UsiCase 330U-SCE
  • ml2
    • Sep 2016
    • 17
    • AU
    UsiCase 330U-SCE
    I made a post about my now apparently dead MSI K8 Neo4 motherboard and it was suggested to me that I post about the PSU here first with some pictures.
    Basically, I turned on the PC and logged on, left the room, came back a few minutes later and the PC was dead. The system had been stable without any hint of what was coming.
    The PSU in question is a Usicase 330U-SCE.
    I opened the PSU up and found one cap with a bulged top. I noticed another one tonight starting to bulge (very slight). I can see no scorch or burn marks anywhere.
    The caps are Fultec, Fuhjyyu and Vent. The failed two are a Fultec and a Vent, both down where all the pigtails join the board.
    Where I've gotten a bit lost is in the behavior of the PSU after the failure. When the PSU is not plugged into the motherboard shorting the ps-on pin to ground turns the PSU on as it should. When the PSU is plugged into the motherboard (both 24 pin and 4 pin connector) shorting ps-on to ground causes the ps-on pin to initially go down to near zero and then shoot up to 14 volts. Would this behavior be indictive of failed caps or something more sinister?
    I guess what we're trying to find out is did the PSU go bad all of a sudden and kill the motherboard in the process, or perhaps the PSU generally ok (just a couple of bad caps) and the motherboard is mostly at fault.
    I guess the PSU might not be worth saving in the grand scheme of things but if I was able to fix it and the mobo to get another month or so out of them while I build a replacement PC that would be good.
    Tim
    • 31020
    Re: UsiCase 330U-SCE
    you have to keep those well mounted or they blow away in the wind!
    the bad news is it's junk,
    the good news is it wont cost mutch to replace all the caps!
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3264
      • Singapore
      wtf it has only one pi coil for filtering the secondary side? really? dont u wanna split that in half for the other rails as well?! /end sarcastic post
      • ml2
        • Sep 2016
        • 17
        • AU
        At the request of another on my mobo thread I measured the PSU again.
        PSU in standby:
        12v = 0.4v (remaining bad cap in PSU?)
        5v = 0v
        3.3v = 0v
        -5v = 0v
        -12v = 15.1v **
        5vsb = 5.19v
        No load
        12v = 12.06v
        5v = 5.26v
        3.3v = 3.429v
        -5v = -4.94v
        -12v = -11.39v
        5vsb = 5.19v
        2 HDD load
        12v = 12.06v
        5v = 5.26v
        3.3v = 3.429v
        -5v = -4.94v
        -12v = -11.7v
        5vsb = 5.19v
        This shows something I missed before (bad me), the -12v line is doing polarity reversal. With the PSU in standby it's at positive 15v but when the PSU is turned on it goes negative (I think I have that the right way around, red DMM lead into blue, black dmm lead into black lead)
        What would cause that? I guess the PSU is really junk now which is no problem, it cost me nothing 6 or so years ago.
        Now I have to research a good value PSU.
        • Dan81
          SNES-powered
          • Oct 2013
          • 1865
          • Romania
          PSU in standby:
          5v = 0v
          3.3v = 0v
          -5v = 0v
          -12v = 15.1v **
          5vsb = 5.19v
          No load
          12v = 12.06v
          5v = 5.26v
          3.3v = 3.429v
          -5v = -4.94v
          -12v = -11.39v
          5vsb = 5.19v
          2 HDD load
          12v = 12.06v
          5v = 5.26v
          3.3v = 3.429v
          -5v = -4.94v
          -12v = -11.7v
          5vsb = 5.19v
          I know you may have heard this before but you could try and boot your K8N Neo4 using another power supply. I know this sounds quite stupid,but I had this happen with a Deer PSU (which was actually built pretty good except the sillicon,but that's going to be a whole another story - bye bye TT2164 transistors!)and using a modded Sun Pro (testing and such) actually worked and the MB booted. Check that your PSU has a -5v rail. I know this really sounds dumb but it seems that even though it's 939 it could still need -5v. (please people don't tell me about the -5v rail being removed story,I know it )
          Main rig:
          Gigabyte B75M-D3H
          Core i5-3470 3.60GHz
          16GB DDR3-1600
          Samsung SH-224AB DVD-RW
          Delux MG760 case
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            As much as I like fixing cheap PSUs, this is one that I wouldn't - at least not for powering a computer anymore. The PSU above has a tiny output toroid, not enough filter caps on the output, and worst of all, the 3.3V rail appears to be derived directly from the main transformer rather than regulated by a mag-amp or a linear regulator (this is pretty evident with the high readings of 3.4V for the 3.3V rail).
