I'm working on a recap for a HannsG HG281D monitor with a Phihong PSM-217-404-H-R rev. A1 power supply.
There are quite a few threads on this monitor at badcaps, and I've read through all of them, but have a few questions related to my particular situation.
The monitor worked fine until about a year ago. I usually would power off the monitor completely when not using it (I don't trust the plug-an-play stuff to not fry the HDMI port on my laptop), and it would not turn back on without a couple of power button presses. Once powered up into standby mode (orange LED color) it would go into normal operation (blue LED color) just fine and not have any issues during use. Getting the monitor initially powered on started to become a bit of a chore, so I started leaving it in standby mode and doing the plug-and-play thing. As long as I didn't accidentally flip the switch on the surge protector, I would be fine. Then it started to turn itself off completely while sitting in standby mode after a week or so; getting it turned back on would be quite time consuming, though sometimes it would just kick itself back on (this monitor seems to revert back to its last state after power failures). Getting the power back on became harder and harder, and now I have not been able to get this thing powered on since the last time it turned off.
From my reading about the HG281D in other threads, it appears this is likely a power supply issue, in particular, a startup capacitor problem (as mentioned here https://www.badcaps.net/forum/showpo...2&postcount=34) does that sound about right to you guys?
Which exactly are the startup caps on this board?
Sounds like the C603, 606 and 707 are also problematic, so I was planning on recapping the entire board (except for C3). I'm wondering if film capacitors would work for the 100V and 50V capacitors or would the ESR be too low? I'd like to understand which places on the power supply board are important to get low ESR, where some ESR may be necessary, and where GP caps are OK.
According to this picture linked from another thread http://www.directupload.net/file/u/4...fvxoqk_jpg.htm the primary is everything to the left of the transformers in the middle, the secondary is everything to the right. This follows a white silkscreen line printed on the back of the PCB. However there is a low ESR cap (C108) on the primary and a GP cap (C707) on the secondary - are those just bad choices? Where is the PFC on this board?
I've attached pics of my particular PSU, also an annotated pic with the cap PCB number + specs to help identify all of the caps.
Also, that picture linked above is a nice reference (it's of the rev. A2 board, all capacitor values are the same).
PCB # / brand series breakdown is as follows:
C203 C114 are Jamicon TK series (general purpose) https://cdn.badcaps-static.com/pdfs/...0a384e50a9.pdf
C205 C606 are Taicon VT series (general purpose) https://cdn.badcaps-static.com/pdfs/...6f416a420a.pdf
C601 Ltec TH series https://cdn.badcaps-static.com/pdfs/...710cf29b67.pdf
C603 C707 C111 Ltec TK series (general purpose) https://cdn.badcaps-static.com/pdfs/...eff471caef.pdf
C108 Ltec LZG series (low ESR) https://cdn.badcaps-static.com/pdfs/...3154c18b5e.pdf
C3 Nippon Chemi-Con CLA https://cdn.badcaps-static.com/pdfs/...41a221bc5e.pdf
Everything else is Nippon Chemi-Con KY (low ESR)
I also plan to replace the DC filter caps on the logic board
https://www.badcaps.net/forum/showth...ghlight=HG281D
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
