Aoyue 474a++ temp controlled desoldering station
  • clearchris
    • Dec 2013
    • 687
    I have been fixing a bunch of stuff for work, and I broke yet another solder sucker, so it was time for an upgrade.
    I have seen a lot of complaints in general about desolder stations, so I was hesitant, but eventually decided on the aoyue 474a++ (yes plus plus). The plus plus model has a temp controlled tip and digital temp setting. It was under $200 from sra soldering.
    First impression was wow, this unit is huge. Its also the second impression. That said, the suction is powerful and the pump is quiet. When you hit the trigger it lets out an authoritative hum.
    Here is a pic next to my ebay hot air station and relatively diminutive hakko iron.
    Really, I like it being large, because I assume its going to be easier to fix when it breaks.
    The instructions say to wait 10 minutes for it to heat up. It doesnt take quite that long,but it takes about 5. In use this machine laughs at lead solder and slurps it right up. It actually makes an audible slurping sound, and thats when you know you got the solder.
    Here is an item I desoldered that would have really been awkward with solder wick or impossible with a pump sucker.
    All the way in the corner, i needed to desolder a puny wifi antenna so i could attach a pigtail and external antenna. I didnt even know the pads had holes, I put the gun on the pad, saw the solder melt, and there was the hole. I think this unit has PB solder, but Im not 100% sure.
    I also desoldered some caps from.a multilayered lead free motherboard with some large ground planes. That was more challenging. In general, i melted some Pb solder onto the leads with an iron, and that made it easier. Sometimes it would pull half the solder from the hole. If that happens, I refill it with pb solder and next attempt is generally successful. If the pins on the caps are straight, they generally fall right out. If the pins are bent, it takes slightly more wiggling and heat to get them out.
    Overall, this machine makes short work of desoldering, and Im getting the hang of working the iron in my right hand and the desolder gun in the left.
    I did some smt work today (check.my other post today) and it worked well. I probably should have used a smaller tip, but i thought of that after the unit was already hot. It was very nice and in one instance pulled the solder out from.under the chip and released it. Then the smt component got stuck in the tip. It came out with a chip popper, but a smaller tip.is definitely advised for fine work.
    So I give it the Chris seal of approval.
    Ill try to answer questions if anyone has any.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Aoyue 474a++ temp controlled desoldering station
    See this thread and with respect to what I bolded above. I know it is not the same model, but you both bought it from SRA.
    https://www.badcaps.net/forum/showthread.php?t=44489
    --- begin sig file ---
    --- end sig file ---
      • 31026
      why say
      It was under $200
      and not just say it was $145?
      http://sra-solder.com/aoyue-474a-dig...ering-station/
      btw, what is the wattage exactly???
      This is a desoldering station for thru hole boards and components. The tools has zero crossing circuitry to prevent electrical surges. This 474A++ is a thermostatically controlled desoldering station that provides low cost and solid performance with a 150W heating system.
      Features:
      70 Watt heater Long Life heating Element
      Temperature range 150-380 ºC (302-716 ºF)
      Suction Flow 15 L/min ( max)
      Digital Controls
      User configurable 1 to 60 minute idle-to-auto-sleep mode for additional device protection and power saving.
      Digital Calibration
      • clearchris
        • Dec 2013
        • 687
        I said under 200$ because I didn't remember the shipping. I didn't realize I was stepping into a deposition. I also said under 200$ because there's nothing comparable at the price range.
        I assume it's a 70w system, I saw the typo beforehand. It can get extremely hot though, I feel the heat coming off the barrell. I don't get that with my soldering iron.
        For grins, I'll open up the box sometime this week and post some pics. So far though, my experience has been good, and I'm still learning to use it.
        One nice thing is it has an auto-shutoff, I don't think the non-digital ones have that, it may help with wear on the tips.
        BTW, I'm not a shill for Aoyue or SRA. So far though, I am happy with the unit. I just like fixing things electronic, but it's not a career for me, so I can't justify Pace or some of the other big names. I also don't put wear on a unit like a pro.
        For the record, I opened up my no-name Chinese hot air station and pointed out some of the shortcomings on here. But so far, so good.
          • 31026
          what type of pump does this use?
          is it a loud blast like a big motor,
          or a low sound like a pool pump?
          • clearchris
            • Dec 2013
            • 687
            Imho, big motors dont make a loud blast. Not electric ones anyway.
