I have this KB Power Supply 120-12-8 here on my bench for repair.
Complaint: Had a transceiver hooked up to it and it will hum on transmit.
So, plugged that PSU in, hooked up a different radio I have kicking around, turn it on and I already hear a 120hz buzz. Tried to TX and the radio resets as soon as I press PTT. Hmm, O.k. so I hooked up my scope to see how bad the output capacitor actually is. Here is the kicker, there was a whopping 6.92 VAC on it!
Question is: How bad can a Mallory CGS 12000 uF 25V, screw in terminal cap go? Let's see: How about down to 495.5 nF with an ESR of 2.8kOhms!
The repair:
Total recap of everything. The regulator board has two axial capacitors 40V 470uF and a small 16V 33uF cap. Then the PSU had a regulating problem and the output voltage wasn't stable. The 2N3771 pass transistor was fine. After a while the SCR would fire and roast that long 1R0 resistor. Lucky me I was there when that resistor started smoking and turned the power off, other than that there would be a few more broken components. Checked the components and all was good, so I did a reflow with plenty flux on the whole back side of that board.
Problem fixed. That ole thing is older than I am. Now it's probably good for another 40 years and I don't have to worry about it anymore.
The repair:
