WFCO Camper Converter need help understanding KA3846 SMPS Controller
  • Shane711
    • Dec 2014
    • 493
    I have this WFCO Camper converter. You plug it into 120v and it puts out 12v 55 amp. After replacing all the bad parts the unit does not work, output voltage is 0.00 volts. There is 2 white ceramic resistors that put out a lot of heat and they burn up all the parts around them. So the main parts to burn up are the capacitors. When I just change out the caps to unit works but the KA3846
    SMPS Controller sometimes goes bad and that has to be changed. When I change out the KA3846 the unit does not work anymore.
    I read on the datasheet that the KA3846 can go into shutdown state. The question how to get it to turn back on?
    Here is the datasheet
    http://pdf1.alldatasheet.com/datashe...LD/KA3846.html
  • Shane711
    • Dec 2014
    • 493
    Re: WFCO Camper Converter need help understanding KA3846 SMPS Controller
    I will have to remove the small daughter board later and take more pictures.
    • Shane711
      • Dec 2014
      • 493
      Here are some pictures. This is the daughter board. It has a PIC 12F675 IC. My next step is to remove the IC and see if I can copy the program.
      But in the mean time I have to figure out why this board is not putting out power. I will have to recheck all the caps. The PIC 12F675 may have the unit in shutdown mode for some reason. When I repairs these if I just change the caps it works but if I change out the KA3846 SMPS Controller then the circuit stops working and I can not get it to turn back on. I am confused about this and I need help.
      • Shane711
        • Dec 2014
        • 493
        I got this information off this website but I don't understand it enough to try it.
        http://www.rv.net/forum/index.cfm/fu...print/true.cfm
        I believe this is referring to the PIC 12F675 IC
        Pin 1 is Vdd, +5
        pin 8 is Vss, 0 volts to converter output
        Pin 7 is the divided converter output
        Pin 4 is reset, normally ~4.27 volts
        Pin 2 is the voltage control output, ~2.28 volts for 13.6 volts out, ~0 volts for boost
        If you go to that link above and read it maybe you can understand it better than me.
        • Shane711
          • Dec 2014
          • 493
          So today I figured out there was a bad connection on the KA3846 SMPS Controller and I fixed 1 unit so far. I have 2 more of these that I will be fixing in the next few days. If anyone needs help fixing theirs I can help. Looks like I understand these boards at least 90%. As time goes on I should become an expert on these. So far I have been able to fix everyone except for 1. The 1 I could not fix has a burnt out transformer and I could not but a new one; the person that had it reversed the polarity on his battery.
          I have fixed 15 so far and I have 6 more on my bench to be fixed.
          • shadetreetrader11
            • Oct 2015
            • 230
            Shane711 I'm working on the same power supply. Do you happen to know the value of c18? It's on the main board in between the 2 large red resistors.
            • Shane711
              • Dec 2014
              • 493
              There are a few different models, can you provide a picture of the circuit board and I should be able to tell you the value.
              • shadetreetrader11
                • Oct 2015
                • 230
                Tell me if you need more pics. C18 is the cap in the top picture in between the two red resistors.
                • shadetreetrader11
                  • Oct 2015
                  • 230
                  Model WF-9865 65 Amps
                  • Shane711
                    • Dec 2014
                    • 493
                    Sorry it took a while. 471K 1KV
                    • PeteS in CA
                      • Aug 2005
                      • 3583
                      • USA, Unsure of Planet
                      470 pF, 10%, 1 KV. The "K" means 10% tolerance; "M" would have meant 20% and "J" would have meant 5%.
                      PeteS in CA
                      • shadetreetrader11
                        • Oct 2015
                        • 230
                        So after a little more investigation I found that almost all of the caps on the control board were shot. The majority of them were open. I replaced them and it started working again. Thanks for the help guys.
                        • Shane711
                          • Dec 2014
                          • 493
                          The reason the caps go bad is because they are too close to the (Rectangle white resistors), Too close to the heat. So you have to protect them from the heat. I move the caps to the underside of the board.
                          • PeteS in CA
                            • Aug 2005
                            • 3583
                            Unless you're talking about vacuum tubes, heat is pretty much never your friend in electronics. Travelling Wave Tubes are used in microwave power electronics, so not all vacuum tubes are dinosaurian relics or for golden-eared audiophile-devotees.
