Unhappy VIZIO E500i-B1 Powers on then shuts off within a few seconds
  • jehuie
    • Aug 2016
    • 18
    Hi All - I'm new to this. I have a Vizio 50" LCD TV that is 18 months old. It has stopped working. It will power on, displays the VIZIO logo on the screen, then within a few seconds powers off and the white power light slowly fades out. Of course the warranty is up. I have tried to reset, uplugged all external devices, unplugged from power source, held the power button for 60 seconds, plugged into new outlet, etc. I would like to attempt to fix it myself due to the cost of service vs. a new TV.
    I saw another thread about the exact same issue that I modeled this thread on but it was a different Vizio model here: https://www.badcaps.net/forum/showthread.php?t=22001
    In that thread most people say it's a firmware issue. I talked to Vizio support and they insist that it's a hardware problem and that they will not help but will refer me to someone who I can pay to repair it. I'm fairly handy and can solder and such but I need some help! So glad to find a community like this one!
  • jehuie
    • Aug 2016
    • 18
    Re: Unhappy VIZIO E500i-B1 Powers on then shuts off within a few seconds
    Oh....one more thing....several times I have unplugged the TV for 30 minutes or so and then it will come up again and work fine for hours at a time. But as soon as I turn it off it's stuck and will no longer power up again and behaves like I stated above.
    • ozzy214
      • Nov 2013
      • 319
      • usa
      Sounds like a bad eeprom or corrupted eeprom chip to me. You can try using a can of air to freeze the chip. If cold, it comes on every time, then change it.
      Sadly it doesnt look like anyone is selling on at this time.
      • jehuie
        • Aug 2016
        • 18
        Is there a part number or something that I can search on to try to find one? Or is it commonly used in certain models that I may be able to find at the local electronics recycling place so I can borrow one from another broken TV?
        Also, I work on old arcade games as a hobby and I'm pretty good at soldering and desoldering on those. But most modern electronics have much smaller components and are difficult to repair unless you have specialized tools. Do these fall into that category?
        Thanks for the help!
        • slickrickybobby89
          • Jul 2016
          • 87
          • america
          What are your board #s i have all boards from a e500i A1, sadly the panel was damaged, but all the boards work great.
          • jehuie
            • Aug 2016
            • 18
            I don't know because I haven't yet disassembled it. I'm not afraid to do so but I didn't want to do it unless I was fairly sure I can repair it. I can get it to work. I just end up leaving it unplugged and then when I want to use it I plug it back in and just wait a bit and it works.
            Which board would that eeprom be on? And how much would you want for the board? Is it pretty easy to get to the board to get the number off it? Like a half hour job? Or much longer?
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              Shopjimmy has plenty of mainboards.
              • slickrickybobby89
                • Jul 2016
                • 87
                • america
                If its similar to the e500a1 you will have to remove the base, then lay the panel on a flat surface, prefereably a clean, carpeted area, or large table, then remove all screws around the edge of the panel, there will usually be a few hidden around the input area, if you start to ift the back and it hangs, look for more screws, the back should lift off fairly easy on this set. If the boards are interchangeable, you can have them for what it will cost me to ship them mate. The set was given to me, so it would just clear some space for me.
                • jehuie
                  • Aug 2016
                  • 18
                  This place is awesome. Well, the people here are. Thank you! I'll give it a shot!
                  • slickrickybobby89
                    • Jul 2016
                    • 87
                    • america
                    No problem, once you get it opened up, take good clear pictures of the boards, and the white stickers on them, ill check your #'s against the ones i have.
                    • jehuie
                      • Aug 2016
                      • 18
                      Here's what I assume is the main logic board:
                      And what I'm assuming is the power supply:
                      I'm not sure which sticker you need on this board though. This one?
                      • jehuie
                        • Aug 2016
                        • 18
                        Here is a better image of the sticker on the main board:
                        • slickrickybobby89
                          • Jul 2016
                          • 87
                          • america
                          You nailed it with the pics man, unfortunately we have completely different mainboards and power supply's, sorry im not able to help ya there man. But you have them labeled correctly. Maybe someone will be able to offer better insight as to why you have the issue with not being able to restart your set.
                          • jehuie
                            • Aug 2016
                            • 18
                            Bummer. Well which board do I need? I think it's the CPU/main board. I can look on shopjimmy. I found that place. What number do I look it up by? There are stickers all over the place.