            So all in all, I suggest not to use this PSU for powering a computer. It might be okay for running small DC motors, light bulbs, and other non-sensitive projects. Or you can use it for parts. Although this is a cheap PSU, at least it appears to have all of the input line filtering: two common-mode chokes, two X2-class safety caps between Line and Neutral, and four Y2-class safety. All of these are good parts that can be used to rebuild another cheap PSU that is perhaps built better on the output but lacks the input filtering. The PSU above also has an SB3040PT schottky rectifier, and that can be used to upgrade another PSU as well.
            • Wester547
              • Nov 2011
              • 1268
              • USA.
              ^ Interesting. I was of the impression that it meant +3.3V was filtered using the coupled inductor that's part of the magamp circuit on the DC side (super group regulation...). Hence the high +3.3V reading. Of course it could be taken directly from the +5V transformer tap after the output tap is rectified and then filtered by the output capacitors or lack thereof. Unless I misunderstood your post altogether?
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                If the 3.3V rail on this PSU used a mag-amp design, then the 3.3V rail would have had its own output toroid *and* also the mag-amp AC-side saturation toroid. Neither of these are optional for a mag-amp design.
                The only time you see a single output toroid (what people often call here "supergroup regulation", which is misleading IMO) is if the PSU derives the 3.3V rail linearly (through a MOSFET, typically from the 5V rail) *OR* like in this case, through its own winding from the main transformer *without* any regulation whatsoever (now that is truly supergroup regulation... and its supper crappy ).
                • Wester547
                  • Nov 2011
                  • 1268
                  • USA.
                  I don't think I'd call it group regulation, as there is no output inductor to regulate the +3.3V rail in that case. I'm a bit perplexed though, as to what this means for other PSUs (I know, I'm getting off-topic again...).
                  Like the linear regulator design in the older Hipro PSUs. As I understand it they have their own transformer tap, their own rectifier, their own winding in the output toroid, and their own output filter before the linear regulated +3.3V rail. So I'm not sure where the +5V and +3.3V combined rating on those PSU's label comes from unless it's just an "ATX mandated" standard (or unless that refers to how much power you can "waste" in the linear regulator before it burns out under a relatively high PSU load). I don't think they're referencing the limit of the main toroid or transformer.
                  Going back to the +3.3V magamp design though, I understand that the choke on the AC side of the heatsink is used to attenuate the AC emanating from the +5V transformer pins so it can bring the voltage down to +3.3V and thereafter is rectified to DC by the rectifier, then regulated by its own toroid and filtered by the output capacitors. Is this part of a separate topology from a forward converter or half bridge design (would a forward converter still need a freewheeling diode for the +3.3V magamp circuit to discharge the output inductor and preclude reverse voltage spikes)? In some half bridge PSUs with a +3.3V magamp design, there appears to be *a second* choke that looks identical to the AC side choke, but it's on the DC side, wedged between the two toroids. No idea what it's for.
                  • glovecaps
                    Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                    by glovecaps
                    I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                    My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                    The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                    11-25-2024, 04:23 PM
                  • Docus
                    Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                    by Docus
                    Hi everyone 😀,
                    I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                    To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                    Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                    1. I already own the exact same model, but its plastic chassis is badly damaged.
                    06-10-2025, 04:24 PM
                  • Archimedes
                    HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                    by Archimedes
                    Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                    Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                    Fans are spinning. Blindly could install windows11 and got the device manager...
                    07-30-2024, 05:14 PM
                    ASUS P5GC-MX motherboard recap
                    by momaka
                    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                    So here is what the motherboard looked like with its original caps:
                    CPU VRM area up close…...
                    01-27-2021, 11:59 PM
                  • dragon3x
                    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                    by dragon3x
                    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                    power on.
                    Here are some examples :
                    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                    switching supply area).
                    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                    than 6.3 V.)
                    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                    I replaced capacitors with aluminum-polymer.
                    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                    03-21-2025, 02:46 PM
