Panasonic TH-50PX500U
  • PBJ
    • Jun 2014
    • 8
    Hoping you guys can give me some guidance on what my problem is. Thanks
  • PBJ
    • Jun 2014
    • 8
    Re: Panasonic TH-50PX500U
    The power light stays red, no blink. Unless it needs to be interrogated?
    • NickStam
      • Jun 2014
      • 8
      Is it still displaying a picture? Is it frozen?
      • tw2005
        • Oct 2011
        • 6458
        I'll take a punt and say D board. You won't get a SOS blink with that kind of fault. D or DG boards but I have not really worked that kind of fault. It's definitely not Sd/Su/Sc/SS/PSU/ C boards.
        • PBJ
          • Jun 2014
          • 8
          [QUOTE=NickStam;460558]Is it still displaying a picture? Is it frozen?[/QUOTE
          The display isn't frozen. It functions properly just has the bars in front.
            D board is a likely cause. You can check the on board test pattern.
            SM for PX50U, a similar model:
            page 39
            Test patterns somewhere there - can't remember exactly how but think it's a few presses of the buttons to access it. Power off to exit.
            • PBJ
              • Jun 2014
              • 8
              I initiated the self test yesterday and these were the results....
              UV OK
              SND OK
              ADV OK
              MEM OK
              DT1 OK
              DT2
              OK
              AVSWV OK
              AVSWA OK
              QC4P OK
              RTC
              OK
              HDMI OK
              PANEL OK
              SOS: 8
              I initiated the test two additional times and did not have the SOS code. I haven't found in the manual yet what that means but still looking.
                SOS 8 is SS board MID voltage low or electrodes disconnected/loose. Has the TV ever failed to turn on, with a flashing red light 8 times?
                • PBJ
                  • Jun 2014
                  • 8
                  No it turns on every time and the light has always stayed solid.
                  • PBJ
                    • Jun 2014
                    • 8
                    Thinking about ordering a D board and an SS board and give it a try. They aren't that expensive so what the heck.
                      I wouldn't order an SS board if the 8 blinks does not occur. Chances are the SS error could be original from the factory when they did the first test. (It obviously failed so they exchanged the SS board before shipment.)
                      • BigPete
                        Panasonic Heatpump Dryer Repair
                        by BigPete
                        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                        Unfortunately the whole machine has to come apart to fix it.
                        I have...
                        11-01-2025, 06:40 PM
                      • Andre Gilbert
                        by Andre Gilbert
                        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                        11-20-2024, 08:52 PM
                      • AquaMan Ua
                        Problem with PANASONIC CF53 laptop after changing BIOS settings
                        by AquaMan Ua
                        Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                        05-17-2025, 09:40 AM
                      • CDNBrewer
                        Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                        by CDNBrewer
                        Hello Everyone,
                        I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                        Symptoms:
                        • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                        • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                        • I swapped the Left and Right surround
                        08-05-2025, 09:29 PM
                      • stecos
                        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                        by stecos
                        Hi everyone!
                        I happened several times, in the search for help from the web, to consult this very interesting forum.
                        So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                        Having said that I come to the gist of my post on the forum as the title suggests.
                        For my passion for technology I'm now collecting several...
                        11-28-2022, 11:39 AM
