Interesting CWT PSU
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Interesting CWT PSU
    Got this PSU at the local recycle place for $2.95. I knew it was CWT before even picking it up, and shining my flashlight through the top, it looked pretty unique. I'll let the pictures speak for themselves mostly
    Switchers are 2SC2625
    16A ultra fast for 12V, two 40A schottky for 5V, and it uses linear conversion for the 3.3V with a 40A FET.
    Fan is a sleeve bearing Jamicon. Will post solder shots later. I am going to recap this and use it in my Pentium III 933 rig. It's rare to find an old PIII era PSU with a quiet fan controller
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    Re: Interesting CWT PSU
    holy shit not one but TWO fuh-joo-yoo primaries! made me gag when i saw those lol! dammit, pentium4! lol
    jokes aside, its a nice power supply. nice score btw. from the label ratings, it gives my enermax liberty a run for its money esp. since it has all the negative rails present. i still have to get around to recapping mine tho.
    • Khron
      • Sep 2006
      • 1350
      • Finland
      On the bright side, the 5Vsb doesn't have an electrolytic "critical cap", AND it's right up against the fan (so gets plenty of cooling, even passively), so it oughtta last for a while. Especially after a re-cap
      • PeteS in CA
        • Aug 2005
        • 3578
        • USA, Unsure of Planet
        Maybe August or September, 2000 vintage. I'd be wary of the GP caps between the inverter and O/P heatsinks. Decently derated O/P rectifiers. The heatsinks seem a little light for 300W, but at least they're solid extrusions, not two extrusions tongue-and-grooved together. Should be good for 250W, though.
        PeteS in CA
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Haha, sorry Wow, really? What model is your Enermax Liberty? Thanks! It was money well spent I would say.
          Yeah! Surprisingly, the Fuhjyyu caps tested good on the 5VSB circuit. Their capacitance started rising though, with one of them reading 500uF and the other reading 526uF. Both their ESR read 0.12Ω which seems about right for GP caps.
          You got it! Forgot to mention, the marked code on the outside of the chassis is August, 2000. I will be replacing ALL caps The only caps that have tested bad so far are the 2200uF 10V Su'scon SD series, reading 2664uF and 2672uF. All the Fuhjyyu caps tested good! The only low ESR cap in here was a 1000uF 16V TMR, that read 1068uF and 0.05Ω ESR. Maybe they did that because it's on the linear regulated rail.
          • ChaosLegionnaire
            HC Overclocker
            • Jul 2012
            • 3264
            • Singapore
            this is the review of mine by hardware secrets. as far as the important rails and power go for a p3 system, the 5v current rating and the combined power of the minor rails match that of my enermax liberty.
            • Stefan Payne
              • 1267
              I have something similar, in a PS/2 Redundant thingy (that with two PS/2 PSUs inside)...
              • Wester547
                • Nov 2011
                • 1268
                • USA.
                The heatsinks aren't only light for 300W, they're light given that a linear regulator for +3.3V is mounted on it. Interesting how 16-year old Fuhjyyus could not only look good but test to spec. We all know this is much less possible with 15+ year old KZGs, so I guess there really is a difference between KZGs and Fuhjyyu. The toroid and the windings look a bit small and thin for 300W too. Those heatsink remind me a bit of those used in early 2000s FSP/Sparkle units.
                Su'scon SD is arguably low impedance but just barely (about on par with Nichicon PM/NCC LXV/LXY). SK is their true GP series. Would be interesting to see how much lubricant is left in that Kaimei sleeve bearing fan if any.
                • Drack
                  Yup it's me
                  • Nov 2016
                  • 297
                  • Venezuela
                  Any news of the PSU?
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Sorry for not updating! I took some pictures a while ago and did a full recap on the thing. There were also three joints that looked like they were failing so I redid them. There were also two 1uF 50V CapXon caps in there, that tested good.
                    I ended up using a newer Jamicon sleeve bearing fan. It's nice and quiet! I will take a picture of the old Jamicon fan later.
