Sharp Aquos blinking error help needed
  • Soltys
    • Feb 2015
    • 17
    • England
    Hi folks, I'm hoping someone can help.
    I've got a Sharp Aquos LC32X20E in that has a flashing light error of LED x 2 OPC x 3
    After speaking to sharp customer support (who weren't much help) the error was pointed towards either firmware upgrade or power supply issue.
    I've done the firmware upgrade and also after testing the power board the error pointed at a Schottky diode which I've replaced. However the tv is still stuck with the blinking error code cycle. Before fitting the new diode I could force the tv on, However now I cannot.
    Any help would be greatly appreciated
    Re: Sharp Aquos blinking error help needed
    The model number of the TV would be great help, as would pictures of the boards inside the set so we can understand the layout and configuration.
    • Soltys
      • Feb 2015
      • 17
      • England
      Sorry just added the model number. I'll take a pic now....
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        We need good clear photos and the model number please.
        • Soltys
          • Feb 2015
          • 17
          • England
          Here's 1
          • Soltys
            • Feb 2015
            • 17
            • England
            Here's another
            • Soltys
              • Feb 2015
              • 17
              • England
              The readings come back as follows, Whilst cycling the error code
              PS ON 0v At power on 3v initially then drops to 0v
              AC DET 3.13v
              PNL POWER 0
              BU5V 5.01
              UR15V 0
              UR15V 0
              UR15V 0
              S15V 0
              S15V 0
              Apart from the PS ON Voltage changing when initially powered on everything else reads the same
              • nomoresonys
                • 12271
                • U.S.
                maybe the mainboard isnt turning on the power supply.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  The mainboard is telling the psu to turn on because it has the 3.1v telling it to turn on....
                  • nomoresonys
                    • 12271
                    • U.S.
                    ok, maybe you can tell him why his 15s are missing huh?
                      Disconnect inverter connection - a shorted inverter can cause the 15V to drop out (will short 60V which runs off same trafo)
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Im with him now, the pson signal is fine if you bothered to look it up the 15s isnt coming on for some reason and is shuting down. If you read we had to repair he psu we are checking that now and disconecting the inverter, dont bother trying to help us anymore mate.
                        • Soltys
                          • Feb 2015
                          • 17
                          • England
                          Ok I've tried that and all the readings are the same Tom
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16958
                            Alright, everyone go to your corner and take a breather. There is an ignore feature on this forum, use it if you guys can't get along.
                            <--- Badcaps.net Founder
                            Badcaps.net Services:
                            Motherboard Repair Services
                            http://folding.stanford.edu/
                            Team : 49813
                            Join in!!
                            Team Stats
                              Ok, Soltys, please check the voltage across the 450V capacitor.
                              This is a large capacitor on the PRIMARY (DANGER) side of the power supply. Your volt meter will need to be on a high DC voltage range, red probe one end of cap, black on other end.
                              Do not touch the two leads together and do not touch anything on the primary side with any part of your body...
                              We are expecting around 320V in standby, ~390V running.
                              • c_hegge
                                • Sep 2009
                                • 5219
                                nomoresonys and ReeceyBurger123 - Enough!!
                                The next argumentative post in this thread will result in an infraction.
                                • nomoresonys
                                  • 12271
                                  • U.S.
                                  not a problem, we were just having a little fun.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Its ok me and sony have called it quits now
                                    • Soltys
                                      • Feb 2015
                                      • 17
                                      • England
                                      Ok thanks Tom, I will give it a go in the morning and come back to you, thanks for the help bud
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        We will check the psu over again to make sure there are no more dead shorts.
                                        • olegeisler
                                          SHARP AQUOS LC-70LE836S only blinking - freebie
                                          by olegeisler
                                          Got this SHARP AQUOS LC-70LE836S for free - did some basic troubleshooting, and found manual - without detail schematics though. Comes from a meeting room with extremely few working hours.
                                          Symptoms :
                                          When connected to mains, the logo blinks continously, approx 6 times per 10 seconds.
                                          A press on MENU as per the manual changes this to one short blink, one long and then repeats.
                                          Only 5V ( Standby ) on PSU module present, no AC_DETECT, no 12V, no 13V, no PS_ON from mainboard.
                                          As I see it mainboard has some kind of life, but does not...
                                          07-23-2022, 07:01 AM
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • jonah1024
                                          Sharp Aquos LC-40UG7252E LCD TV burn in?
                                          by jonah1024
                                          Hello!
                                          I'm a few days old into this TV screens repair universe so please bear with me.
                                          Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                                          - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                                          - I did a factory reset as well...
                                          07-16-2024, 04:23 AM
                                        • bajdik
                                          Sharp LC-40LE830E white blinking after wallplug is off
                                          by bajdik
                                          Hello, on Sharp LC-40LE830E is everything OK. Working great. If I put the 230 V off and on again, it just blinking white standby LED. I can power on only via VOL- and CH+ and POWER button on TV. After that, I can power off and power on again without problem (by buttons or remote control) until the 230 V is connected. If i put the plug off and on again, just white standby LED blinking. TV needs three button starting again.. On the first look, the backlight looks great, no darker or lighter spots. Any idea what is wrong?
                                          07-21-2023, 09:05 AM
