42PQ6000 Clicking fast not powering on
  • loadedboyuk
    • Feb 2014
    • 26
    • uk
    I have a LG 42PQ6000 seems to be stuck in standby
    after plugging in to the wall the only thing you can get is a rapid click (twice a second) from the main power board.
    If I disconnect the X/Y boards it makes no differance, if I disconnect the main AV board the clicking slows down (once every 2 seconds)
    TV does not power up
    X is connected thur the YSUS
    Board numbers are
    Power: EAY60696801
    AV: eax57566204
    Y: eax60764001
    X: eax60764101
    If anyone can help it would be great,?!? I have replaced a few compontents, as I thought I did not have 5v standby but this has made not effect on the issue of the clicking relay
  • sordids999
    • May 2013
    • 2158
    • uk
    Re: 42PQ6000 Clicking fast not powering on
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Common issue a the stby Diode shorting is something like Vb3200 check that.
      • loadedboyuk
        • Feb 2014
        • 26
        • uk
        Here is a pic of the back of the TV.
        Not sure what you mean by VB3200?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Vb3200 is the model of the diode, do you have a DMM and do you know how to check for SC ?
          • loadedboyuk
            • Feb 2014
            • 26
            • uk
            I can find lots of simlar tv manuals but not the one for this model.
            i know how to use my multi meter and check for shorts yes.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              have you tried toms site? if theres not a exact one maybe another will be close enough for trouble shooting
              http://www.toms-service-manuals.com/...h=Submit+Query
                PQ3000 is very close - only a few less features
                Terrible picture quality. Worst I've ever seen from a plasma. Dim and washed out. No idea how LG approved shipment (I believe it was the model after the sparklies debacle, so perhaps they gimped the panel drive to make it work without requiring too much re-engineering.)
                • loadedboyuk
                  • Feb 2014
                  • 26
                  • uk
                  found a diode marked VSB3200 shorted out. can this normnally be replaced, or is the short often casued by something else?
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Normally just the diode replace it and away you go Common issue on these sets, repaired two previous ones and was just that diode.
                    • loadedboyuk
                      • Feb 2014
                      • 26
                      • uk
                      cool, parts on order though various websites have different part numbers for them including
                      UF5408 (VSB3200 / RGP30) DO-201AD Diode 1A 1000V from ohmsupplies
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        You will need a VSB3000 that will work.
                        • direnc
                          • Mar 2016
                          • 1
                          • België
                          hi did it work?
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            We dont know because he never BOTHERED to update his thread. What fault have you got ?
                            • Mikeyboy2007
                              • Mar 2013
                              • 745
                              • Scotland
                              can this diode be purchased from maplins or RS components ? looking on there website im seeing loads of different ones ? or if someone can send me in the right direction to get one thanks
                              • Mikeyboy2007
                                • Mar 2013
                                • 745
                                • Scotland
                                would this work ? http://www.maplin.co.uk/p/1n5402-3a-...ectifier-ql83e
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  Ohms Supplies Ltd are a local UK supplier. LoadedlboyUK didn't come back on the thread so perhaps it worked for him.
                                  He indicated UF5408 (VSB3200 / RGP30) DO-201AD Diode 1A 1000V
                                  But I don't know if it is a replacement for the VSB3000 which I can't find anything on.
                                  • Alastair E
                                    Chief Womble
                                    • Mar 2013
                                    • 1963
                                    • U.K.
                                    Nah--Dont think its to do with the Mal-Discharge issue--These also suffer from it quite badly.
                                    LG got at by the damnable Greenies and chasing lower power-consumption I think...
                                    Crap set either way! Never seen a good one, always cruddy pictures and nearly always Mal-Discharge too, although--the green fringing/sandy/gritty picture sort rather than red-spots....
                                    TELEFIX
                                    • Mikeyboy2007
                                      • Mar 2013
                                      • 745
                                      • Scotland
                                      ok thanks. i will order that and give it a try and let you guys know if its works. im repairing this set for someone.
                                      • Mikeyboy2007
                                        • Mar 2013
                                        • 745
                                        • Scotland
                                        update for you guys, took out that diode and put in the UF5408 (VSB3200 / RGP30) DO-201AD Diode 1A 1000V from Ohm supplies and it was a success so for anyone else having the issue if the diode is goosed then change that and away you go.
                                        thanks guys.
                                        • B0r1s
                                          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                          by B0r1s
                                          PSU - BN44-00878A
                                          Symptoms:
                                          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                          A weak clicking sound was coming from the transformer.
                                          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                          Progress:
                                          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                          01-17-2023, 04:58 PM
                                        • Sisko
                                          Onkyo-593 No power and now clicking sound
                                          by Sisko
                                          Hi all!!
                                          Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                          Yesterday, 02:18 PM
                                        • TheDevastatedOne
                                          PSU Clicking On then powering off & looping.
                                          by TheDevastatedOne
                                          I have two higher end PSU's here.
                                          One of them is an EVGA 1300 Supernova G2 when I jump the "power on" it begins to power up, fans spin, voltages go down the lines as I connected a case fan to the 12volt rail and it spins up as well. But then what sounds like a small faint relay clicks and it powers off, then powers back on again and repeats this power on/off loop.
                                          I also have a new Raidmax 1000W Scorpio which does similar (right out of the retail box I might add) it will begin to power on then click & shut off. (This one does not attempt to restart until...
                                          04-23-2023, 03:37 AM
                                        • cook
                                          HP Power Supply 6632A: Fast Mode vs Normal Mode?
                                          by cook
                                          FAST MODE vs NORMAL MODE
                                          I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
                                          I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
                                          06-07-2020, 05:32 AM
                                        • slimmy182
                                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                          by slimmy182
                                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                          Looking on google I found this:...
                                          01-14-2023, 11:55 AM
