LG 55lv5500 bad picture no sound
  • dorp90
    • Mar 2017
    • 11
    I have an LG 55LV5500-UA.ausyljr that has a scrambled picture and no sound. From what I have read other places I'm thinking that I need to replace the main/logic board. Am I on the right track for this? I didn't see any capacitors that were swollen or anything like that.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LG 55lv5500 bad picture no sound
    No this model is known for faulty BGA connections on the mainboard. Take off the black heatsink off of the processor and heat up Ic 401 and 402. You can do this while the TV is on see if the picture straightens out.
    Tcon board is fine. It's just doing what is told
    • dorp90
      • Mar 2017
      • 11
      Just so I'm straight and do no further harm. When you say heat up Ic 401 & 402 are you talking about soldering them or just taking a heat gun at them? Thanks.
      • freakaftr8
        • Oct 2012
        • 3743
        Heat gun. What I do is at the TV standing straight up so you can view the screen hit these two Ics with a bit of heat and then as you're watching the screen see if it straightens out
        • freakaftr8
          • Oct 2012
          • 3743
          There is another ic hiding underneath that black heat sync. Try that one as well
          • dorp90
            • Mar 2017
            • 11
            Just finished hitting it with the heat gun and the picture is all clear. Thank you very much. Just curious, what is it about the heat that helps?
            • johnboy1313
              • Nov 2012
              • 1959
              There are very small solder connections that break over time. Heating these up, reflows the solder, restoring the connections.
              • freakaftr8
                • Oct 2012
                • 3743
                May not last long thou. This repair takes extensive time and the right amount of reflow. Let us know how long it lasts. Don't put this board in the oven! It doesn't fair well.
                • dorp90
                  • Mar 2017
                  • 11
                  I had jumped the gun a little bit with my first reply that it was fixed. After I put it back together I had the same issue. So, I took it apart again and did some more heat and it has been running for a couple days now with no problems.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4346
                    • Italy - Milan
                    Heating a bit wil never fix a BGA chip, you need a reflowing, if you don't know what it is search the forum..
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Even a reflow won't be a permanent repair. Reballing with leaded balls will be a much longer lasting fix.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Sometimes you get lucky. I have the 47 inch version of this TV same problem been working great for a year-and-a-half after the reflow
                        • Daisyann15
                          • Sep 2018
                          • 1
                          • United states
                          Hello! My LG 55lv5500 have no soud and dont recognize HDMI neither USB connection. Picture is fine. I remove the cover but looking main board Im not sure where to heat.
                          • tvtimmy
                            • Mar 2015
                            • 1160
                            • usa
                            Take the 4 push in spring loaded pins out of the big black heatsink. Then peel off the rubber pad if yours has one. Heat the chip with a heat gun on low for about 45 seconds. Watch a youtube video on reflow of bga chip to be sure of the time and temp to do it.
                            • TR103
                              by TR103
                              - it keeps rebooting
                              01-22-2025, 04:12 PM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • Ierwin
                              by Ierwin
                              05-13-2025, 03:31 PM
                            • jchang
                              Samsung UN70NU6900F no picture and no sound
                              by jchang
                              Hi all
                              I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                              Symptom:
                              No picture no sound.
                              When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                              No sound at all.
                              What I tried:
                              1. I tried unplugging the left or right ribbon...
                              01-09-2023, 06:28 PM
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
