WOW! Emerson LF320EM4A
  • johnboy1313
    • Nov 2012
    • 1959
    One of these just came in with a broken screen. It's being parted and sold on eBay. I'm not impressed. There's one single LED strip with 9 LEDs.
    It was easy to open up though. I give them credit for that.
    Re: WOW! Emerson LF320EM4A
    Holy Cow! I wonder what the pictures look like when it is working.
    I like what it said on the website:
    "A BASIC TV THAT GOES BEYOND YOUR EXPECTATION"
    http://www.emersonaudiovideo.com/pro...uct.php?id=649
    I bet they drive the LEDs really hard.
    • retiredcaps
      • Apr 2010
      • 9271
      Wow, it only weighs 13 pounds. I can see how these things are getting cheaper and cheaper. I saw one TV with an integrated PSU and main board.
      --- begin sig file ---
      --- end sig file ---
        How does it manage to get even light distribution? Crazy.
          • 31294
          looking at the depth of that rear molding, it must have one hell of a defuser layer!
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            With that Funai shit, who cares???
            All that matters is that ya walk out the door with it after they've got your money.
            Since "all TVs are the same," what difference does it make how the LEDs are (over)driven?
            Most of the crowd buying these has been brainwashed into believing "it's not new, so it's junk." Does not matter if it lasts a year or even a week. The ones that die early are an entire week old and no longer new- therefore junky..
            Hey "stoopid!" It was junk before you even bought it; before it was on the shelf, even...
            "pokemon go... to hell!"
            EOL it...
            All style and no substance.
            guilty,guilty,guilty,guilty!
            guilty of being cheap-made!
            • johnboy1313
              • Nov 2012
              • 1959
              This one had an integrated main/PSU too.
                "Since "all TVs are the same," what difference does it make how the LEDs are (over)driven?" trying to get enough lights from single strip of LED instead of 4 strips, they will have to run that at full or beyond current limit of the LEDs just last long enough for warranty period.
                  • 31294
                  in theory, wih 9 cree lamps on a heatsink and the right defuser it could be done.
                  but we know they arent using heatsinks or cree lamps.
                  • kaboom
                    "Oh, Grouchy!"
                    • Jan 2011
                    • 2507
                    Sarcasm???
                    You know, just like how people assume that "all power supplies are the same" because the supposed "wattage on the sticker" is an inflated number...
                    On the same note, how about nasty crapxons and cheapo-teapos that are supposedly 4000 hr parts at 105 degrees celcius but don't even last a year at moderate temps, while an actual capacitor (Panasonic, Nichicon, Chemicon, Rubycon) will last for years, despite being good for only 4000 hours...
                    "How can the 4000hr Nichicons last so long, while capxons of the (supposedly) same longevity died in 8 months???"
                    Because the capxons in that case were not 4000hr parts, despite the fabricated figures in their datasheets.
                    Sure they are, sure they are! See the cheezy steel heatsink? And how it works better w/o thermal compound?
                    Don't be persnickitty now- who needs the Crees? "All LEDs are the same."
                    Not.
                    EOL it...
                      "Sarcasm???" Not at all, where the hell did you get that?
                        Could be really dim. I fixed a 32" Vestel junker and it was about half as bright as a normal LCD. Maybe there's a shop mode that makes them really bright, but then when you take them home the LEDs wear out quickly and brightness reduces...
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Omg what a hunk of shit !
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            That's ok. A 2013 samsung plasma I worked on a while ago had a power supply that was warped so bad that it was touching the metal panel backing causing the middle of the panel electrodes inside the screen to change color to a greenish hue that won't go away and where the supply was touching the panel is permanently damaged.
                              Pictures? That sounds crazy. What a bad design.
                              Seriously, it seems like everything consumer electronics wise is now a race to the bottom with no sign of stopping.
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                I took one. I'll try to drum it up.. it's on my server somewhere.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  What was the model of the Plasma as well, everything is going to shit all cheap crap I will always stick with an older Plasma for my main tv ALWAYS !
                                  • Pipolups
                                    Corsair K70 LUX RGB dying LEDs
                                    by Pipolups
                                    Hi there !
                                    I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                    Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                    10-08-2024, 11:58 AM
                                  • THE GTC
                                    Insignia NS-37D20SNA14 intermittent LEDs
                                    by THE GTC
                                    So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                                    When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                                    11-03-2020, 02:40 AM
                                  • pni
                                    Backlight panel diffuser melt by backlight leds broken
                                    by pni
                                    Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                                    10-12-2025, 12:08 AM
                                  • VitalComputing
                                    Replacing Mode Indicator LEDs
                                    by VitalComputing
                                    I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
                                    I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
                                    I thought I could just put a resistor...
                                    09-17-2023, 04:43 PM
                                  • jimbofz
                                    just a quick question do all qled leds appear blue when fault finding ?
                                    by jimbofz
                                    i have replaced many leds strips that have changed blue when they are worn
                                    and the new replacements are perfect white
                                    but when fault finding do quantum leds always look blue?
                                    08-28-2024, 06:51 AM
