LG 42LS3450 powers off
  • Manddave
    • Oct 2013
    • 58
    • Uk
    Hi
    I have a Lg 42 ls3450
    The problem is it will not stay on it comes on for a short time and then powers off.
    Can you help please
    Many thanks
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: LG 42LS3450 powers off
    Post some clear pics of the boards inside.
    • dkneyle
      • Dec 2013
      • 441
      I've just repaired an LG 42PJ350. I suspect it's close to the same set. It will be the power supply. Have a look for a 6 terminal regulator attached to a heatsink. It might have the same part number as mine did: 3BR1565JF. They seem to be notorious for failing the way you have desscribed. I assume all your electro caps on that board look OK? There's some high wattage low value resistors that fail, as well as a diode close to the 6-terminal regulator. But I reckon it will be that regulator. Let us know how you go. (By the way, those regulators are a couple of bucks on E-Bay.)
        Your model is a plasma, his is an LED-LCD, unfortunately I doubt the power boards will be similar.
        • dkneyle
          • Dec 2013
          • 441
          Of course Tom is correct! (I was trapped by the similarity of the model codes without having drilled down deeper.)
          • angel-boy
            • 550
            • Romania
            I ask here , i dont want to open another topic,
            i have a problem with 42ls3450 display panel . see photo ,
            problem with panel or t-con ?
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              Looks like AS-15,--If it has one....
              TELEFIX
              • angel-boy
                • 550
                • Romania
                have a TPS65178 , and in few seconds is hot
                  Unplug one ribbon at a time from the T-con (on the LCD panel side, not the LVDS cable.) If the TPS chip cools down or half the picture looks normal, it's probably a short on the panel and there's not much you can do about that.
                  • angel-boy
                    • 550
                    • Romania
                    i try this, i remove one ribbon ar a time , but no image right or left side, only vertical lines
                    • michael dranfield
                      • Jan 2016
                      • 232
                      • England
                      I have had this exact fault on an LG TV with the LCD bias IC getting hot and un pluging one side of the ribbon cable did indeed cure the fault , however sometimes this problem can be nothing more than a smd ceramic decoupling capacitor on the LCD connection board and with nothing to lose I applied 12 volts at 10 amps to the board power feed and in the blink of an eye something went up in smoke and the short was burnt away , so I am assuming it was just a decoupling capacitor.So worth thinking about if you have nothing to lose and dont want to disassemble all the panel to fault find the connection board.
                      • disorder
                        HP 2311 display, 3.3v regulator fried, need help to replace
                        by disorder
                        hello,
                        i have a hp display 2311 to repair, totaly dead
                        on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
                        i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
                        thank you
                        07-27-2025, 04:34 AM
                      • VcemPzd
                        Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                        by VcemPzd
                        Hello everyone !
                        My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                        04-28-2025, 10:14 AM
                      • bilux
                        uP0109: 2A Ultra Low Dropout Linear Regulator equivalent substitute
                        by bilux
                        I want to find a replacement for uP0109 8pins, and i found this parts:
                        uP0109 is "2A Ultra Low Dropout Linear Regulator"
                        RT9199 is "Cost-Effective, 2A Peak Sink/Source Bus Termination Regulator"
                        FP6137C is "2A BUS TERMINATION REGULATOR"
                        can replace uP0109​ by RT9199 or FP6137C ?
                        11-01-2024, 12:00 PM
                      • malogro
                        Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                        by malogro
                        Hello all,
                        I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                        Intro:
                        This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                        Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                        04-14-2023, 04:44 PM
                      • playit
                        diy - voltage injection possiblity with voltage and ampere regulator - possiblity ?
                        by playit
                        hello ,for diy voltage injector for short killer/finder -- is it possible to use something like this - LM317 DC Linear Regulator, DC-DC 4.5~40V Turn 1.2~37V, Step Down Power Module, Adjustable
                        and ampere controller along (to make it zero amps ) with some addons(transistors diodes etc.) for it -- and use some 5v adaptor or 3.3v volt rail of my smps power supply as input and finally get 1v and zero amps for injecting voltage to find out short circuit component ? ..
                        for source input -- can we use 3.3 -4 volt 18550 battery ?( i have some of those ) and then adding ampere regulator...
                        02-26-2025, 05:39 AM
