Hello.
Well, I've gotten a bit used to my new 25mhz Owon scope. For low-frequency stuff, it's great. Now I hook it up to ATX Power Supplies and..... UH OH.
Great big gnarly spikes all over the place, even on the ground wires. Even with the little ground clip attached to the particular ground wire being tested. Multiple volts of P2P!
Worse, the amount of ripple voltage varies with the volts per division setting, indicating that the ripple/spikes don't originate with the circuit being tested.
Oddly, a really cheap 6 year old pull from an upgrade that weighs about ONE pound came up relatively clean with no motherboard attached, but started spiking all over just like a new Antec EA380 when attached to a motherboard.
Obviously I'm doing something really, really wrong here. So, some reading about scopes, PSUs, probes "ringing" and testing procedures later.....
Oh! I needed to attach a 10uf and a .1uf cap together in parallel across the probe tip and ground. Ta Da! no more giant spikes all over. Thanks, JonnyG.
However..... I still have some questions.
Someone somewhere stated that adding the decoupling caps across the probe tip is meant to simulate the caps on the motherboard. The great big spikes are evident with the PSU connected to a motherboard! Both an old one and a brand new one with zero hours on it. Both with lots of great big caps way bigger than 10uf. Wouldn't this kinda sorta indicate that maybe something else is going on? Like great big gobs of electromagnetic interference that transcends any number of caps and goobers up my probe?
Someone else stated that a "Differential Probe" is meant to be used for ATX PSU testing, but that it isn't really that big of a difference. I noticed that Differential Probes are kinda expensive. So are Active Probes that are specially designed to get rid of the annoying ringing spiking thing that I might be suffering from. Does anyone have any experience with these?
My Decoupling Capacitors obviously alter the characteristics of the probe, rendering it inaccurate when testing against the 1khz/5v reference signal. Doesn't this make it useless for testing PSUs as well? Or am I meant to use just the caps on a bare cable without any probe? I'm going to test this out further. I suspect that the caps are meant to be a DIY probe, not to be added to a 1X-10X probe.
Oh well. My sig is more appropriate than ever!
Have Fun,
Keri
Have Fun,
Keri
