Oster wine celler cooler Mod OW0912H6H fault
  • ivtec
    • Dec 2008
    • 1967
    Hi guys; i have this Oster wine celler OW0912H6H that has been working for a few years and this weak it failed ,i smelled burn,i opened it and checked circuit ,visual don't see anything burned,is there any thing that i could check on this board thanks?
    http://www.fixya.com/fullimage.html?...1_11_16_pm.jpg
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Oster wine celler cooler Mod OW0912H6H fault
    What about the underside ?
    • ivtec
      • Dec 2008
      • 1967
      Thanks Diif; i also checked D83-004 and my measurements were= black probe midle pin and red on left pin and right pin i get 0.117 on diode tester,Is this right?
      http://www.datasheetq.com/D83-004-doc-Fuji
      • c5gary2
        • Dec 2015
        • 8
        Your measurements look correct. What about reversing the leads?
        BUT, take a look at this thread:
        https://www.badcaps.net/forum/showthread.php?t=42346
        It looks like you are working on a very similar wine fridge.
        I finally was able to fix mine (actually 3 of mine).
        The problem was the VDD 47ufd cap on pin 12 of the tl494 (16pin dip device). It had gone to 33ohms ESR. This caused faulty startup operation which also took out one fo the small TO-92 transistors.
        Gary
        • c5gary2
          • Dec 2015
          • 8
          Looking at your photo again, I see why you zeroed in on the dual diode...
          It isn't even attached to the heatsink!
          If that is so, that isn't good, my heatsink gets really hot.
          But, your readings look good and it did work for years...
          Can you identify where the smell came from?
          Use your meter diode function to test the small transistors, they should measure the same.
          One of mine was shorted (zero ohms). But it didn't look burned, nothing did.
          Gary
            • 31246
            fuck me, that's bad.
            i imagine the heatsink on the left would do a nice job IF THE FUCKING PART WAS ACTUALLY ATTACHED TO IT!!!
            • ivtec
              • Dec 2008
              • 1967
              Thanks guys; I know the heat sink is not attached i did take out the screw,measurements were made with the Diode in place, if you say that the measurements i made are good then the diode is good ,as so the other 2 diodes on the other heat sink and all small transistors,and Caps, this cooler has a few years i already had repaired it once,i guess it's time to get a new one,thanks anyway.
              • c5gary2
                • Dec 2015
                • 8
                ivtec,
                I wouldn't give up yet!
                You can check the big dual diode in reverse mode, put the red probe in the middle, readings should be high.. if so it is good, reattach it.
                What are the symtoms? Nothing works? Fans, LEDs work? Disconnect the big wires to the Peltier device and see if the fans work.
                What were the measurements on the two small transistors? BTW, the devices on the the other heatsink are transistors, not diodes.. however they would test the same with your meter.
                It sounds like you have the same condition as I had, couldn't find anything blown!
                But in the end, it WAS a bad cap was all that was wrong on one of my boards!!
                If you can't/don't want to fix it, you may be able to just get a new power supply board.
                Try SearsPartsDirect... they still have replacements for my board.
                Gary
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  did you test the esr on the capacitors or just the uf readings is the primary side glass fuse ok? in the pictures one end looks black but could just be the picture
                  • ivtec
                    • Dec 2008
                    • 1967
                    Thanks vinceroger69; yes i tested all caps with my Cap-analyzer 88A,special those big caps and some of the small ones and all tested good ESR and capacity,all parts that can be tested seem to be ok, besides i don't want to spend money on parts,if i was certain that this or that part would solve the fault, i would go for it but a wild goose chaise no time for that,it already had a badl LCD control panel that i couldn't reed temp reeding.
                    Today i went to a Flee Market here in my area and found an old HAIER Mdl HVUEB06-RBG
                    6 bottles cooler almost new for 20 bucks which runs great and for now i'm set ,no need to loose time on this electronic board,if i come across a cheap board i'l buy it if not trash it.
                    And for other people has same issue that want to know more about these wine cooler go here ;forum.allaboutcircuits.com/threads/repair-thermoelectric-cooler.101748/
                    Also here:
                    • c5gary2
                      • Dec 2015
                      • 8
                      Ok, very basic repair guide...
                      "If the voltage is within AC100-120V, then test the output voltage, if the voltage is not within DC12-13V, then it must be the problem of the PCB, change the PCB."
                      Just get a new power supply! Or like you, go to flea market and get a
                      new fridge..
                      Well, I agree with getting a new power supply rather than just blindly swapping all its parts, that's what I did the first two times.
                      BUT, it you can find the one or two bad parts, its better to actually repair the problem.
                      Thanks,
                      Gary
                      • edugimeno
                        Wine cooler flickers at startup and doesn't cool enough
                        by edugimeno
                        Hi there!
                        I have an old wine bottle cooler, it's a basic peltier cell system with a power supply built in with the controller board, with a simple display at the front door and 2 push buttons to select the desired temperatura.
                        Symptoms are it doesn't barely cool down, and makes a chirping noise at the board.
                        Both fans on each side of the peltier are (now, after much cleaning) running smooth and silent
                        When you turn it on, the front 7-segment display flickers for a variable time, usually like 1 minute but sometimes nothing or 3 minutes... Then turn on solid (but still some...
                        03-01-2025, 04:51 AM
                      • KYBOSH
                        Wine and Beverage Cooler Control Board Repair Attempt
                        by KYBOSH
                        Trying to a fancy Wine and Can Beverage Cooler which wasnt working.
                        Model number AWBC242GGFD
                        Previous owner states that it needs a new motor.
                        When plugged up you hear a quick chime from the PCB alarm but it quickly dies away (trails off actually) and there is no sign of life from the unit at all.
                        I pulled out the main control board to give a look.
                        Fuses checked out okay. All diodes except one checked out. It was reading in both directions so I pulled it out of circuit and checked it again but this time it read good.
                        07-18-2024, 11:52 PM
                      • watergremlin0
                        Wine Cooler CD-110-B
                        by watergremlin0
                        Anyone have an experience with this board? Ive actaully replaced 2 caps on it before. Worked for a few years. However this time around they all seem good. Ive pulled a few and tested they all test in range. Checked a few of the diodes they all seem good. dont see any popped resistors or anything. The light and screen power on however the fans never kick on. Havent found a skematic for this board however my guess would be a component in line with the fan.
                        06-18-2024, 08:03 PM
                      • Rictech
                        Panasonic SA-MAX770PU SMPSU board fault....
                        by Rictech
                        Hello everyone. 😀
                        As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                        Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                        Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                        This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                        There are no devices that have exploded or otherwise show signs...
                        08-26-2024, 01:05 AM
                      • howardc64
                        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                        by howardc64
                        • Prior owner tried a replacement main board. No difference.
                        • Samsung 2x red blinking standby LED = panel fault
                        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                        07-19-2025, 10:54 PM
