Sony Kdl-46v5100
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Sony Kdl-46v5100
    I just got a free 46" Sony. It has vertical lines on the left side mainly.
    Research of others with similar problems lead to a faulty t-con board.
    I wanted some opinions before I order one.
  • budwich
    • Jul 2015
    • 3097
    Re: Sony Kdl-46v5100
    hmm... could be but the horizontal ones perhaps indicate a panel issue instead. Have you looked at the insides yet? check the tab cables. Vertical lines could be a poor seating of the tcon cables... maybe but the horizontal is more likely a tab issue.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      The cables were seated ok.
      I have found t-con boards on eBay. Shopjimmy is out of stock but I like to use them for reference.
      I have the model number of the t-con board, as per shopjimmy there are different versions according to the numbers on the sticker.
      eBay doesn't have one with my exact numbers but there are other ones listed for this model TV that are also on shopjimmy.
      Would one of those work or must the sticker number be exact?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8327
        Before you go out and buy a new board, unplug one side of ribbon cable from the tcon to the lcd screen and turn the TV on. Then vise versa. See if the bad side of the screen goes white.
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          The bad side unplugged was black, the side plugged in is white with thin colored lines.
          The picture should be rotated 90 degrees clockwise. I don't know why it posted like that.
          • Malachi
            • Dec 2015
            • 1077
            • Usa
            Unplugged the other side and plugged in the other this is what it looks like.
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              Would one of these boards work?
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8327
                If Shopjimmy lists the other tcon number as compatible, then you should be good.
                • Malachi
                  • Dec 2015
                  • 1077
                  • Usa
                  They are listed for the same model TV but they say that if possible you should order the one with the same number.
                  eBay didn't have the same exact one so I ordered one of the other ones. At $37 (including shipping) with 10% restocking feel, I'll take a chance.
                  • Malachi
                    • Dec 2015
                    • 1077
                    • Usa
                    Replacing the t-con board solved it. $37 for the board. Half life 2 the orange box for PS3 fir the TV.
                    Great deal for what seems like a nice picture. Might keep it instead of a 50" Panasonic plasma that is not full HD.
                    If a mod could mark this thread solved it would be great.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8327
                      glad to hear! Thanks for the feedback!
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Nice one Here is a word of advise keep with your Plasma ! Lol
                        • Malachi
                          • Dec 2015
                          • 1077
                          • Usa
                          My main TV is a 60" plasma, this is in the second room.
                          Keep the th-50px75u that is 720p over the 46" Sony that is 1080p?
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Yeah the plasma has many advantages, a good Plasma will still look better than 4k lcds !
                            • thelankanguy
                              Sony KD-55X9000F TCON Issue
                              by thelankanguy
                              The TV shows a black screen with no image.
                              TCON ribbon connectors were disconnected individually for image and there was no half image even.
                              Later both ribbons were disconnected and TCON voltages were tested.
                              12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                              There is also a short to ground in this circled inductor.
                              Is this a TCON issue or something else ?...
                              12-13-2024, 12:27 AM
                            • bbrain
                              Sony KD-55AG9 TCON?
                              by bbrain
                              I have this problem with my Sony 55' AG9.
                              It flashes 4x.
                              I have found the service manual, and seems it is the TCON.
                              Before I buy a TCON can someone check the vid?
                              Thanks in advance!...
                              09-19-2024, 10:50 AM
                            • rimwall
                              Sony KD-65x8500b - bad Tcon or panel?
                              by rimwall
                              Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
                              a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
                              b) the Tcon board is malfunctioning,...
                              10-24-2023, 07:58 PM
                            • x_orange90_x
                              TCL 50S535 bad tcon or panel issue?
                              by x_orange90_x
                              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                              03-29-2025, 11:02 PM
                            • advant
                              by advant
                              02-03-2020, 12:25 AM
