Bios Dump BA41-02206A PIOTEK
  • cellphoneyeta
    ShortedboardGSM
    • Oct 2015
    • 49
    • philippines
    Hi guys anyone has bios dump for Samsung NP300E4E
    board id: BA41-02206A PIOTEK
    Thanks in advance
    • 20807
    Re: Bios Dump BA41-02206A PIOTEK
    Backup your bios, try this one .
    EDIT: this bios is P07RBD
    • cellphoneyeta
      ShortedboardGSM
      • Oct 2015
      • 49
      • philippines
      ok i will try... i will post the result
      • cellphoneyeta
        ShortedboardGSM
        • Oct 2015
        • 49
        • philippines
        no luck sir... still no display
          • 20807
          OK , try this one with cleaned ME ,latest firmware.
          P07RBD
          • cellphoneyeta
            ShortedboardGSM
            • Oct 2015
            • 49
            • philippines
            thanks.. i will try and post the result...
            • sainigolu935
              • Aug 2018
              • 1
              • india
              thanks sir
              • punkrockpax
                • Feb 2019
                • 23
                • Mexico
                Originally posted by JOSE82
                hola cellphoneyeta
                disculpa...(con qué y cómo programaste me podrías apoyar?
                EZP2013 CH2013B
                You have to desolder the eeprom and put it in the programmer, I suggest you make a backup of your original bios just in case, greetings!
                • quinojuan
                  • May 2019
                  • 1
                  • Argentina
                  Thanks from Argentina.
                  • inter_cyber
                    • May 2014
                    • 8
                    • turkey
                    Thank's from Turkiye
                    • nassimhamdi
                      • Feb 2016
                      • 150
                      • algeria
                      thank you i will try
                      • boskorp
                        • Sep 2019
                        • 8
                        • Bulgaria
                        P07RBD
                        Works fine on Samsung NP300E5V-A01BG same board BA41-02206A
                        Screen back on.
                        • Marcelo De Villa
                          • Mar 2020
                          • 1
                          • Philippines
                          Thank you
                          • essamali
                            • Feb 2012
                            • 9
                            working very well thank you great job
                            • renars777
                              • Apr 2018
                              • 1
                              • Kazakhstan
                              Thank's from Kazakhstan!
                              • rascao
                                • Jul 2020
                                • 51
                                • España
                                thanks the clear ME works really good for the reboot loop on this samsung
                                • M Anis
                                  • Mar 2021
                                  • 1
                                  • Indonesia
                                  thank's from Indonesia
                                  • brixlaptoprepair
                                    • Mar 2016
                                    • 15
                                    • canada
                                    thanks its work 100 percent...
                                    • Andyservo
                                      • Jun 2013
                                      • 152
                                      • Indonesia
                                      P07RBD
                                      Thanks @SMDFlea, the Bios is working...
                                      • YMK
                                        • Mar 2020
                                        • 13
                                        • Tajikistan
                                        P07RBD
                                        thanks bro
                                        • Habble7
                                          I need a BIOS dump for the Samsung S49CG934SU monitor
                                          by Habble7
                                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                          Suspected Cause:
                                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • DynaxSC
                                          MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                                          by DynaxSC
                                          Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                                          I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                                          11-17-2023, 10:56 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          07-28-2025, 07:11 AM
                                        • grimacelord
                                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                          by grimacelord
                                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                          Motherboard model number: DA0PAMB46A1 REV: A
                                          Secondary motherboard model number: 0PAB
                                          SKU: 685K4UA
                                          Serial number is: 5CD3223BJP
                                          Recently reflashed this laptop with latest BIOS and once...
                                          05-07-2024, 08:06 AM
                                        • DynaxSC
                                          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                          by DynaxSC
                                          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                          11-06-2022, 05:22 PM
