LG Plasma 50PK540 Lightning Victim LED Light Relay Clicks On Plug In Nothing Else
  • Michale32086
    • Nov 2011
    • 1453
    LG was the victim of a lightning strike. No bad caps or burn marks, no scorched areas at all..
    I get no power on VS or VA.. Zilch.. Nada.. None..
    So, I am thinking bad power PCB....
  • MagicSmoke
    • Feb 2011
    • 275
    Re: LG Plasma 50PK540 Lightning Victim LED Light Relay Clicks On Plug In Nothing Else
    Unplug power connectors to X & Y boards and see if VS & VA come on and stay on. If not then PSU, if so then X or Y have problems.
    • Michale32086
      • Nov 2011
      • 1453
      OK, unplugged the X and Y boards..
      The VS acted a little different. It counted up slowly from .000v to around .035v.. But it got no where near the 201v it should be..
      I didn't even bother checking the VA, as it's obvious the power PCB is shot...
      Thanx for the input.. Still no chance to play with my Rigol!!
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Well it is meter time- Fuses ok?-
        Next two gray components between the two relays and the edge of the board.
        Think some sort of surge protectors - test them for resistance.
        Next Looks like two?? Bridge Rectifiers on the end of the heatsink often suffer in surges
        • Michale32086
          • Nov 2011
          • 1453
          And I GOT my meter this time!!
          Yea, fuses check out OK..
          Refering to pic. There?? RED
          There?? BLUE
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Yes
            • Michale32086
              • Nov 2011
              • 1453
              OK I get about 16ohms +/- .2 or so on the gray components
              The bridge rectifiers look in good shape. No burns, bulges or blows... Can I check their voltages??
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                If the pins are visible/ touchable from the top of the board set your meter on 600vdc and
                test the outer two pins. VERY carefully!!
                THEN metre on 600vAC test middle two pins. should be same as mains voltage.
                Also test the resistance of the green glass? component near the mains socket.
                If the BRs are not easily accessible or you dont want to mess with high voltages
                you can do an ohms2000 test on the bridge with power OFF 1 to 2 then rverse the probes and test again then 3 to4 then reverse the probes and just as final test
                for a dead short 2 to 3
                • Michale32086
                  • Nov 2011
                  • 1453
                  That always scares me the crap, as my grandson would say.. But, better to be scared and cautious then brave and stoopid..
                  The meter I have is auto-adjusting so I don't need to worry about settings beyond the AC/DC setting..
                  They are fairly accessible, but I'll check the connections this way first...
                  • Michale32086
                    • Nov 2011
                    • 1453
                    I assume the pins are numbered as shown??
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      Yes - we are only doing this as you seemed to suggest there was no power but a short cut and often easier to get at is to test the BIG caps voltage maybe up to 400DC
                      so again careful does it.
                      • Michale32086
                        • Nov 2011
                        • 1453
                        The right one...
                        1-2 6.7 Mohms
                        3-4 1.69 Mohms
                        The left one...
                        1-2 8.7 Mohms
                        3-4 2.8 Mohms
                        • Michale32086
                          • Nov 2011
                          • 1453
                          On the marked cap
                          397V
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            Looks good to me so far what is the voltage printed on the cap
                            • Michale32086
                              • Nov 2011
                              • 1453
                              450v
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                On the power board there are about 7 white ceramic resistors (2 on the left 5 on the right of the psu) do these all test ok? it should say on the side of them what they should read.
                                • selldoor
                                  Slow Learner
                                  • Dec 2010
                                  • 7870
                                  Just in case you were wondering or anyone spots it the test for the bridge was not quite correct - It was ok for testing for a short but to test correctly meter should be in Diode mode - hence the reason for reversing the leads should show something one way and infinity when the leads swapped.
                                  • Michale32086
                                    • Nov 2011
                                    • 1453
                                    Should those be tested with the unit powered up??
                                    • Michale32086
                                      • Nov 2011
                                      • 1453
                                      Ahhhhhh Makes sense.. Sorta
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        With power off and on ohms mode on meter.
                                        • Rensiee
                                          Panasonic TH-50PX8EA Black screen, only relay clicks
                                          by Rensiee
                                          I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
                                          I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
                                          When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
                                          I have measured the voltage in the VSUS line, which...
                                          06-18-2024, 12:58 PM
                                          Samsung LN46b530p7f – relay clicks and backlight cycling, sound OK
                                          by momaka
                                          I got this TV a little over a year ago from a coworker from my previous job. It’s a Samsung 46” TV, model number LN46b530p7f.
                                          Problem:
                                          Backlight cycles On and Off.
                                          Basically, when the TV is turned On, there is a relay click heard from the TV PS board. The relay cycles On and Off 4 times in about 2-3 second intervals. Each of those 4 times, the backlights also cycle On and Off with the relay. The screen TFT isn’t cracked/damaged and appears to work - I can see a “no signal” image when the backlights turn On briefly – though the image is a bit dull/dark....
                                          01-17-2019, 11:23 PM
                                        • samtron786
                                          toshiba 46xv555d relay clicks
                                          by samtron786
                                          Hello
                                          The red and green LEDs both light up and you can hear the relay click. (no picture, no backlight, no sound)
                                          2-3 seconds later the relay will click again and only the red LED will stay on.
                                          I would be very grateful for any advice or a little help.
                                          circuit diagram?
                                          Thanks very much
                                          02-04-2023, 04:39 PM
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                        • jm1234
                                          9V relay temperature 40C
                                          by jm1234
                                          Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                          I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                          05-09-2024, 03:03 AM
