I have a Sanyo dp55441. A lightning storm came by the other day and got several electronics in the house. This tv included. It wouldn't do anything when power was pressed. I took tv down, took back cover off, and visibly checked everything and nothing stood out. I plugged power up and tv came on. Everything seemed to work. I could change input and it would display and then show "no signal". So I connected it to different sources and still get "no signal". I have tried all hdmi ports. Composite Video ports and the USB port and they all show no signal.
Any ideas?
The main board's numbers are listed as 431c4169l02. They are nearly impossible to find.
Questions:
Do you think this is what is causingissue?
Is there a way to check if this is bad?
Is this part compatible with other similar parts?
Thanks so much for any help!
Any ideas?
Questions:
