Asus X55c bios dump need
  • zonzolo
    • Apr 2015
    • 13
    • italy
    Hello i need a dump bios of asus model X55C (uefi bios)with main board code X55vd rev2.1.
    thanks in advance
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    Re: Asus X55c bios dump need
    prova questo
    • kronnos
      • Dec 2015
      • 9
      • Romania
      This dump work on X55C (mb x55vd rev 2.2) . 10x to gcomputers
      • sandaruwan
        • Dec 2014
        • 19
        • Sri Lanka
        thanks
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Thank you gcomputers, working here too. Attached a copy with clean ME region if the one gcomputers posted gives issues to anyone.
          A working TV? How boring!
          • abbassink
            • Aug 2015
            • 83
            • iran
            • kukasIII
              • Aug 2012
              • 11
              • lisboa
              guys you rock..
              thanks 1000 times
              • Mohammedselia
                • Sep 2017
                • 3
                • India
                Originally posted by kronnos
                this dump work on x55c (mb x55vd rev 2.2) . 10x to gcomputers
                working
                • by_mex
                  • Feb 2014
                  • 57
                  • turkey
                  working
                  • firodrigues
                    • Jun 2015
                    • 2
                    • Portugal
                    Worked, Asus X55VD 2.1. Thanks a world!
                    • teknikpc
                      technical
                      • Dec 2016
                      • 61
                      • Türkiye
                      thanks
                      • 22VDFR
                        • Sep 2017
                        • 9
                        • PORTUGAL
                        thanks abbassink
                        rev 2.2 working 100%
                        • linuss437
                          • May 2015
                          • 12
                          • la spezia
                          I thank the user Th3_uN1Qu3 for the dump working on rev2.1 and I thank the forum, great job all good guys
                          • ABDELKADER
                            • Nov 2017
                            • 9
                            • MAROC
                            thanks
                            • atbykls
                              • Feb 2021
                              • 26
                              • turkey
                              • jimore
                                • Nov 2020
                                • 177
                                • mexico
                                Originally posted by abbassink
                                tanks working for me
                                • rinaty4
                                  • Mar 2017
                                  • 9
                                  • Turkmenistan
                                  Thanks to Th3_uN1Qu3, it works on x55c notebook with m/b x55vd rev 2.1
                                  • razor_amd
                                    [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
                                    by razor_amd
                                    With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
                                    For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
                                    I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
                                    This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
                                    12-15-2020, 07:07 PM
                                  • DynaxSC
                                    Need real mobo dump of BIOS v402 for ASUS PRIME Z590-A - stock image no help
                                    by DynaxSC
                                    I have a serious problem to program the Z590 chipset SRAM with a Management Engine after replacing the chipset.
                                    The new chipset is factory new and is not containing any Management Engine. Any attempts to program it into the chipset under Windows ends with a failure (eg. Error 20: Management Engine Device not present, or something similar).
                                    Due to the lack of the ME several ports on the board, including all M.2 ports aren't working, booting OS works only on USB. So it's now other way, as to program the chipset with a ME.
                                    Usually on ASUS boards it worked...
                                    06-14-2024, 03:49 PM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • Habble7
                                    I need a BIOS dump for the Samsung S49CG934SU monitor
                                    by Habble7
                                    The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                    Suspected Cause:
                                    I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                    Troubleshooting Attempts:
                                    05-22-2025, 07:28 AM
                                  • kcp0085
                                    Request BIOS dump for ASUS FA617NS-A16.R77600
                                    by kcp0085
                                    Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
                                    I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
                                    Specs:
                                    - ASUS TUF FA617NS-A16
                                    - CPU: AMD Ryzen 7
                                    - BIOS chip: Winbond W25Q16JVSIQ (2MB)
                                    If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
                                    Thanks in advance!​
                                    05-02-2025, 12:52 AM