                            PeteS in CA
                            • Versus78
                              • Aug 2019
                              • 4
                              Good day Shane,
                              I found your post while searching about KA3846 ICs on Google. I am also working on a 12V converter for my RV, but the brand is Parrallax Powersupply instead of WFCO. But according to the pictures your posted, it seems to be somewhat similar in design. Mine is also rated 12V/55 Amps. It also use the KA3846 IC and lots of parts seems identical.
                              I was wondering if you could give me some advice as mine is not working properly.
                              When running without load, I have a clean 13.8V DC output. As soon as I am putting a load on it (a 20w bulb), the systems seems to go in shutdown. I can hear a high-pitched switching sound, and voltage drops to a mere 1VDC.
                              I was able to troubleshoot using variable loadbank from work, and if I increase the load from 0 to 15 amp very smoothly, the converter was able to supply the 12V @ 15 amp for brief periods of time, before going to 1VDC again. I am assuming that the power components are still functioning properly and that the system goes in shutdown for an unknown reason...
                              Nothing seems to be overheating on the board, except for 2x big 1k resistors but it seems normal as they are rated 10watts
                              I am checked the big capacitors (the 2 big 200V filtering capacitors, and the output capatitor) with a ESR meter from work and they seem fine (they are within their specified tolerances).
                              1. Are those IC prone to failure, and do you think the 3846 is in cause?
                              2. What are the main issues you are facing with your WFCO?
                              I will try to upload pictures of my Parralax Converter..
                              Any help would be appreciated!!
                              • Versus78
                                • Aug 2019
                                • 4
                                UPDATE!
                                I found the problem. I took a chance by replacing a small 220uF capacitor that was a bit too close to the big ceramic resistor... It seem that that capacitor was part of the KA3846 circuit and I assume the electrolyles dried up from the heat of those resistors. Although they didn't have any apparent damage...
                                It seems to be working fine now!
                                I just saved 200$
                                • Shane711
                                  • Dec 2014
                                  • 493
                                  You should move that capacitor to the underside of the board to prevent the heat from burning it up again.
                                  • Versus78
                                    • Aug 2019
                                    • 4
                                    I would need to modify a lot of hardware to to so because the board sits on a tray and there isn't clearance underneath... There was a 220uF 30V and I put a 50v instead. The can is a little bigger so I guess it might be easier to dissipate heat from the resistors.. I think I'll try to fit heatsinks of the resistors too.. if I'm lucky it will last another 10 years
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8706
                                      Can't relocate the capacitor? Relocate the resistors
                                      • rialcsiobc
                                        • Oct 2020
                                        • 1
                                        Hi Shane711
                                        I have a WFCO -9875. When off load I can adjust to 13.60 volts (with Vr1). As soon as I put a battery the voltage drop to the battery level. If I leave it connected it it will charge the battery very slowly over many days then stabilize at 13.2v. When in my trailer the voltage keeps on reducing to the point that the fridge doesn't work anymore. Do you know which IC controls the amperage and voltage output ? Is this the mini controller or the KA3846. I have a new 9875 but would like to fix this one.
                                        Claude,
                                        • Shane711
                                          by Shane711
                                          I read on the datasheet that the KA3846 can go into shutdown state....
                                          10-23-2017, 04:14 PM
                                        • tonytiger
                                          wfco power converter 8855 in camper
                                          by tonytiger
                                          hi,im trying to fix my converter unit that has no 12vdc or 120vac
                                          when i plug 120vac on it directly,there is no 12vdc coming out and vise vesa....
                                          now i check most all fuses,resistors,capacitors,ect... the thing i notice i have no voltage on my 2 big capacitors on the 120vac....there is no diagram for this board on net that i could find.all help or info would be appreciated....
                                          05-08-2019, 10:29 AM
                                        • dkneyle
                                          Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                                          by dkneyle
                                          This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                                          Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                                          02-01-2022, 02:08 AM
                                        • shamsudeen
                                          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                          by shamsudeen
                                          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                          i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                          07-19-2025, 07:14 AM
                                          MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
                                          The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
                                          Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
                                          10-23-2024, 03:23 AM