                            • jehuie
                              • Aug 2016
                              • 18
                              Never mind my last question. I found it. Looks like a replacement board is about $80. Do these guys fully test their boards and stand by them? I'm torn between risking $80+shipping on something that may fix it....versus going and buying a new TV for $500. If I felt confident that the board would last a long time then it's a no brainer for me. $500 is a lot of money to spend every year and a half for a disposable TV!
                              • jehuie
                                • Aug 2016
                                • 18
                                Sorry for rambling here....
                                I also found this on eBay. It looks identical and says it's for the 500i-b1 which is what I have. But the numbers are different. Does anyone know if it will work?
                                $40 + free shipping and guaranteed return sounds promising to me.
                                http://www.ebay.com/itm/like/3018689...&ul_noapp=true
                                • Malachi
                                  • Dec 2015
                                  • 1077
                                  • Usa
                                  I copied and pasted the number from your link into the shopjimmy search bar.
                                  It says that board if for an E500i-B1 with a certain serial number.
                                  Look on shopjimmy for the one that matches your serial number then look for it on eBay if you want to buy there.
                                  • jehuie
                                    • Aug 2016
                                    • 18
                                    Well....I've been running it for a couple days now with the back off and it doesn't seem to be having any problems. Perhaps because it's running cooler with the back cover off? I may just leave it that way since I can't see the back anyway.
                                    • jehuie
                                      • Aug 2016
                                      • 18
                                      And now it's doing it again. I guess I need to buy a board after all.
                                      • culcuhain
                                        • May 2016
                                        • 186
                                        • U$@
                                        Shopjimmy should give you a 6 month warranty with the option to buy a 1yr or 2yr warranty. They are very reputable.
                                        • csmith
                                          Vizio D50u-D1 Powers up no picture
                                          by csmith
                                          I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                          Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                          supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                          issue. Set will power up with remote but not power off....
                                          07-11-2025, 11:52 AM
                                        • ResoluteHawk
                                          Alienware 17 R3 (LA-C912P) Powers on then powers off after 4-6 seconds
                                          by ResoluteHawk
                                          I have an Alienware 17 R3 (board is a C912P) that I recently starting trying to repair. Originally the issue was the charger going into protection mode when plugged in to the laptop. I found a short on the motherboard (one of the capacitors on the back of the board under the DRMOSes for the CPU) and the charger when plugged in now doesn't go into protection mode anymore. The laptop powers on, the lights on the keyboard, alien head, and alienware logo light up, and the fans spin. The issues are:
                                          1) The battery doesn't charge. I've probed the charger jack and it's only receiving 0.633v...
                                          06-17-2022, 01:04 PM
                                        • videotronics
                                          D43-E2 vizio dark gray display 36 seconds restart
                                          by videotronics
                                          Hello everyone, the budget 4k 2017 model Vizio on power up the white led fades and the backlight illuminates, the display is dark gray modulating slightly brightness until the set restarts on 36 seconds interval. Power supply 5v 12.7v 21v are all good. Any recommendations to test the panel and display drive t-con board and mainboard will be appreciated.
                                          08-24-2023, 09:04 AM
                                        • survivalbloke
                                          ASUS TUF 506 powers off after about 10 seconds due to heat
                                          by survivalbloke
                                          This laptop come in with liquid damage. I located a couple areas on the board which honestly didn't look bad at all. I ISA them and cleaned up - can't even tell anything happened. However, when I power up the computer, it will shut off after about 10 seconds. I discovered it seemed like the fans weren't coming on because the board was getting mad hot right around the battery charging mosfets and coil. Anyhow, I checked under the thermal camera with just the power adapter connected but the machine off. I have marked what is warm at that time. Once I power it up, the coils near CPU vcore start heating...
                                          08-07-2023, 02:23 PM
                                        • npolite
                                          Vizio E320-A1 Powers on But No Display
                                          by npolite
                                          Hi All,
                                          I have a Vizio E320-A1 which lost sound and picture. The power LED comes on and stays on but nothing else works. I am not able to power it off unless I unplug it.
                                          Here are the voltages when the power is on
                                          1 - 5.25
                                          2 - 5.25
                                          3 - 0
                                          4 - 4.8
                                          5 - 25
                                          6 - 25
                                          7 - 0
                                          8 - 0
                                          9 - 0
                                          10 - 12
                                          11 - 12
                                          12 - .9
                                          13 - .5
                                          Can someone let me know if the issue is with the mainboard?
                                          Thanks...
                                          04-19-2024, 11:33 AM
