macbook pro 13 inch a1278 820-2879 Bios dump
  • dellxps15
    • Feb 2014
    • 1591
    • italy
    hi, i need this bios dump for a macbook pro 13 inch that doesnt power on at all. tryed another bios and fan spin but no display and since there was not reported the mainboard code but only model, i need specifically a bios dump for 820-2879 with that mainboard layout.
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: macbook pro 13 inch a1278 820-2879 Bios dump
    i don't knew if it's the same but this is for A1278 820-2879-B
    • dellxps15
      • Feb 2014
      • 1591
      • italy
      tnx really appreciate. will try them tomorrow.
      ive seen with first bios ( wrong as it was 8mb and it's a 32bit bios) macbook power on with a downloaded 4mb pc is dead
      • Comrad_SU
        • Feb 2014
        • 31
        • Ukraine
        Thank You! It's working, but i can't enter to BIOS. No one combination incorrect.
        P.S. Sorry for my english.
        • dellxps15
          • Feb 2014
          • 1591
          • italy
          update about that macbook:
          with bios on it pc power on then off almost immediately. if i remove bios chip, pc stay on with no post, but at least is running. if i put back bios in it it is doing the same all the time...
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            maybe try here
            https://ghostlyhaks.com/downloads/efi-repository
            Im Back... sort of...
            • dellxps15
              • Feb 2014
              • 1591
              • italy
              but ive used dump posted upside and still do the same. when using a dump i hould not have any password right ?
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                dell if with bios attached still not turning on , there is no good communication between smc and bios . do you have osciloscope ?
                • dellxps15
                  • Feb 2014
                  • 1591
                  • italy
                  i dont :S and smc is totally reballed....
                  • highpulse
                    i hate HP
                    • May 2013
                    • 1488
                    • portugal
                    dell beeing reballed doesn't mean that its ok
                    • dellxps15
                      • Feb 2014
                      • 1591
                      • italy
                      i know.... when pc is powered off and bios chip is removed i have volt 3.3 on pins 1-3-8
                      if i power it on also without bios chip i have voltage on pins 1-3-7-8.
                      • highpulse
                        i hate HP
                        • May 2013
                        • 1488
                        • portugal
                        3 7 and8 are 3.3 vcc lines so that ok , pin 1 2 5 6 are command pins TX RX , does are the one you need to test . but does only with osciloscope , or try something like replacing bios chip and insert new rom
                        • highpulse
                          i hate HP
                          • May 2013
                          • 1488
                          • portugal
                          a1278 mcp89
                          bios
                          vinafix downloaded
                          • dellxps15
                            • Feb 2014
                            • 1591
                            • italy
                            let's try this bios too.... tnx
                            ps: once i flashed for bad reading a 8mb bios into 4mb rom and even if bios was soldered , pc power on and fan stays on (ofcourse no post)
                            edit: with this bios dump it does the same..... with soldered bios i have volt on pins 1-3-8 when power off. when i press power on (smc bypass) i have stable volt on pins 1-3-8. pin 7 goes for a fraction of second up to 3volt then 0.
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1488
                              • portugal
                              chek pin 7 on schematic , to see if its normal to drop to 0 volts
                              • dellxps15
                                • Feb 2014
                                • 1591
                                • italy
                                when bios is present it drop, otherwise it didnt.
                                looks like it's related to gpu..... maybe gpu need new bga instead of just a reballing. for now ive removed smc and will put another one just to be sure it's not an smc problem.
                                any good source for mcp89-mz-a2 seller that sell new bga ?
                                gc didnt have any new but just second hand.
                                • Saidogoid
                                  • Jul 2016
                                  • 5
                                  • Portugal
                                  Thank you polytek for the dump.
                                  Mine was chimming and giving white screen, but he dont recognize hard drive and won't give ALT options.
                                  I programmed the bios and do the SMC reset and NVRAM and that solved my problem.
                                  Many thanks,
                                  Regards
                                  • charly22patricio
                                    • Jun 2016
                                    • 4
                                    • España
                                    Many thanks
                                    • Ahari
                                      by Ahari
                                      I...
                                      08-13-2025, 06:12 AM
                                    • Habble7
                                      I need a BIOS dump for the Samsung S49CG934SU monitor
                                      by Habble7
                                      The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                      Suspected Cause:
                                      I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                      Troubleshooting Attempts:
                                      05-22-2025, 07:28 AM
                                    • haitham sharabati
                                      [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                      by haitham sharabati
                                      Hello engineers 😀,
                                      I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                      🔧 Device Info:
                                      - Model: HP 15-da2007ne
                                      - Product Number: 8XF55EA#ABV
                                      - Serial Number: CND0338P0D
                                      - CPU: Intel Celeron N4000
                                      - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                      💀 Problem:😅
                                      - Device shows “Administrator Password”...
                                      08-07-2025, 04:54 AM
                                    • Citymin
                                      NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                                      by Citymin
                                      My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                                      The charging red LED lights up, but the charging screen doesn't show any indication.
                                      When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                                      (I've tried removing the battery and resetting the device, but the issue persists.)
                                      NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                                      PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                                      S/N : 5RNK9FFT70...
                                      08-05-2025, 05:12 AM
                                    • DynaxSC
                                      MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                                      by DynaxSC
                                      Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                                      I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                                      11-17-2023, 10:56 AM