            This is a deep hum. Ill have pics up later. Btw, its a large enough motor that they put rubber spacers (like you see on refrigeration compressors and some elec motors) between it and the frame. You can see it if you turn the unit over, which you have to do to remove the shipping screw.
              • 31026
              sounds like a diaphram type.
              i have a weller with a vane pump that looks like a truck airhorn comressor and sounds like one.
              but that bitch can suck like a pro on a friday night!!!
              • clearchris
                • Dec 2013
                • 687
                I opened it up. AFAIK, the iron runs on 24v. I didn't trace out the pump, it may run on 110v or 24v. Lots of room in here, if the pump fails, I'll definitely be able to find something that fits.
                I can't identify the manufacturer of the caps on the board, but I wasn't expecting anything special. On the plus side, the board silkscreen is more detailed than any other I have seen before. Caps are labeled with their rating, etc. The board looks like it can also support a soldering iron, they probably have a model with an iron attached (maybe that's where the 150w came from iron + desolder gun).
                Would have been nice to have a fuse, but that can be added on easily enough.
                  • 31026
                  the soldering iron one is this:
                  http://www.sra-solder.com/aoyue-701a...dering-station
                  • clearchris
                    • Dec 2013
                    • 687
                    After reading through the other thread and doing some research, I'm still fine with my purchase. However, I wouldn't touch the other unit, a fully handheld model. IMHO, it takes more manufacturing skill and a lot of custom parts to get everything small enough but still strong and light enough for a handheld unit. That and the price differential isn't that much to justify buying the off-brand unit.
                    Given that full vacuum is only ~14.7psi, the flow moved through the gun isn't terribly high either, there are plenty of very sturdy looking aquarium pumps that could be suitable for the job. My only concern there would be that aquarium pumps are meant to run constantly (I assume), many start up cycles could end up burning the motor.
                    The other parts look to be off-the-shelf, except for the gun parts. I haven't done any research yet to see if I could fit any hakko tips to it yet, but it could be possible.
                      • 31026
                      the pump in your foto's is mains powered - i'm sure.
                      if you did have to replace the pump, the originals are well under $50,
                      but i would fit an airhorn pump and a 12/24v transformer to drive it.
                      it will be loud, but have much higher performance.
                      if you keep the filters clean the pump should be o.k. though.
                      on mine i added an extra filter just before the base using a plastic inline fuel filter from the local car parts place.
                      cost me about 4€
                      • clearchris
                        • Dec 2013
                        • 687
                        Excellent tips thank you! I didnt think of an airhorn pump. The fuel filter idea is also excellent. I bet I could find an inline filter in the airtools section too.
                        Thanks!
                        Oh, and I take back not having a fuse. Its hard to see unless you are really looking right at it.
                        • dahoneycutt
                          • Feb 2016
                          • 2
                          Hello Group,
                          I really need to find a schematic for my Aoyue 474a++. Anyone have a copy or suggestions as to where I can find one?
                          Thanks,
                          David
                          • clearchris
                            • Dec 2013
                            • 687
                            Id ask SRA solder products.
                            What is wrong with it? It didn't look complicated when I opened it up.
                              • 31026
                              you could draw one up with Eagle in under an hour.
                              • myth77
                                UV solder mask - high temp resistent, recomendation?
                                by myth77
                                Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                                Is there any solder mask...
                                03-28-2022, 04:04 AM
                              • corrize
                                Best way to solder LVDS connector for beginner (and qfn) ?
                                by corrize
                                Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                                I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                                I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                                See the test :
                                https://youtu.be/bNAzC-EvqHs?t=1767
                                With hot air from bellow the board, that's...
                                03-09-2023, 02:57 AM
                              • mentholflash
                                Aoyue 738 4 in 1 solder station power board
                                by mentholflash
                                Hi all
                                Hope sumone can help.
                                the heating element failed, so i bought a new one researched how to replace it.
                                I wasn't looking forward to it much but was gonna do it anyway.
                                i powered it up just to make absolutely sure i needed to. (This was my first big mistake)i knew it needed changing.
                                so got all tools together, i started taking out screws and consentrating on instructions from the laptop.I grabbed the old element with a pair of pliers to pull nit out of the handle and bang little puff of smoke it was still plugged in.
                                so 20 years later can anyone help me...
                                07-26-2023, 10:19 PM
                              • petemanuk
                                BGA solder balls not connecting - help pls
                                by petemanuk
                                So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                11-16-2022, 05:21 AM
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
