Samsung UN55KS800DF
  • Jtroutt19
    • Aug 2011
    • 164
    Samsung UN55KS800DF
    Hey guys this unit power cycles with no image but backlight does come on and then shut off. Unplugging the cable in the picture makes the backlight stay on but no response other than that from it. I am assuming main board is faulty wanted to double check before I spent money. Thanks!!
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8327
    Re: Samsung UN55KS800DF
    Main board trouble indeed! One more test. Put all the boards back into the TV and disconnect the WiFi module and power the TV on. Another thing you can try is to freeze the EEProm on the main board with a can of air upsidedown and see what happens.
    • William1967
      • Nov 2017
      • 215
      • Netherlands
      Know error with these sets.
      Possible culprits are mainboard (- in combination with the one connect box ) or display.
      This set does the same when the FCC cables are disconnected so there is no need to try that. We saw several of these where the mainboard and one connect box were defect, some even have a defect mainboard in combination with the display.
      • Jtroutt19
        • Aug 2011
        • 164
        Ok purchased new main board. Now I'm getting a display but it's showing up like this?
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8327
          does the OSD work?
          • Jtroutt19
            • Aug 2011
            • 164
            no the OSD does not work.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8327
              Can you borrow and oscilloscope? Probe the LVDS cable between the main and Tcon, while flicking the menu on and off. If you see a difference on the oscilloscope while flicking the menu on and off, your next stop is the Tcon. Measure around the Tcon for voltages.
              • Jtroutt19
                • Aug 2011
                • 164
                Borrowing an O-scope is prolly gonna be a problem. Not sure I know of anyone with one. I will ask around.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8327
                  maybe proceed to check on voltages on the Tcon
                  • Jtroutt19
                    • Aug 2011
                    • 164
                    So this doesn't have the normal tcon board.
                      It has integrated T-CON into the LCD panel tab bonding board.
                      • realdealthill
                        • Nov 2016
                        • 53
                        Im having the same exact problem, with the same exact model...
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8327
                          ouch! that sux... I hate TV's like that...
                          • William1967
                            • Nov 2017
                            • 215
                            • Netherlands
                            Are the BN94-xxxxxX numbers the same on both mainboards?
                            • RAMartens
                              • May 2016
                              • 2
                              I have same model. Tried 2 sets of P.S. & Main. Board #s match. Ver. # match. Same symptoms. Why do back light stay on ( no dark areas ) with #20 plug disconnected from main if display can be the problem? Shouldn't set light up w/o one connect attached? Is it excessive draw by back light causing cycling? Thanks.
                              • realdealthill
                                • Nov 2016
                                • 53
                                I Ordered complete set of boards from SJ for about 90.00,got them in yesterday.Swapped them all out.. Tv works perfect now. Cant beat it for only 90.00!
                                  09-07-2024, 05:50 AM
                                • Asraf Atb
                                  Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                  by Asraf Atb
                                  Hi everyone,
                                  Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                  Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                  I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                  01-27-2025, 05:02 PM
                                • JSin21
                                  Compatibility of main boards between different variations of samsung MU6100
                                  by JSin21
                                  Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                  I have Samsung Smart TV UA65MU6100WXXY version DA01
                                  Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                  11-27-2023, 04:54 AM
                                • stylishconsultant
                                  un60j620dafxza - Samsung No Display Problem
                                  by stylishconsultant
                                  Hi All,
                                  Need help.
                                  I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                  So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                  problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                  might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                  09-04-2024, 03:26 AM
                                • Yanleb
                                  Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                                  by Yanleb
                                  Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                                  If they are not compatible why did Samsung give them the same part number to begin with?
                                  08-04-2025, 11:35 PM
