HP Probook 440 G4 Working BIOS
  • subroto
    • Oct 2015
    • 230
    • Bangladesh
    DA0X81MB6E0 REV. E
    Working BIOS.
    Enjoy......
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP Probook 440 G4 Working BIOS
    Thanks bro
    • String2016
      • Nov 2015
      • 2234
      • philippines
      thanks for sharing
      • Pascal Komlassan
        • Jan 2017
        • 806
        • TOGO
        Nice job thanks
        • sourcebf
          • Jul 2016
          • 431
          • N/A
          thanks a lot
          • fyaagoub
            • Dec 2016
            • 269
            • maroc
            thanks for sharing
            • nimmay
              • Dec 2015
              • 82
              • Pakistan
              thx subroto & the all badcaps members for the bios upload,
              bro i update bios & bios is working fine
              1 issue is that display is delay approx 20 sec minimum
              kindly give me solution for this error.
              i have previous 440 G4 with bios password ?
              thanks overall and waiting for the solution.
                • 20793
                The delay is because the ME (management engine) area of the bios is "dirty" .The ME firmware needs replacing in your bios, here`s the guide that everyone uses to clean (replace ME firmware) in the bios:
                https://winraid.level1techs.com/t/gu...lization/31277
                Its always best to post your original bios backup when asking for help,if you want a password removing or the ME area cleaning, if you can`t do it yourself .
                EDIT: Have you shared anything yet with this community .
                • nimmay
                  • Dec 2015
                  • 82
                  • Pakistan
                  SMDFlea ...
                  thanks for the help bro really appriciated.
                  bro i am uploading old bios which has password on bios ,
                  kindly clean it if you can...
                  waiting bro
                  • imranromi
                    • Jan 2015
                    • 1288
                    • Pakistan
                    Hello @SMDFlea same problem for me this bios file Hp 440 g4 i try all clean me work but when show display logo restart and restart in bios setup work 100% clean me problem or more other guys have checking fast display plz share thanks
                    Mistake rename file.File is 440 g4
                      • 20793
                      Your bios has corporate ME firmware,it should have had consumer FW. Try this bios
                      • imranromi
                        • Jan 2015
                        • 1288
                        • Pakistan
                        Thank you Friend you file work for me but 1 more problem new bios.Old late display file detect Nvidia Graphic card in Device manager this new file not detect Nvidia card when i check again old bios also show nvidia possible detect if use other clean me file..
                          • 20793
                          Ok, try this bios .
                          • imranromi
                            • Jan 2015
                            • 1288
                            • Pakistan
                            Ok, try this bios .
                            No work this file also late display 30sec after display
                              • 20793
                              what motherboard revision do you have X81-MB-D, rev E ?
                              • biospwd
                                Banned
                                • Oct 2019
                                • 51
                                • Ireland
                                Check this, should works.
                                • imranromi
                                  • Jan 2015
                                  • 1288
                                  • Pakistan
                                  Rev:E
                                    • 20793
                                    Try again with FITC.The ME firmware isn`t clean.
                                    "Warning: The ME FW image loaded has been pulled from a previously booted system. Some FW settings will not be allowed to be changed."
                                      • 20793
                                      Rev:E
                                      The rev E is UMA i think ? https://www.ebay.com/itm/905796-001-...id=24033761851
                                      • imranromi
                                        • Jan 2015
                                        • 1288
                                        • Pakistan
                                        Sorry i will check again what is correct Rev or Rev:E
                                        • markobi
                                          HP Probook x360 11 G6 EE working bios is needed
                                          by markobi
                                          Hello everyone. I have this probook x360 11 G6 ALOE20 6050A3113201-MB-A01(A1). It has computrace and I need a working bios to get it working back to normal. I can really lay my hand on any bios file yet. My original bios file is also attached. Thanks in advance....
                                          09-02-2023, 02:38 AM
                                        • zPwN!
                                          ENOVA NE14I310 XU133t rev 1.3 working BIOS
                                          by zPwN!
                                          Corrupted BIOS (no WIFI, graphics drivers crashing, USB port reset request failed, etc)
                                          Working BIOS (taken from 15.0.41.2158_CON_LP_B_PRD_EXTR_AB7F54AC but I fixed some FLEX I/O for sata ssd and GPIO VCCIO config for this model)
                                          System SKU NE14I310
                                          BIOS Version APD-BI-14-XU133TR130-TA60F-143-E ?
                                          Motherboard XU133T rev 1.3
                                          Serial Number IPNBI3X240SM2A01095
                                          Processor 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz 3.00 GHz
                                          RAM 8.00 GB
                                          NOTE: I'm new repairing and not sure if this is everything that needed to be configured, but the BIOS...
                                          01-03-2025, 01:03 AM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Sparklingx
                                          CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
                                          by Sparklingx
                                          So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
                                          So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
                                          now all...
                                          08-29-2024, 01:53 PM
