Samsung BN44-00506A power board dead no standby
  • london-freddie
    • May 2015
    • 472
    Hi again all
    just been given for free a dead Samsung LT27B3000EW LED Tv, it was going to the skip
    Just wasted several hours of my life looking at the power board, but it is beyond me
    Power board is BN44-00506A
    No output voltages at all on any pins, no standby voltage or led
    I do have 338V at the big cap
    Anyone had any dealings with this board or any ideas where to start looking next
    Nothing appears visibly popped on this board
    thanks in advance
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: Samsung BN44-00506A power board dead no standby
    check fuses and fets
    • london-freddie
      • May 2015
      • 472
      pics of boards
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Post #11 may interest you.
        https://www.badcaps.net/forum/showthread.php?t=54437
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Is there a burn mark on this resistor or just a speck of dirt?
          • london-freddie
            • May 2015
            • 472
            thanks for that, re the resistor no burn mark, however looking even closer at this board I think it has had some work done on it in an attempt to fix it.
            some solder joints been done looks like the little blue cap CM804 next to that resistor has been changed out, also looks like CM801S has also been played with, me now thinking may be easier just to try and source another board
            • london-freddie
              • May 2015
              • 472
              just been looking at that post you pointed me towards, looks exact same problem as my board even down to same components, coincidence ???
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Checked the output diodes for SC ?
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  No, it's probably a standard failure for this board.
                  • london-freddie
                    • May 2015
                    • 472
                    Thanks for the help guys
                    Pretty sure this board has the same problem as Modrobert in the previous link
                    looks like STR-W6052S is shorted
                    CM804 blue ceramic looks to have been changed markings on cap are 47k 2kw not sure if this is the correct cap for the board
                    Diode DM801 is short when fitted, also checked this off board still short
                    Anyone know the correct blue ceramic that should be fitted
                    • london-freddie
                      • May 2015
                      • 472
                      Output diodes all seem to be ok
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        In the link I gave earlier
                        I have replaced IC STR-W6052S, ceramic cap [CM804] (0.22nF 1000V "221K 1KV") and the TV is working again.
                        • london-freddie
                          • May 2015
                          • 472
                          ok will get these parts ordered and give it a go, thanks
                          • london-freddie
                            • May 2015
                            • 472
                            ok have ordered this ic STR-W6052 and diode DM801 which was def short, I have the cap CM804 221 1Kv
                            However with these components now removed from the board I now have another question re do I have another problem on this board
                            I believe the ic has one leg which is ground, however when checking the board connections with the ic removed I am getting a ground on all 3 solder points on one side of where the ic solders in, dont know what pin numbers they are but they are all on the outside edge of the chip/board,
                            Does that sound right or am I worrying over a problem that is not there, I am thinking there is something else on this board that has a short to ground
                            • london-freddie
                              • May 2015
                              • 472
                              update !!!! got a used power board off ebay tv is now working again, now wait for ic and diode to arrive and try and get old faulty board working
                              thanks for the help guys
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Were you able to compare the two boards regarding your concern over the 3 pins grounded.
                                • london-freddie
                                  • May 2015
                                  • 472
                                  No, did not check just put the board straight in the tv and powered it up, may take it back out and check out of curiosity though, I was being a bit impatient as the ic is coming from china and did not want to wait when I saw this board on ebay got it next day
                                  • andrearimini
                                    • Dec 2018
                                    • 1
                                    • Italia
                                    Hi all, i'm trying to repair this board and lost few hours without no results.
                                    I've changed STR-W6052S (the old one makes a "click loop" when powered) and CM804, checked all diodes and capacitors, changed everything was faulty but this damn board doesn't work and nothing appears on output.
                                    It seems STR-W6052S (correctly powered) doesn't oscillate and obviously transformer doesn't work.
                                    Does anyone has any suggestion? Any schematics? My curiosity is higher than time i've spent on it so i'd like to find the faulty.
                                    Many thanks, have a nice day.
                                    • gray.matter
                                      • Oct 2021
                                      • 1
                                      • england
                                      Hello new member here looking for helpwith
                                      Samsung BN44-00506A power board dead no standby, but i can hear something cycling on the board and advice on wat to check or replace?
                                      Many thanks
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        Many thanks
                                        Can you upload good clear pictures of your power supply front and back if possible.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • k370
                                          Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                                          by k370
                                          Hi everyone,
                                          I have a NM-A321 board that is dead, with no power at all.
                                          When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                                          With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                                          • +3VALW
                                          • +5VAUX
                                          • 1.2VSUS_PWRGD
                                          • 3VALW_PGD
                                          • 1.05VAUX_PWRGD
                                          Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                                          The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                                          09-23-2024, 11:57 AM
                                        • Destroyer-Br
                                          [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                          by Destroyer-Br
                                          Hi everyone,
                                          I'm working on an Acer Nitro 5 unit with the following specs:
                                          • Motherboard: LA-J871P Rev: 1B
                                          • Model: Acer AN515-55-59MT
                                          • S/N: NHQ7JAL00403906A973400
                                          • SNID: 03902728734
                                          Initial Issue
                                          The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                          After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                          04-17-2025, 08:18 PM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • corrize
                                          Nikon D5 – dead, power board issue ?
                                          by corrize
                                          Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
                                          When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
                                          I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
                                          Now, I try to understand how it works.
                                          There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
                                          04-03-2023, 09:13 AM
