Vestel TV - backlight but no picture
  • Eddy1000
    • Jan 2017
    • 20
    • MyCountry
    my TV shows no picture.
    It starts, the background lighting goes on, but there is no picture.
    I have already made a vestel core update. No change!
    Then I rewrote the two flash memories 25Q32 and 25Q64 - unsuccessful.
    Need help!
    Chassi: VES315WNDS-01
    PS: Vestel 17IPS11
    MB: Vestel 17MB82S
    Thank u
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Vestel TV - backlight but no picture
    Guessing WNDS panel then if not what does it use ? The samsung Panels in these are prone to this failure sometimes, check the ceramic caps on the panel board for short circuits if they are fine theres an Ic on the panel that needs swapping.
    • Eddy1000
      • Jan 2017
      • 20
      • MyCountry
      Hello!
      Panel board means the board between panel and mainboard? There ist no ceramic cap.
      Thank u
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        On the panel tab pcb which is hidden under some plastic.
        • Eddy1000
          • Jan 2017
          • 20
          • MyCountry
          Can i check something? The fuse does the job.
          Thank u
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            do you get voltage on each side of that white fuse?
            • Eddy1000
              • Jan 2017
              • 20
              • MyCountry
              Yes 12 volts on each side
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                thats ok then hopefully reece will have a idea what maybe causing this issue now he knows it uses a VES315WNDS-01 panel
                • Eddy1000
                  • Jan 2017
                  • 20
                  • MyCountry
                  Ok :-)
                  I hope so too.
                  Thank u
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Have a read bud:
                    https://www.badcaps.net/forum/showthread.php?t=59898
                    • Eddy1000
                      • Jan 2017
                      • 20
                      • MyCountry
                      Thank you!!!
                      How can I check the caps in the circuit?
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Dmm also just see if they get warm for a start.
                        • Eddy1000
                          • Jan 2017
                          • 20
                          • MyCountry
                          I have checked the temperature.
                          Unfortunately, nothing is warmer than 18° C.
                          The TV responds to the remote control only on / off and the presets button. Presets make the backlight brighter and darker.
                          • Eddy1000
                            • Jan 2017
                            • 20
                            • MyCountry
                            I've got behind the few parts on the right side and the two (t2 parts) only 0 volts...
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Test for short circuits.
                              • MartinBth
                                • Feb 2017
                                • 14
                                Vestel 17MB82S / Telefunken LED TV D32H278R3
                                i am new in this Forum.I am from Germany.My Problem:
                                I have an Telefunken LED TV Model: D32H278R3
                                The Motherboard Vester 17MB82 is broken.
                                I buy on Ebay an other Board from an Telefunken D32H278A3.
                                Now the Picture ist standing on the Head and the Picture ist very Bad.
                                Motherboard: 17MB82S
                                Power Supply:17IPS71
                                Panel:VES315WNDL-2D-N02
                                Here some Picture from the TV.
                                What can i do?
                                Who can help me,please ?
                                Greetings from Germany
                                Martin
                                • Andrew F. Ali
                                  • Jan 2014
                                  • 2450
                                  • Trinidad & Tobago
                                  Main Bd Software is not a correct match for your T-CON Bd
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    +1
                                    • MartinBth
                                      • Feb 2017
                                      • 14
                                      Who can give me the correct software?
                                      Which version?
                                      Greetings
                                      Martin
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        No one order the correct board.
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Raulnn
                                          Ansonic 32HD1 Vestel 17IPS11 17mb55 no Sound, no backlight, no images
                                          by Raulnn
                                          Hello! I am new to electronics, and this forum is fantastic. I have the following problem, I have an Ansonic 32HD1 tv, a generic brand from Vestel, with a 17IPS11-R4 power supply and main 17mb55.
                                          The tv has no backlight, but it also has no image and sound. when it turns on the standby light blinks several times, and there is a very short flash of the backlight, as if it wanted to start, but it does not start. I have measured the voltage on the red wire of the backlight, as you have seen on the forum, and in standby it has 30v, and when it turns on it goes up to 100v and slowly drops...
                                          11-15-2022, 03:02 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