                    It must be true that these crappy companies were better back in the day. Whether they got used or not, true Fuhjyyu would have popped. Like ones I've seen that popped and leaked after just 7 years of sitting. Anyways....pictures!
                    • Wester547
                      • Nov 2011
                      • 1268
                      • USA.
                      Nice work, P4! The base of those heatsinks do look a bit thin for my liking. But if the fan controller is aggressive enough at high loads, it may be a non-issue.
                      Yes, in my experience, Jamicon fans are even quieter than ADDA fans.
                      Very true, in spite of the fact that the bad brands have always been inconsistent in quality. KZGs, on the other hand (and KZJ and their variants), were always notorious for the same misdemeanor as bad Fuhjyyus (popping and leaking in unused equipment or still retaining their full leads in a sealed bag), all the way back to the year they went into production (2001 for KZG, 2003 for KZJ). Although admittedly I haven't seen a popped or failed KZG with 2009 datecodes or later so I wonder if NCC actually ever fixed them before they went out of production, but that's for another thread.
                      As to crap companies getting worse over time - the same goes for LTEC, Elite, Teapo, CapXon, Jamicon, Su'scon, etc - none of these brands were ever on par with the Japanese brands but they weren't alway so notoriously bad. Teapo and CapXon have particularly become replace-on-sight-pop-their-tops-in-storage junk over the years.
                      • Drack
                        Yup it's me
                        • Nov 2016
                        • 297
                        • Venezuela
                        Must say that where I live there are so many crap caps, even no name ones, that I'm glad when I see a teapo, I think they are not that bad as they used to be, crapxon on the other hand is shit, I think that no name caps are better in some cases lol
                        I have a couple of kzg on two of my Mobo's, and they are OK, haven't check the date though
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          Okay so I remeasured all of the caps and listed where most of them were. I like to measure afterwards because testing them right after desoldering can be misleading.
                          AC filtering:
                          680uF 200V Fuhjyyu LP. Read: 613.4uF, 0.14Ω
                          680uF 200V Fuhjyyu LP. Read: 621.4uF, 0.15Ω
                          5VSB filtering:
                          Cap before coil: 470uF 16V Fuhjyyu TNR. Read: 513.4uF, 0.20Ω
                          Cap after coil: 470uF 16V Fuhjyyu TNR. Read: 494.6uF, 0.21Ω
                          Startup cap:
                          22uF 50V Su'scon SK. Read: 21.70uF, 1.13Ω
                          5V filtering:
                          Cap before coil: 2200uF 10V Su'scon SD. Read: 2536uF, 0.07Ω
                          Cap after coil: 2200uF 10V Su'scon SD. Read: 2598uF, 0.07Ω
                          Linear 3.3V filtering:
                          1000uF 10V Fuhjyyu TMR. Read: 1056uF, 0.10Ω
                          12V filtering:
                          Cap before coil: 1000uF 16V Fuhjyyu TNR. Read: 1089uF, 0.12Ω
                          Cap after coil: 1650uF 16V Fuhjyyu TNR. Read: 1746uF, 0.08Ω
                          -12V filtering:
                          470uF 16V CapXon KM. Read: 460.8uF, 0.18Ω
                          -5V filtering:
                          47uF 16V Su'scon SK. Read: 64.51uF, 1.00Ω
                          Primary BJT caps:
                          1uF 50V Su'scon SK. Read: 0.98uF, 3.2Ω
                          1uF 50V Su'scon SK. Read: 1.00uF, 3.7Ω
                          Others:
                          22uF 50V Fuhjyyu TNR. Read: 21.20uF, 1.27Ω
                          10uF 50V Fuhjyyu TNR. Read: 10.62uF, 1.82Ω
                          2.2uF 50V Fuhjyyu TNR. Read: 2.08uF, 1.43Ω
                          2.2uF 50V Fuhjyyu TNR. Read: 2.13uF, 1.12Ω
                          1uF 50V CapXon KM. Read: 1.01uF, 3.1Ω
                          1uF 50V CapXon KM. Read: 0.98uF, 3.7Ω
                          • Stefan Payne
                            • 1267
                            But but it's said that Fuhjyyu are not good as well as others.
