UPDATE (to CCFL-LED Conversion wiring question)
  • Sledge Fingerhammers
    • Feb 2015
    • 8
    If at first you don't succeed....keep on looking. And looking...and looking. Plus a little Google Translate...
    Following these links for info on a Delta DAC 19M005/19M009:
    http://translate.google.com/translat...D8&prev=search
    https://cdn.badcaps-static.com/pdfs/...d7f0a99bf3.pdf
    What I end up with is:
    (My original numbering was wrong)
    CN5:
    1: Audio Out L+ | 2: Audio Out L-
    3: Audio Out R+ | 4: Audio Out R-
    5: Shutdown | 6: Audio Mute
    7: Volume Adj | 8: +13.8v
    9: +5v | 10: +5v
    11: ???* | 12: Gnd
    13: Gnd | 14: Gnd
    15: Inverter On | 16: Dim
    * from various sources, it's "+5v AU", "DET", "AUD EDT", and I have no clue what they mean. "Audio Detect" is the only thing that sounds like it makes sense, but it's not necessarily right.
    Anyway, I'll wire the LED strip driver to 8, 14, 15 & 16, and see what happens. If it blows up in my face, I'll be sure to report that here, as soon as I get out of the hospital...
    • 31094
    Re: UPDATE (to CCFL-LED Conversion wiring question)
    test it before you fit the strips into the panel.
    i had a bad one once where the wires had been fitted the wrong way from the strips - easy to fix but best to test before you totally assemble it.
    and you need to disable the invertor.
    i would remove the 2 8pin fets, the transformer and the controller ic on the other side of the board.
    along wih the 4 blue caps and the tube sockets.
    then fit the led board in the space with foam tape.
    edit: after looking at the pdf, you can leave the chip in place, it does not send error info.
    but you should pull the fets & transformer.
      • 31094
      actually, dont use the 13.8v, you could damage the psu.
      use the 19v after the fuse F200
      that is the backlight supply.
        • Feb 2015
        • 8
        Thanks for the headsup, stj. Got all that real estate cleared, went to test for voltages and got 169 at the big cap, 14.1 for 13.8, 22.4 at F200, and zero for 5v. Maybe I shorted something with my sloppy desoldering and blew F101. Got a new fuse on order, and I'll clean things up, inspect it under magnification, then try again.
        Incidentally, my board is a 19m009, which is very much like the 19M005/8/10, but they all have their little differences. Any idea if the controller IC can still stay, or should I just go ahead and take it out?
          Just remove the power MOSFETs that drive the Inverter transformer.
            • 31094
            yea, pull the mosfets, and i'd pull the transformer , blue ceramics and tube sockets just to clear the area.
            then you can stick the new invertor there with tape.
            you dont need to pull the controller because it does not send any error codes back.
            some tv's / monitors do - but this one doesnt.
            • JonathanAnon
              • Jul 2012
              • 457
              • Ireland
              Hi guys,
              sorry for digging up this thread. I have a TV at home with 22 inch CCFLs, two of which are broken, so i was gonna try and replace with LED strips. Here's what I'm thinking at the moment:
              1. Pull out the pico fuse to prevent the 12V being fed to the inverter circuit. (Might take out the MOSFETs and transformer just to be sure, but pulling the pico should be enough).
              2. At that 12V, take a 12V feed to my LED strips. The 12V at the secondary stage is already regulated, I just need to make sure I dont pull too much current through that particular rail.
              3. Connect the BL_ON to the base of a MOSFET, which will be used to switch the ground for the LEDs, and switch them on and off. I dont care about dimming them.
              I know I'm brief on details here but does this sound okay?
              thanks,
              J
                • 31094
                the led driver has a logic input for BL_ON, you dont need a mosfet.
                • JonathanAnon
                  • Jul 2012
                  • 457
                  • Ireland
                  Hey,
                  I was gonna try it without the driver board and hook the LEDs directly to the 12V (that normally feeds the inverter board). Just thinking about it, I'm probably better off using a driver, otherwise I'd have to set up limiting resistors.
                    • 31094
                    bang!
                    where are you gonna find slim strips without the current-regulated convertor anyway?
                    • JonathanAnon
                      • Jul 2012
                      • 457
                      • Ireland
                      Well I was just thinking about trying different configurations of these types of LED strips. They have the LED built in. I dont see how it goes bang, though, the SMPS should regulate the voltage for the 12V rail, and then resistor for each LED limits the current, and as long as I dont pull more current from the rail that it can handle it should be okay, no?
                      http://www.lck-led.com/images/P6180789.JPG
                      I'm thinking that I will have to do some sort of improvisation, as I will not be able to find an LED strip that is the exact length and fit for the panel.
                        • 31094
                        those are too wide and too far apart.
                        • JonathanAnon
                          • Jul 2012
                          • 457
                          • Ireland
                          Yeah, I havent fully thought that part through, other than there will be a strip of LEDs fitted in the place of the CCFL. I need to do a bit of work on sourcing a strip of LEDs of the right colour and size. I'll see what's available, but like I said above, it's unlikely that there will be 22 inch strips so I will have to do some improvisation.
                            • 31094
                            there are 22" strips - infact i'v seen them sold upto 24"
                            • JonathanAnon
                              • Jul 2012
                              • 457
                              • Ireland
                              Yeah, you might be right. I'm in Ireland so I'm not sure there will be a local supplier, but I could get one from the UK. Not much point in reinventing the wheel by trying to make one up myself. Waste of time.
                              http://www.ebay.ie/itm/490mm-LED-Bac...-/141818678470
                              • akwky
                                by akwky
                                Hi!
                                04-14-2025, 01:56 PM
                              • TheUser
                                Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                by TheUser
                                Hello to everyone ,
                                This is my first post here, and i would like to share with you a small story in case you can help me.
                                Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                02-10-2024, 02:07 PM
                              • lordgeny
                                z490-f gaming bricked after bios update
                                by lordgeny
                                I had to assemble a PC with this Z490-F Gaming motherboard and an i7-1700K CPU. Upon the first boot, the CPU LED was red and flashing. I realized that I needed to update the BIOS. I didn't read the ASUS notice that said, "Before BIOS update, please download Intel ME update tool from ASUS support site, and update ME firmware to Version 14.1.53.1649V1.1 to ensure optimized system settings." I updated the BIOS without doing this, and everything seemed fine until the system performed an Intel ME update and shut down permanently. My attempts to reflash it were unsuccessful. Searching online,...
                                11-02-2023, 09:03 AM
                              • iMuhtaseb
                                A1706 2017 critical update
                                by iMuhtaseb
                                this board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
                                we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
                                One weird symptom is it takes too long to power on and show the Apple logo for some reason..
                                I've taken a look into the MLB and noticed tiny liquid around Q3100.. its...
                                08-13-2024, 08:41 AM
                              • al3m0di
                                Update bios EFCN58WW to EFCN59WW
                                by al3m0di
                                Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                                I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                                The BIOS version is EFCN58WW.
                                When I turn on the device, it displays the message:
                                "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                                The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                                I've tried
                                07-29-2024, 10:32 AM
