Sharp PN-E702
  • Peter 101
    • May 2016
    • 3
    • wales
    Sharp PN-E702
    Good Morning,
    We have a Sharp PN-E702 that loses backlight after 20 seconds. We are trying to rule out wheather its the display or the supply. On the 14 separate supplies we have about 180v supplying the screen. On the return from the screen we only have between 1v and 1.7v. After disconnecting the return voltage on the 14 separate pins the voltages range between 70v and 90v. Any help would be much appreciated.
    Best Regards Peter
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Sharp PN-E702
    Sounds like a bad Led in the screen to me. You will have to take the Lcd panel apart and test the Led backlights.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      Re: Sharp PN-E702
      x2 what reecey said.
      • Peter 101
        • May 2016
        • 3
        • wales
        Re: Sharp PN-E702
        Thats what we were thinking as well,,unfortunately due to the size of this beast its a real pain to do without risking cracking the screen.
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          The TV does not turn on, the standby indicator is on. All voltages are present.
          Emms is dead. Not readable, not detected.
          Replaced emmc.
          But with another dump there is no launch
          Terminal log
          UART
          AC_ON
          RPMB key is not yet programmed
          HASH1_VERSION=0x00000000 64bit
          E-B
          FDE enabled
          layout pattern onebin by SAR7,0...
          06-01-2025, 02:11 AM
        • neilc6
          Sold Sharp LC-50LB370U Board on Ebay - Return Requested
          by neilc6
          Sold this board on ebay with this warning in the description and pic of working TV.
          "Pulled from a TV with a damaged panel. NO REFUNDS.
          This model suffers from LED backlight failures. Make sure your backlights are working before replacing boards. Symptom is TV turns on and off with no backlight or a flash of backlights."
          Ebay Return Request
          Reason for return - Doesn't work or defective
          Details - Powersupply board has sound,but verry dark screen.I would like to return,You send for me another one. Thank You.
          With ebay, if...
          07-16-2021, 04:00 PM
        • advant
          by advant
          02-03-2020, 12:25 AM
        • sefoster
          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
          by sefoster
          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
          11-20-2022, 09:29 AM
        • gavenb
          Sharp LC-80LE661U 80 inch
          by gavenb
          Hi folks!
          I have a LC-80LE661U that had some interesting issues.
          Initially, it would come on and show the sharp logo and would show normal static before shutting off.
          I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
          11-12-2023, 02:05 PM