                            But but your caps seem to be totally fine. That must be some mistake on your side!!!111
                            Sorry for the sarcasm, just coudn't resist
                            • Drack
                              Yup it's me
                              • Nov 2016
                              • 297
                              • Venezuela
                              Fuhjkyou tnr on spec, wait WTF? CRAPXON KM ON SPEC?
                              sorry but it's really weird to see those in good shape in this forum, and don't make me talk about the suckson I hate them.
                              Ps. I felt that the real names are bad words, that's why they are twisted
                              Ps2. I know my jokes are bad
                              • Wester547
                                • Nov 2011
                                • 1268
                                • USA.
                                It's true that capacitance wise, electrolytics have a positive temperature coefficient, so until the caps themselves are at room temperature (after cooling down following desoldering), the resulting measurements can be a tad misleading.
                                As for the bad brands testing fine, in all seriousness, (possibly and probably) the measurement of the utmost importance in testing wet electrolytic capacitors is leakage current (or vloss/voltage loss). A capacitor can still test to spec for capacitance and impedance and still have very high leakage current (and that means the anode dielectric has a weak point, a hot spot, or is possibly damaged beyond repair). A telltale sign is how quickly they respond on the ESR meter and how fast they reach their desired values (for capacitance and ESR - if they respond slowly, leakage current is probably high). If this PSU was unused and those capacitors were just sitting all these years, leakage current is probably really high and I'm not sure if those F-you's or Suck-cons would reform all that well (but no one would ideally be using 16-year old crap brands for anything other than very light applications such as decoupling, maybe).
                                You are right though, Su'scons aren't good caps. They have a really high failure rate in LCDs, just like Samxon GF and GK, CapXon, Samwha WB/XC, etc...
                                • Drack
                                  Yup it's me
                                  • Nov 2016
                                  • 297
                                  • Venezuela
                                  At least samxon has some good series I have heard, almost all the samwha caps I have saw are dry or Leakey, Samsung should be ashamed
                                    ASUS P5GC-MX motherboard recap
                                    by momaka
                                    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                    So here is what the motherboard looked like with its original caps:
                                    CPU VRM area up close…...
                                    01-27-2021, 11:59 PM
                                    no-name Radeon 9600 XT recap and cooler
                                    by momaka
                                    I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                                    This one was actually suggested to me by ChaosLegionnaire....
                                    11-06-2020, 07:54 PM
                                  • Pentium4
                                    Solytech SL-8360EPS analysis + mods
                                    by Pentium4
                                    Unfortunately I got rid of most of my power supplies a few years back so I hunted some on eBay. Of course I could have got some with already good caps but what's the fun in that when you can save unsuspecting victims on eBay from buying something that could cause them problems?
                                    I'm also aware that Solytech is capable of making a decent unit, minus their caps. This one is on the 80 Plus website as being able to do its full wattage.
                                    I bought two of these as a lot. One was made in July 2017 and one was made in September 2017. Interestingly, the only...
                                    08-04-2023, 06:21 PM
                                  • Foetuss
                                    Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                    by Foetuss
                                    Hi all
                                    Hope this is in the correct place.
                                    I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                    Could use some double checking to see if I'm not doing something stupid .
                                    Pictures of the boards are attached.
                                    What I will be replacing with what : (planned)
                                    Soltek Golden ::
                                    4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                    6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                    01-18-2025, 11:44 AM
                                  • goodpsusearch
                                    Got 4 LG L222WS 22" for free - psu recap
                                    by goodpsusearch
                                    Got 4 CCFL 16/10 monitors for free.
                                    The resolution is almost Full HD (1680x1050)
                                    VGA Input only is a bummer though.
                                    Uses cheap TN panel with terrible viewing angles.
                                    Even though this is not 17" 5:4 screen, still has very low resell value here. Can be found for 15-20 euros.
                                    All the 4 monitors were not working and needed psu recap. Used mix of mediocre / junk caps to recap them, then donated 3 of them to friends/relatives and kept 1 for myself. Also like to install extra caps on empty spaces to help them last longer.
                                    01-15-2022, 05:36 PM
