HP DAG74AMB8D0 Rev D bios needed
  • String2016
    • Nov 2015
    • 2242
    • philippines
    Hi everyone!I need a working bios for this model HP 15-CC002NX BOARD CODEag74amb8d0 REV.Can anyone share a working dump for this model please
  • String2016
    • Nov 2015
    • 2242
    • philippines
    Re: HP 15-CC002NX bios needed
    anyone can share a working dump for this model please
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Hp official bios-3 types of bios in this model. One will definitely work if its bios issue. Enjoy.
      PS: Instead of asking for bios you should download on your own from hp site and just run setup and choose copy option.
      • String2016
        • Nov 2015
        • 2242
        • philippines
        Ok thank you ill try this
        • String2016
          • Nov 2015
          • 2242
          • philippines
          I flashed the bios with above uploaded from hp site the third one which my bid 08361,at first turns on and display comes with flash block complete then shuts off and turns on again with power button light blinking.I have uploaded the original dump, can someone fix this please
          • String2016
            • Nov 2015
            • 2242
            • philippines
            update i replaced the chip and flash it again with above bios now its working fine thank you
            • String2016
              • Nov 2015
              • 2242
              • philippines
              now i have a problem i cannot edit the ct board id and product id on the board.I have already used NBDMIFIT 2.10 but when i boot on flash drive once i typed NBDMIFIT, first i entered current date but after entered it says this utility cannot be used in this platform try other version utility can anyone please help
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                try this
                Im Back... sort of...
                • String2016
                  • Nov 2015
                  • 2242
                  • philippines
                  Thank you i will try this
                  • String2016
                    • Nov 2015
                    • 2242
                    • philippines
                    alaborbe tried your bios not working capslock blinking
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      make a dos bootable pen drive and use bq185.exe i have given you. It works on almost all hp15 motherboard. You can easily fill dmi info . Try with this tool, else post your non working bios.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Try this
                        • String2016
                          • Nov 2015
                          • 2242
                          • philippines
                          thanks but still the same issue i flashed caps lock blinking no display
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Better you use hpbq185.exe dmi fix tool.
                            • String2016
                              • Nov 2015
                              • 2242
                              • philippines
                              now the problem is the chip cannot finish veryfying on the programmer, so i replaced the chip and flashed with the bios from hp site but same issue capslock blinks 5 times then on the 6th blinks it blinks continously
                              • String2016
                                • Nov 2015
                                • 2242
                                • philippines
                                anyone please help on this when i change the chip and flashed it again with the bios from hp site that is working before but now caps lock blinks 5 times then on the 6 times it blinks 3fast blink and so on .
                                • String2016
                                  • Nov 2015
                                  • 2242
                                  • philippines
                                  anyone please help
                                  • String2016
                                    • Nov 2015
                                    • 2242
                                    • philippines
                                    anyone please help
                                    • meritosari
                                      • Oct 2010
                                      • 774
                                      • Indonesia
                                      - Maybe you need to programming the KBC chip also.
                                      - Check around bios chips, if any resistor was out of direction, missing, etc.
                                      • String2016
                                        • Nov 2015
                                        • 2242
                                        • philippines
                                        thanks for the response meritosari i checked already around bios chip there is no resistor moved.maybe it is the kbc. but the blinks from the caps lock is not redlight its white
