Dell Vostro 3360 no power on
  • bicalov
    • Nov 2014
    • 294
    • Netherlands
    Hi
    I have a vostro 3360 which don't start.
    On the motherboard I found PQ10 to get very hot, but the components connected to him seems to be OK, no short
    Is this a defective PQ10 for sure or do I have to look at other things?
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: Dell Vostro 3360 no power on
    You will never know unless you remove it and test it.
    • bicalov
      • Nov 2014
      • 294
      • Netherlands
      Thx atsio.
      I have to wait a while to do that because I have to order the part. In my area it have no electronics shops who carry smd chips.
      • atsio
        • Oct 2013
        • 819
        • Greece
        You remove it, you test it, check on board that there is no short and then solder new one.
        • HarryPK
          • Mar 2014
          • 210
          • barabai
          Its look like bad diode...
          • bicalov
            • Nov 2014
            • 294
            • Netherlands
            Hi Guys,
            I put a new PQ10 on the board, but this one also gets very hot, so no gain there.
            Checked around the PQ10 for other components , but no short there.
            There is a strange thing, the mosfets are usually numbered 1-2-3- or G-S -D. There are several 2n7002W but the marking on the board says I-G-O.which does not correspondent with the factory specs from the 2N7002W.
            The schematics shows 1-2-3 of which 1 is on GND and on the board 2 is on ground.
            Can somebody pls explain how to messure?
            • samanthban
              • Feb 2014
              • 253
              • Sri lanka
              mosfet can be easily identified by removing it .n channel single or dual , p channel single or dual.there is a short/falty that's what component getting hot
              sigpic
              • bicalov
                • Nov 2014
                • 294
                • Netherlands
                Thank you, that I understand, but the issue remains about the markings on the mobo, how to interpreted that.
                • bicalov
                  • Nov 2014
                  • 294
                  • Netherlands
                  Wat it looks like, is that Dell uses the marking "In- Out-GND" on the motherboard,
                  This is very confusing, because the schematics use "1-2-3"
                  The pinout from the 2N7002W is 1= Gate, 2= Source and 3= Drain
                  So on the mobo it looks like In=Gate, Gnd=Source and Out=Drain
                  The schematics now look wrong because 1=Source, 2=Gate and 3=Drain and 2 is on gnd
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3610
                    • slovakia
                    replace both two mosfets if it is a step-down circuit.
                    • atsio
                      • Oct 2013
                      • 819
                      • Greece
                      Probably you got the wrong numbering (if I am looking at the right schematic). PQ10 is an 4435. 2n7002W is either the PQ11, PQ1, PQ14 or PQ16.
                      • bicalov
                        • Nov 2014
                        • 294
                        • Netherlands
                        That is correct. The PQ10 I have changed for a new one. The PQ11,-1,-14,-16 are 2n7002W and it is by these ones the letters I,G,and O are on the board and not 1-2-3.
                        If I translate the letters from the board to the schematic, it would be: 1= I , 2 = G and 3 = O. or translated to letters Gate=I, Source= G and Drain= O.
                        Very confusing, see pictures
                        • atsio
                          • Oct 2013
                          • 819
                          • Greece
                          Just remove pq10 again and check resistance relative to ground on pads (on motherboard) 1, 4 and 8.
                          • bicalov
                            • Nov 2014
                            • 294
                            • Netherlands
                            pq10 removed.
                            pin 1-2-3= 286k
                            pin 4= 47,5k
                            pin 5-6-7-8= 152k
                            • atsio
                              • Oct 2013
                              • 819
                              • Greece
                              152k means there is a problem somewhere down the line (but it's not so clear). Do you have a lab supply? Check resistance relative to ground on coils, PL1, PL2, PL3, PL4, PL5, PL6, PL7, PL8, PL9.
                              • bicalov
                                • Nov 2014
                                • 294
                                • Netherlands
                                I do not have lab supply, I do have a 120W adapter which can stand a short cut.
                                PL1= 380 ohm
                                PL2= 10.8 ohm
                                PL3= 2,9 ohm
                                PL4= 9,2 ohm
                                PL5= 42 kohm, starts at 850 kohm and drops to 42 kohm. Capacitor unloading?
                                PL6= 22,6 ohm
                                PL7= 1,6 ohm
                                PL8= 492 ohm
                                PL9= 192 kohm
                                • atsio
                                  • Oct 2013
                                  • 819
                                  • Greece
                                  You have problems on the 3.3v_alw rail as well as on the gfx_core rail. Remove pr133 and check resistance relative to ground on both pads.
                                  • bicalov
                                    • Nov 2014
                                    • 294
                                    • Netherlands
                                    Sorry, I can't find PR133. I looked for more than an hour and I can find all the components in that part of the schematics, except for the PR133.
                                    Also I forgot to mention that I took PU7 off the board to replace it. I waited to measure first before I put it back on. Do I have to put it now or wait
                                    • atsio
                                      • Oct 2013
                                      • 819
                                      • Greece
                                      remove pl6 and measure
                                      • bicalov
                                        • Nov 2014
                                        • 294
                                        • Netherlands
                                        PL6-1 = 1,2 Mohm
                                        PL6-2 = 22,6 ohm
