This power supply uses the same layout as those Solytech psus, reviewed by c_hegge:
http://hardwareinsights.com/wp/xigma...rp-vc503-500w/
http://hardwareinsights.com/wp/the-2...ply-roundup/5/
They all made it to 350-400W with very good voltage regulation and low ripple output except the Xigmatec's 3.3V.
The Allied has full input filter, including MOV protection, 2x 470uF 200V primary caps, 2xTT2194 NPN transistors and FTA02N65 mosfet for 5vsb.
There is passive pfc coil, not fake.
The main transformer is true ERL-35 and the 5vsb transformer is EEL-19.
Secondary:
PWM controller is chip of the year 2005Z.
As you can see, this psu has a fan controller board attached to the secondary heatsink.
5vsb: 1xSR560 2x1000uF 10V YC TK
3.3V: 1xSBL2045CT 1x2200uF 10V Koshin KLH, 1x1000uF 10V YC TK
5V: 2xSBL2045CT (total 40A) 1x2200uF 10V Koshin KLH, 1x1000uF 10V YC TK
12V: 1xSB3060PT 30A, 2x1000uF 16V YC TK
-12V: 1x470uF 16V YC TK
There are pi coils installed in every single output including 5vsb and negative voltage rail -12V.
Do you think it is worth recapping?
Btw the bleeder resistors are not of the same value:
R3: 462kohm
R4: 330kohm
so, the rectified voltage is not divided equally. I have no idea why they do this.
Secondary:
R3: 462kohm
R4: 330kohm
