.
          Cheers, Janos
          • yohnsee
            Semi-noob
            • Dec 2017
            • 198
            • Hungary
            Maybe this helps, today I do not have any brainpower left to check it, but you can look it trough, if it is more or less the same as your board.
            (I would say yes)
            Cheers, Janos
            • alfredomfr1
              • Oct 2014
              • 318
              • usa
              This is an update
              PD-1-2 UR13.2V (signal): Fluctuating 0 to 13v and again 0 to 13v
              PD-3-4 UR13.2V (Audio): Fluctuating 0 to 13v and again 0 to 13v
              PD-5-6 SGND (signal)
              PD-7-8 SGND (audio)
              PD-9 AC-DET: 0v
              PD-10 PS-ON: Fluctuating 0 to 3v and again 0 to 3v
              PD-11 BU5V: 4.99v to 5v not variation
              PD-12 PNL-POW: Fluctuating 0.06v to 0.75v and again 0.06 to 0.75v
              • alfredomfr1
                • Oct 2014
                • 318
                • usa
                Pictures Update
                • alfredomfr1
                  • Oct 2014
                  • 318
                  • usa
                  yohnsee, main filter voltage steady with Main Board connected or disconnected.
                  No 13v with Main Board disconnected
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4461
                    • Italy - Milan
                    This board have often the same two problems, first of all feed the psu separately and switch it all on with a pull up on the ps-on pin, now check voltages, if you have no ac-det signal high but the 5v and the 13v then change the optocoupler 7730 then retry, if this time you have ac-det then redo the same test but this time after checking the 13v pull high the pnl_pow then check the 4 pin connector that feeds the tcon, if you have no 12v then change the 4 pins KIA regulator under heatsink.
                      OK, so you do have fluctuating PS-ON, not 0 Volt as you reported in post #1, that is why the switched 13V is fluctuating.
                      • alfredomfr1
                        • Oct 2014
                        • 318
                        • usa
                        budm: Yes, my mistake
                        Davi.p: How can I test the psu separately?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4461
                          • Italy - Milan
                          What do you think i have said in post #10?
                          • sda
                            • May 2015
                            • 11
                            • Greece
                            Thank you.
                            Only 5V stby on main - no AC-det voltage
                            Faulty o/p (7703)
                            Cheers
                            • Cemal Odabasioglu
                              MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                              by Cemal Odabasioglu
                              I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                              Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                              Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                              Observations...
                              01-14-2025, 03:54 PM
                            • borstar_micke
                              Dead Sharp Aquos LC-32LE430E
                              by borstar_micke
                              My 12y old daughters tv (that she got after her grandpa, has sentimental value to her) was just dead without stby light a couple of weeks ago.
                              I´ve repaired a couple of computer monitors, classic blown capacitor replacements, a 55" Sammy led with t-connboard replacement and a 42" Panasonic edge led where I replaced the led-strip.
                              Not a master with the multimeter, which is cheap and 10-15year old btw...
                              So please make it basic...
                              To the issue at hand.
                              As stated, the tv is totally dead with no standby light....
                              03-23-2023, 09:14 AM
                            • metropical
                              Sharp lc32d42u seems dead
                              by metropical
                              plugged in after being off for quite some time. No OPC lights. Tried flashlight test for backlight check, nada.
                              Pulled the PS and checked all diodes including the 5w(?) D7908 that was the issue last time. All diodes check OK in circuit with DVM diode test.
                              No caps look unhappy. It is 17 years old. Was gonna fix and give to my brother.
                              But is there anything else to try or is it likely met its match.?...
                              09-28-2024, 05:41 PM
                            • Judderman69
                              Sharp LC-40FG2241KF dead
                              by Judderman69
                              Hello and greetings from the United Kingdom, I'm looking for some help in repairing my grand daughters 'dead' Sharp LC-40FG2241KF smart tv. I have replaced the following damaged parts on the main PCB (TP.MS6486.PB711) :- fuse FB1, switch mode chip UB101, MOSFET QB101,capacitor CB116, resistor RB106, RB148 and a track from UB101 pin 6 to QB102.
                              Unfortunately resistors RB105 and RB108 are also open circuit and because of their size (0201) I don't know their value. Could some kind soul please tell me or point me toward a schematic with a parts list, a very big ask but for this I would...
                              02-02-2022, 11:29 AM
                            • double_DD
                              How can I be sure that my EC chip is dead?
                              by double_DD
                              As the title suggests, how can I be sure that my EC chip is really dead?
                              I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                              Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                              03-12-2025, 07:47 AM
