LG 42PA4500 mainboard LED codes
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    HI all,
    I have this TV , without picture,sound.. only LED on mainboard blinking all the time : 1 second blink, then 5 second nothing and then again 1 second blink and again, again...
    Have someone blink code table or something like that? Thanks for answer.
    Re: LG 42PA4500 mainboard LED codes
    Is that on control board, or on actual main board (with HDMI ports, etc.)
    • DeniS182
      • Jun 2014
      • 328
      • Slovakia
      It's on mainboard , board with all connectors like hdmi, scart etc.
      Led on front panel is turned off and nothing changed when I pushed start button or other buttons ..
        I've never seen led like that on a newer LG plasma. It's not optical port or for Ethernet?
        • DeniS182
          • Jun 2014
          • 328
          • Slovakia
          It's not optical port or for ethernet.. I attached some photos.
            OK, what you can try and do is jumper the two holes marked EXT AUTO GEN on this board:
            https://www.badcaps.net/forum/attach...1&d=1421777971
            And disconnect LVDS (right most ribbon connector)
            Then plug TV into mains power.
            Do you get a sequence of test patterns appearing on the screen?
            • abdekader
              • Jul 2014
              • 73
              • Turkey
              i have the same TV check the Y-sus IGBT transistor shorts , but after i change it the same transistor shorts , this problem to me in all of kind of LG PLASMA Y-SUS T KIND
              something problem in it
              check 18v in Ysus
              Electronic Engineer from Syria,Aleppo
              • DeniS182
                • Jun 2014
                • 328
                • Slovakia
                tom66: I jumped these two holes and disconnect lvds cable too (ribbon cable with blue end), but nothing.. no picture. But LED on mainboard was off and LED on front of TV was ON and when I push start button , then this led turn off and again turn on and stay ON.
                abdekader: I'll check it tomorrow.
                • DeniS182
                  • Jun 2014
                  • 328
                  • Slovakia
                  I didn't have time to work on this sooner.
                  Now I measured components on heatsink, on YSUS and some are short circuited. I can ask you how to remove board from tv? I unscrewed all screws, but I have problem with three connectors. I don't want damage it. Any idea to remove it without damage connectors / board?
                  • drussell
                    • Nov 2014
                    • 144
                    It can take a fair bit of pulling force, yeah...
                    I generally use a pair of needlenose pliers, opened slightly and twist between the buffer board and the Y to help pry them apart while pulling. This is much kinder to the edge of the board than a screwdriver, for example, since the outside of needlenose pliers are generally rounded. Just be gentle and take your time.
                    If there is a spot that has the little protrusions from where the boards are snapped apart during manufacture and you need to pry them apart, do it there since it gives a bit of added protection to the edge of the board. If you ever run across ones that are really tight or have many connectors you can always shim in a little plastic against both boards when you stick something in there to pry them apart.
                    • DeniS182
                      • Jun 2014
                      • 328
                      • Slovakia
                      drussell: thank you for advice.
                      I found three short circuited components. First on heatsink Q709 - KF7N60 (N channel mosfet), second and third on bottom of pcb both in DPAK package. And I don't know what they are. You can see on photo of bottom PCB - eight components in dpak in a row and first and last are these short circuited. On first is written JF63K2 A3P 02 and on last is written F2A A1P 069. Have someone service manual/schematic of this TV or can help me with identification of these burned-out components? thanks for answer.
                      • DeniS182
                        • Jun 2014
                        • 328
                        • Slovakia
                        I can't find schematic of this YSUS board. Can you help me?
                        • jamesb6
                          • Nov 2012
                          • 20
                          I have one of these sets as well. It has the exact same behavior as DeniS182 tv. I have also found shorted components on the YSUS but my board has different ones shorted. My shorted FETs are Q734, Q735, Q736 and Q737. Two on the under side and two on the heat sink.
                          I suspect a new YSUS is the fix. Any advice?
                          • cloo
                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                            by cloo
                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                            After doing a factory reset this problem was gone and the picture was back to...
                            01-06-2025, 06:02 AM
                          • Mirenia
                            Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                            by Mirenia
                            Hi everyone,
                            I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                            I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                            In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                            The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                            03-30-2025, 06:47 AM
                          • EazyBone
                            Un50cu7000 2 blink oddity *partially solved
                            by EazyBone
                            I write this to maybe help another with this TV.
                            So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                            The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                            03-18-2024, 10:24 PM
                          • orcic
                            MASTER TL240 and new mainboard LW36BKC01
                            by orcic
                            I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                            The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                            After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                            Now I have some doubts about how to connect the new mainboard to the old power supply.
                            First of...
                            05-12-2023, 08:10 AM
                          • noonyf
                            Sony NSX-32GT1 need blink codes.
                            by noonyf
                            Hello, does anyone have the blink code for this model? I have the schematic but it doesn't list the blink codes. After the set is on for a minute or two, it will shut down and blink 10 times.
                            thanks
                            09-18-2020, 09:54 AM
